b0mb 36 Posted November 10, 2016 Posted November 10, 2016 Hi! After some ppl told me that Emby is meanwhile running flawless on krypton i´ve migrated from jarvis to latest libreelec build with krypton beta 5. Everything is running fine but i can´t see anymore ratings for movies neither series or episodes. Any idea? Kodi Addo is 3.1.12, Emby is latest beta 214. b0mb
Angelblue05 4132 Posted November 10, 2016 Posted November 10, 2016 (edited) Krypton won't be supported until RC. Ratings changed drastically in Krypton hence why they are not showing right now. Edited November 10, 2016 by Angelblue05
b0mb 36 Posted November 10, 2016 Author Posted November 10, 2016 Hmm... I should hear more to myself than what other ppl saying... Anyway I think it is only a question of time before rc will be ready [emoji6] Gesendet von meinem LG-D855 mit Tapatalk 1
im85288 1493 Posted November 16, 2016 Posted November 16, 2016 Hmm... I should hear more to myself than what other ppl saying... Anyway I think it is only a question of time before rc will be ready [emoji6] Gesendet von meinem LG-D855 mit Tapatalk This comes down to the skin your using, personally I don't find much use in the Emby ratings as they are out of date sooner than you think. Pick a skin that fetches the ratings on demand and you can happily use krypton. I've been using it for months with no issues, regardless of the official policy here that it will not be supported etc etc until RC
b0mb 36 Posted November 16, 2016 Author Posted November 16, 2016 hmmmm... I don´t have anymore ratings to be shown in my kodi. No Movie, no series, no episode... it seems like they are los.... and it doesn´t matter what skin i use - there are no ratings :|
im85288 1493 Posted November 16, 2016 Posted November 16, 2016 Have you tried Titan for example? You need a skin that makes use of the skin helper addon. That addon fetches ratings from various sources such as rotten tomatoes etc. Estuary will not do it, many mods etc out there do though
b0mb 36 Posted November 16, 2016 Author Posted November 16, 2016 Have you tried Titan for example? You need a skin that makes use of the skin helper addon. That addon fetches ratings from various sources such as rotten tomatoes etc. Estuary will not do it, many mods etc out there do though even Titan doesn´t show any ratings and i did not ever have this kind of problem before. Maybe there is something wrong with my system ...all infos are shown except ratings...
Angelblue05 4132 Posted November 16, 2016 Posted November 16, 2016 (edited) It won't work because rating depends on the imdb id which has not been updated for krypton. As I said, the rating system changed drastically. Sent from my iPhone using Tapatalk Edited November 16, 2016 by Angelblue05 1
b0mb 36 Posted December 26, 2016 Author Posted December 26, 2016 (edited) So is there any ETA now when Krypton is nearly final? [emoji3] Gesendet von meinem LG-D855 mit Tapatalk Edited December 26, 2016 by b0mb
CBers 7554 Posted December 26, 2016 Posted December 26, 2016 So is there any ETA now when Krypton is nearly final? [emoji3] It's still in beta. See here: https://kodi.tv/kodi-v17-krypton-the-last-beta-7/
sualfred 677 Posted December 27, 2016 Posted December 27, 2016 It is on GitHub -> RC will be released as official installer in January 1
b0mb 36 Posted December 27, 2016 Author Posted December 27, 2016 No.I don't think they will do anymore changes that would effect the ratings and most ppl are already running the latest beta of Krypton.... ;-) Gesendet von meinem LG-D855 mit Tapatalk
sualfred 677 Posted December 27, 2016 Posted December 27, 2016 (edited) The GitHub master is already v18 for a longer time and there is already a feature freeze for bigger changes since a few weeks. The last weeks were used for bugfixing and just and small backports of v18. Edited December 27, 2016 by sualfred
xnappo 1611 Posted December 27, 2016 Posted December 27, 2016 (edited) Feel free to check in the fix with proper support for older versions of Kodi then. I don't know how many times we have to say this - until it is at RC officially it is not officially supported. As you can tell it will only be a few more weeks until it is official. Please understand this from our point of view - we do this for free and if we start backing off on this policy it makes more work for us - and in particular @@Angelblue05 who gives better support than most for-pay software. xnappo Edited December 27, 2016 by xnappo 1
sualfred 677 Posted December 29, 2016 Posted December 29, 2016 (edited) Feel free to check in the fix with proper support for older versions of Kodi then. I don't know how many times we have to say this - until it is at RC officially it is not officially supported. As you can tell it will only be a few more weeks until it is official. Please understand this from our point of view - we do this for free and if we start backing off on this policy it makes more work for us - and in particular @@Angelblue05 who gives better support than most for-pay software. xnappo All I wanted was inform the others that RC is near Btw: RC1 is out, released today Have fun and take your time to bump the plugin to the "Krypton level" Edited December 29, 2016 by sualfred 1
im85288 1493 Posted December 29, 2016 Posted December 29, 2016 I actually started looking at this today, the video database has not changed for over 4 months so I think we can say it's stable now. Now I cannot see what the problem is though...inspecting my database in kodi myVideos107.db I see the rating and imdb number in the correct places. Looking here: http://kodi.wiki/view/databases#movie the correct fields seem to be populated. Which leaves the question as to what has actually changed?
sualfred 677 Posted December 29, 2016 Posted December 29, 2016 (edited) I actually started looking at this today, the video database has not changed for over 4 months so I think we can say it's stable now. Now I cannot see what the problem is though...inspecting my database in kodi myVideos107.db I see the rating and imdb number in the correct places. Looking here: http://kodi.wiki/view/databases#movie the correct fields seem to be populated. Which leaves the question as to what has actually changed? Checked my database. My "rating" table in myVideos107.db is completely empty. What has been changed: The feature "UserRatings" were added to videos/music/etc. I guess this has something to do with. Edited December 29, 2016 by sualfred
im85288 1493 Posted December 29, 2016 Posted December 29, 2016 Hmm I'll take another look...maybe this rating table is new for Kodi 17? If you look at the movie table you'll see the rating in c05 and the imdb number in c09
sualfred 677 Posted December 29, 2016 Posted December 29, 2016 Yep, you are right. The ratings are in c05 and c09. I've opened an old myVideos104.db (where Emby wasn't used) and the rating table is filled with data:
im85288 1493 Posted December 29, 2016 Posted December 29, 2016 Thanks for confirming, it does appear the rating table is new. I'll continue looking into the fix for that as it appears to need some extra mapping done
sualfred 677 Posted December 29, 2016 Posted December 29, 2016 No problem, but that table does not contain the IMDb number. Don't know what happened to this value in the new db.
im85288 1493 Posted December 29, 2016 Posted December 29, 2016 Yeah they've messed around big time, some "uniqueid" field has now appeared. The lack of an IMDb number is also effecting some of the skin helper widgets...what looked a quick fix is turning out to be a pita!
im85288 1493 Posted December 29, 2016 Posted December 29, 2016 Can you try and give this version a shot for movies? https://dl.dropboxusercontent.com/u/4689286/plugin.video.emby-2.3.26.zip I did put a new version in the beta repo but the repo is being slow for me today. This should work for movies...imdbnumber is still MIA though at the moment. If this works for others I'll look into expanding it for TV shows and then start looking at the ImdbNumber issue 1
