Danee 57 Posted January 22, 2014 Posted January 22, 2014 (edited) Hello, I discovered an issue in the way ServerWMC handles the network path to the Recorded TV folder. I've setup a new system and only after I installed ServerWMC I saw that I didn't rename the system to it's desired name. After I renamed it I still saw the old name in the ServerWMC setting. Please see the attached log. Version: 1.0.0.21, build 1115 log.txt Edited January 22, 2014 by Danee
krustyreturns 191 Posted January 24, 2014 Posted January 24, 2014 Hi, Do you mean that after you changed the folder name, you didn't see the name in the settings file or where? Did you click the 'save' button after making the change?
Danee 57 Posted January 25, 2014 Author Posted January 25, 2014 Hello, No, I renamed my computer, it was called windows8test when I installed/first ran serverwmc. Then I renamed it to wmcserver. In the logfile the server machineName is showing the correct current name, but the network 'Recorded Tv' path: smbshows the old computer name. I fixed it by changing it in serverwmc so it works now.
krustyreturns 191 Posted January 25, 2014 Posted January 25, 2014 Ah, I see. Thanks. That is a bug, I will fix it.
