bozrdnag 75 Posted December 31, 2016 Posted December 31, 2016 The latest update fixed the IMDb issue here too. Thanks for all your hard work! 1
im85288 1493 Posted January 1, 2017 Posted January 1, 2017 There's a new version up in the beta repo 2.3.31 There was one last thing to sort out which was handling the adding/updating of the new ratings in the same way we do already for updating the movies/tvshows now when things like artwork change etc. Anyway to cut a long story short this should now be working correctly. A clean install will be needed I'm afraid as the previous version would always create new ratings/uniqueid etc even when an item was only being updated. I guess the best way to test would be to update a rating after the initial install and see if that get's picked up. Thanks 1
sualfred 677 Posted January 1, 2017 Posted January 1, 2017 I knew I forgot something to test yesterday ^^ It's working, thanks. 1
im85288 1493 Posted January 1, 2017 Posted January 1, 2017 Cool thanks for confirming, it was hopefully the final part of the ratings saga
sualfred 677 Posted January 1, 2017 Posted January 1, 2017 Don't pull you hairs out, but Kodi introduced something new with Krypton:ListItem.Rating[(name)] ListItem.Votes[(name)]ListItem.RatingAndVotes[(name)] Desc: "Shows the scraped rating of the currently selected item in a container. Optionally you can specify the name of the scraper to retrieve a specific rating." But afaik there is no available scraper, which supports it atm. So I'm not really sure if it's implemented completely in Kodi 1
im85288 1493 Posted January 1, 2017 Posted January 1, 2017 It should be easy to add to and currently we may actually support it as I add the uniqueid with a type such as imdb for movies/tvshows and tvdb for episodes. 1
sualfred 677 Posted January 1, 2017 Posted January 1, 2017 Good to hear. But I guess it could be ignored for this time, because it seems to be broken anyway.
Sttephan 1 Posted January 2, 2017 Posted January 2, 2017 Confirming that it works ! (After updating addon and local database reset) Thank you guys so much. The missing ratings were always bothering me a lot... Happy new year ! 1
b0mb 36 Posted January 3, 2017 Author Posted January 3, 2017 (edited) Hmm All movies I've scraped today are without rating again.... Edit: Nevermind! Resetting the database fixed things for me. [emoji6] Edited January 3, 2017 by b0mb
