Problem installing emby Server on Synology
Hi,
    I tried to install Emby on my Synology ds215j with no luck. I'm on DSM 5.2-5967.
The package installs without errors from the Package Center, starts the process and stops with exit code 0
The logs are attached below.
Do I need to install other packages / configure something / give permissions before trying to install emby package ?
Thank you !
Diag synology_armada375_ds215j dsm 5.2-5967.txt
Install log - synology_armada375_ds215j dsm 5.2-5967.txt
Stderr - synology_armada375_ds215j dsm 5.2-5967.txt
Hi James,
Here is the reference :
sendlogs_Syno_synology_armada375_ds215j_20161107T205605UTC.tgz
Thank you,
Patrick
