Ekomax 14 Posted March 24, 2018 Posted March 24, 2018 @@Luke is this goinig to be done serverside, trailer plugin or client(ATV 4k)? I hope this is gettong fixed soon because i cant watch any trailer nor use cinema mode because of that buffering all the time. everything else works excellent. love emby best regards
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 Any update on the trailer plugin? Its unusable on all my clients because on that constand buffering. looks like the trailers arent getting downloaded fast enough. sorry for my bad english. best regards
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 Just tried. Same Problem. Best regards Gesendet von iPad mit Tapatalk
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 It doesnt work on iOS, tvOS. Trailers from the Plugin start. Then just stuck. Waiting for a while then it continues. Gesendet von iPad mit Tapatalk
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 Here you are, starting around 17:09 best regards
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 (edited) how ? can't seem to upload the log ? Edited March 28, 2018 by Ekomax
Luke 42255 Posted March 28, 2018 Posted March 28, 2018 Instructions are here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 (edited) Around 17:09 I started Edited March 28, 2018 by Ekomax
Luke 42255 Posted March 28, 2018 Posted March 28, 2018 What happens if you use the web app to browse the trailer channel and play something from there? please try that again. thanks.
Happy2Play 9814 Posted March 28, 2018 Posted March 28, 2018 I haven't seen any issues playing trailers provided by the trailer plugin from any device local or remote. Are all your devices wireless?
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 No. just iPhone and iPad. Atv4k is wired. My Synology DS216+II as well. Network cant be the Problem because multiple high bitrate movies direkt play fine. best regards
Ekomax 14 Posted March 28, 2018 Posted March 28, 2018 tomorrow after work ok? its late today in austria. thanks for your help. @@Luke you know whats the problem? best regards
Luke 42255 Posted March 28, 2018 Posted March 28, 2018 I pushed updates to trailers reducing the quality of the versions we're using. Your logs seem to indicate you might not have gotten those updates. Yes please provide the ffmpeg log tomorrow. thanks.
WalBob 9 Posted March 28, 2018 Posted March 28, 2018 Thanks for the updates. All seems to be working fine for me now... no more buffering :-)
mentasm 43 Posted March 29, 2018 Posted March 29, 2018 I was using trailers last night in ET and for the first time in ages I had no buffering.
