kanipek 230 Posted November 10, 2016 Posted November 10, 2016 I have 1 channel that are is displaying no guide data. Is there a method to fix this? It looks to me like the data is there for this channel in the cache->embytvepg folder It is mapped correctly and I see data for this same channel in other programs that use the same schedules direct account. I have re-mapped it (Channel 5.2) and it does pick up data when I re-map it to a different channel - right now it is mapped to channel 5 so WEWSDT3->WEWS Delete the cache and start over? Or? I have attached some files to see if that helps (renamed the .json file to .xml for upload) I see a lot of "schedules direct doesn't have data for..." in the log but I think that is because I have to map 90 percent of my channels cause the names don't match up. Thanks for reading any any help! hdhr_5.2_2247a47b5d8c6324837730bbb8980fda.xml server-63614361719.txt
Luke 42242 Posted November 23, 2016 Posted November 23, 2016 Continued here: https://emby.media/community/index.php?/topic/41310-incomplete-guide-data-live-tvdvr-schedules-direct
