lance321 2 Posted November 7, 2016 Posted November 7, 2016 Hello, I am having issues with stuttering and slow playback (constant pausing and buffering) when any Emby trailers are playing. Otherwise this plugin appears to be working correctly. I also confirmed the trailers stutter in both the Emby web-browser on my media center, and via the Emby Theater app. I can find no recent posts on this issue, last I see is from 2014 on another version of Emby. I am running Emby Server version: 3.0.85, and the current version of Emby Theater. I have no special setups or customization, only one plugin installed "Trailers". My internet is plenty fast at 90 Mbps (Speedtest.net). I can stream HD content on Youtube or Netflix just fine etc. Hardware should be fine, my media center is running a Core i5-4690K w/ 16 Gig of RAM, and a Nvidia video card. So there are no hardware bottlenecks. All drivers up to date. OS is WIn 7. The only playback I have had any issues with is the Trailers plugin. Is there a way to turn down the trailers quality, or whatever may be causing the buffering in Emby? I can find no way to do this on the current version. Many thanks for any assistance! 1
Happy2Play 9814 Posted November 7, 2016 Posted November 7, 2016 You would need to post a server log after you experience this issue. All the trailers I just tested, direct streamed without any issue.
lance321 2 Posted April 14, 2017 Author Posted April 14, 2017 Sorry about the late reply. I thought I was subscribed to this thread but missed the notification. Since this original post I have updated Emby Server and Theater. I noticed after that things ran a little smoother. Trailers when played once, appears to cache (someplace) because then they play again fine later before any main movie features. But I have still had trailers buffering. I just tried the trailers again, and I cannot fully test this because I do have a slower Internet connection at the moment. I am staying at a temporary location for a couple months and will have a slower WiFi connection. The trailers may currently be cutting out due to the slow Internet. However I will be back home within a couple months, back on Ethernet, and high speed broadband. So I can retest then. I will attach my log reports. Trailers Version: 1.0.6150.25153 Emby Server: Version 3.2.12.0 Emby Theater: 2.5.40 System Specs: CPU: i5-4690K RAM: 16GB Video: GTX 1080
lance321 2 Posted April 14, 2017 Author Posted April 14, 2017 Here is a server log. I have a lot of logs, so if you want others let me know. 2017-04-13 21:46:10.5170 Info Main: Emby Command line: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Bonaparte\AppData\Roaming\Emby-Server Application directory: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system 2017-04-13 21:46:10.6430 Info ImageMagick: ImageMagick version: ImageMagick 6.9.2-7 Q8 x64 2015-11-28 http://www.imagemagick.org 2017-04-13 21:46:10.8200 Info App: Application version: 3.2.12.0 2017-04-13 21:46:10.8880 Info App: Application configuration: {"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableSeriesPresentationUniqueKey":true,"EnableLocalizedGuids":true,"EnableNormalizedItemByNameIds":false,"IsPortAuthorized":true,"EnableCaseSensitiveItemIds":true,"SeasonZeroDisplayName":"Specials","PreferredMetadataLanguage":"en","MetadataCountryCode":"US","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"LibraryMonitorDelay":60,"EnableDashboardResponseCaching":true,"DashboardSourcePath":"","ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Logo","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"BoxSet","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Thumb","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":["The Open Movie Database","TheMovieDb"],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Primary","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":["The Open Movie Database","TheMovieDb"],"MetadataFetcherOrder":[],"DisabledImageFetchers":["TheMovieDb"],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"SkipDeserializationForBasicTypes":false,"SkipDeserializationForPrograms":false,"SkipDeserializationForAudio":false,"ServerName":"","UICulture":"en-us","SaveMetadataHidden":false,"ContentTypes":[],"RemoteClientBitrateLimit":0,"SharingExpirationDays":30,"SchemaVersion":109,"EnableAnonymousUsageReporting":true,"EnableStandaloneMusicKeys":true,"EnableFolderView":false,"EnableGroupingIntoCollections":false,"DisplaySpecialsWithinSeasons":true,"DisplayCollectionsView":false,"LocalNetworkAddresses":[],"CodecsUsed":["libmp3lame","libx264","copy","aac -strict experimental"],"Migrations":["MediaBrowser.Server.Startup.Common.Migrations.OmdbEpisodeProviderMigration","MediaBrowser.Server.Startup.Common.Migrations.MovieDbEpisodeProviderMigration","FolderViewSettingMigration","CollectionGroupingMigration","CollectionsViewMigration","LibraryScan6","GuideRefresh2","GuideRefresh3"],"EnableChannelView":false,"EnableExternalContentInSuggestions":true,"ImageExtractionTimeoutMs":0,"PathSubstitutions":[],"EnableSimpleArtistDetection":true,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":true,"IsStartupWizardCompleted":true,"CachePath":""} 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.Plugins.Anime, Version=1.1.6035.25335, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.Plugins.Trailers, Version=1.0.6150.25153, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.Api, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.WebDashboard, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.Model, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.Common, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.Controller, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.Providers, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Photos, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Common.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Server.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.MediaEncoding, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.LocalMetadata, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading MediaBrowser.ServerApplication, Version=3.2.12.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:10.9110 Info App: Loading Emby.Server.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-04-13 21:46:11.0640 Info SqliteUserRepository: Sqlite version: 3.18.0 2017-04-13 21:46:11.0640 Info SqliteUserRepository: Sqlite compiler options: COMPILER=msvc-1500,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_SYNCHRONOUS=2,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1 2017-04-13 21:46:11.0870 Info SqliteUserRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\users.db is wal 2017-04-13 21:46:11.0870 Info SqliteUserRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.0870 Info SqliteFileOrganizationRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\fileorganization.db is wal 2017-04-13 21:46:11.0870 Info SqliteFileOrganizationRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.0870 Info AuthenticationRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\authentication.db is wal 2017-04-13 21:46:11.0870 Info AuthenticationRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.1760 Info ImageProcessor: ImageProcessor started with 4 max concurrent image processes 2017-04-13 21:46:11.1930 Info SharingRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\shares.db is wal 2017-04-13 21:46:11.1930 Info SharingRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.1930 Info ActivityRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\activitylog.db is wal 2017-04-13 21:46:11.1930 Info ActivityRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.1930 Info SqliteDisplayPreferencesRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\displaypreferences.db is wal 2017-04-13 21:46:11.1930 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.1980 Info SqliteItemRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\library.db is wal 2017-04-13 21:46:11.1980 Info SqliteItemRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.1980 Info SqliteNotificationsRepository: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\notifications.db is wal 2017-04-13 21:46:11.1980 Info SqliteNotificationsRepository: PRAGMA synchronous=1 2017-04-13 21:46:11.3740 Error App: Error creating MediaBrowser.Plugins.Anime.Plugin *** Error Report *** Version: 3.2.12.0 Command line: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Bonaparte\AppData\Roaming\Emby-Server Application directory: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system SimpleInjector.ActivationException: No registration for type Plugin could be found and an implicit registration could not be made. One or more errors occurred. ---> System.AggregateException: One or more errors occurred. ---> System.InvalidOperationException: There is an error in XML document (0, 0). ---> System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderAnimelist.Read9_animelist() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream) at AnimeLists.Downloader.<Download>d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at MediaBrowser.Plugins.Anime.Providers.AniDB.Converter.AnidbConverter..ctor(IApplicationPaths paths) at MediaBrowser.Plugins.Anime.Plugin..ctor(IApplicationPaths applicationPaths, IXmlSerializer xmlSerializer, ILogger logger) at lambda_method(Closure ) at SimpleInjector.InstanceProducer.BuildAndReplaceInstanceCreatorAndCreateFirstInstance() at SimpleInjector.InstanceProducer.GetInstance() --- End of inner exception stack trace --- at SimpleInjector.InstanceProducer.GetInstance() at SimpleInjector.Container.GetInstanceForRootType(Type serviceType) at SimpleInjector.Container.GetInstance(Type serviceType) at Emby.Common.Implementations.BaseApplicationHost`1.CreateInstanceSafe(Type type) SimpleInjector.ActivationException at SimpleInjector.InstanceProducer.GetInstance() at SimpleInjector.Container.GetInstanceForRootType(Type serviceType) at SimpleInjector.Container.GetInstance(Type serviceType) at Emby.Common.Implementations.BaseApplicationHost`1.CreateInstanceSafe(Type type) InnerException: System.AggregateException System.AggregateException: One or more errors occurred. ---> System.InvalidOperationException: There is an error in XML document (0, 0). ---> System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderAnimelist.Read9_animelist() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream) at AnimeLists.Downloader.<Download>d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at MediaBrowser.Plugins.Anime.Providers.AniDB.Converter.AnidbConverter..ctor(IApplicationPaths paths) at MediaBrowser.Plugins.Anime.Plugin..ctor(IApplicationPaths applicationPaths, IXmlSerializer xmlSerializer, ILogger logger) at lambda_method(Closure ) at SimpleInjector.InstanceProducer.BuildAndReplaceInstanceCreatorAndCreateFirstInstance() at SimpleInjector.InstanceProducer.GetInstance() ---> (Inner Exception #0) System.InvalidOperationException: There is an error in XML document (0, 0). ---> System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderAnimelist.Read9_animelist() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream) at AnimeLists.Downloader.<Download>d__3.MoveNext()<--- at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at MediaBrowser.Plugins.Anime.Providers.AniDB.Converter.AnidbConverter..ctor(IApplicationPaths paths) at MediaBrowser.Plugins.Anime.Plugin..ctor(IApplicationPaths applicationPaths, IXmlSerializer xmlSerializer, ILogger logger) at lambda_method(Closure ) at SimpleInjector.InstanceProducer.BuildAndReplaceInstanceCreatorAndCreateFirstInstance() at SimpleInjector.InstanceProducer.GetInstance() InnerException: System.InvalidOperationException System.InvalidOperationException: There is an error in XML document (0, 0). ---> System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderAnimelist.Read9_animelist() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream) at AnimeLists.Downloader.<Download>d__3.MoveNext() at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream) at AnimeLists.Downloader.<Download>d__3.MoveNext() InnerException: System.Xml.XmlException System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderAnimelist.Read9_animelist() at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderAnimelist.Read9_animelist() 2017-04-13 21:46:11.4441 Info HttpServer: Calling ServiceStack AppHost.Init 2017-04-13 21:46:11.9921 Info ServerManager: Loading Http Server 2017-04-13 21:46:11.9921 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2017-04-13 21:46:11.9921 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2017-04-13 21:46:12.0781 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:12.0851 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:12.0851 Info HttpServer: HTTP Response 503 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:12.0851 Info HttpServer: HTTP Response 503 to 127.0.0.1. Time: 16ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:12.2161 Info HttpClient: HttpClientManager GET: https://api.github.com/repos/MediaBrowser/Emby/releases 2017-04-13 21:46:12.7231 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:12.7231 Info HttpServer: HTTP Response 503 to 127.0.0.1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:12.7251 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:12.7251 Info HttpServer: HTTP Response 503 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:13.4142 Info TaskManager: Daily trigger for Start new log file set to fire at 4/14/2017 12:00:00 AM, which is 133.776463061667 minutes from now. 2017-04-13 21:46:13.4142 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 4/14/2017 2:00:00 AM, which is 253.776413058333 minutes from now. 2017-04-13 21:46:13.4362 Info MediaEncoder: FFMpeg: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe 2017-04-13 21:46:13.4362 Info MediaEncoder: FFProbe: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffprobe.exe 2017-04-13 21:46:13.4362 Info MediaEncoder: Validating media encoder at C:\Users\Bonaparte\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe 2017-04-13 21:46:13.4362 Info MediaEncoder: Running C:\Users\Bonaparte\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -decoders 2017-04-13 21:46:13.4512 Info MediaEncoder: Decoder available: mpeg2video 2017-04-13 21:46:13.4512 Info MediaEncoder: Decoder available: h264_qsv 2017-04-13 21:46:13.4512 Info MediaEncoder: Decoder available: hevc_qsv 2017-04-13 21:46:13.4512 Info MediaEncoder: Decoder available: mpeg2_qsv 2017-04-13 21:46:13.4512 Info MediaEncoder: Decoder available: vc1_qsv 2017-04-13 21:46:13.4512 Info MediaEncoder: Running C:\Users\Bonaparte\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -encoders 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: libx264 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: libx265 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: mpeg4 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: msmpeg4 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: libvpx 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: libvpx-vp9 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: aac 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: libmp3lame 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: libopus 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: libvorbis 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: srt 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: h264_qsv 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder available: hevc_qsv 2017-04-13 21:46:13.4642 Info MediaEncoder: Encoder validation complete 2017-04-13 21:46:13.4642 Info App: ServerId: 6dd34c8286434feb9001d86351a94b8f 2017-04-13 21:46:13.4642 Info App: Core startup complete 2017-04-13 21:46:13.4642 Info App: Post-init migrations complete 2017-04-13 21:46:13.5002 Info App: Starting entry point MediaBrowser.Plugins.Trailers.EntryPoint 2017-04-13 21:46:13.5052 Info App: Entry point completed: MediaBrowser.Plugins.Trailers.EntryPoint. Duration: 0.0050003 seconds 2017-04-13 21:46:13.5052 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2017-04-13 21:46:13.5052 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 0.0010001 seconds 2017-04-13 21:46:13.5052 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2017-04-13 21:46:13.5052 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.001 seconds 2017-04-13 21:46:13.5052 Info App: Starting entry point Emby.Server.Implementations.TV.CleanMissingEpisodesEntryPoint 2017-04-13 21:46:13.5052 Info App: Entry point completed: Emby.Server.Implementations.TV.CleanMissingEpisodesEntryPoint. Duration: 0 seconds 2017-04-13 21:46:13.5052 Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications 2017-04-13 21:46:13.5052 Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.0030002 seconds 2017-04-13 21:46:13.5052 Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier 2017-04-13 21:46:13.5052 Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0010001 seconds 2017-04-13 21:46:13.5052 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2017-04-13 21:46:13.5052 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0 seconds 2017-04-13 21:46:13.5052 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2017-04-13 21:46:13.5052 Info App: Loading live tv data from C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\livetv\timers 2017-04-13 21:46:13.5932 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.0820046 seconds 2017-04-13 21:46:13.5932 Info App: Starting entry point Emby.Server.Implementations.FileOrganization.FileOrganizationNotifier 2017-04-13 21:46:13.5932 Info App: Entry point completed: Emby.Server.Implementations.FileOrganization.FileOrganizationNotifier. Duration: 0.0010001 seconds 2017-04-13 21:46:13.5932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2017-04-13 21:46:13.5932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0010001 seconds 2017-04-13 21:46:13.5932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2017-04-13 21:46:13.5932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0 seconds 2017-04-13 21:46:13.5932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2017-04-13 21:46:13.5932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.001 seconds 2017-04-13 21:46:13.5932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LoadRegistrations 2017-04-13 21:46:13.5932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LoadRegistrations. Duration: 0 seconds 2017-04-13 21:46:13.5932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2017-04-13 21:46:13.5932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0010001 seconds 2017-04-13 21:46:13.5932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RefreshUsersMetadata 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RefreshUsersMetadata. Duration: 0.0960055 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0020001 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0020001 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0020001 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2017-04-13 21:46:13.6932 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0020001 seconds 2017-04-13 21:46:13.6932 Info App: Starting entry point Emby.Server.Core.IO.LibraryMonitorStartup 2017-04-13 21:46:13.7232 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:13.7232 Info App: Entry point completed: Emby.Server.Core.IO.LibraryMonitorStartup. Duration: 0.0250015 seconds 2017-04-13 21:46:13.7232 Info App: Starting entry point Emby.Server.Core.EntryPoints.ExternalPortForwarding 2017-04-13 21:46:13.7232 Info LibraryMonitor: Watching directory F:\Movies\MediaCenter-3D_Videos 2017-04-13 21:46:13.7232 Info LibraryMonitor: Watching directory F:\Movies\MediaCenter-Music_Videos 2017-04-13 21:46:13.7232 Info LibraryMonitor: Watching directory F:\Movies\MediaCenter-Movie_Files 2017-04-13 21:46:13.7232 Info LibraryMonitor: Watching directory F:\Movies\MediaCenter-TVShows 2017-04-13 21:46:13.7532 Info App: Entry point completed: Emby.Server.Core.EntryPoints.ExternalPortForwarding. Duration: 0.0270015 seconds 2017-04-13 21:46:13.7532 Info App: Starting entry point Emby.Dlna.DlnaProfileEntryPoint 2017-04-13 21:46:13.7532 Info App: Entry point completed: Emby.Dlna.DlnaProfileEntryPoint. Duration: 0 seconds 2017-04-13 21:46:13.7532 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2017-04-13 21:46:13.7682 Info App: App Activity: app: Emby Mobile, version: 3.2.12.0, deviceId: dbbf22ca4678873df3976b0df4596419252a96c0, deviceName: Chrome 2017-04-13 21:46:13.8842 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.1310075 seconds 2017-04-13 21:46:13.8842 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2017-04-13 21:46:13.8842 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.001 seconds 2017-04-13 21:46:13.8842 Info App: Starting entry point Emby.Security.PluginSecurityManager 2017-04-13 21:46:13.8842 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0 seconds 2017-04-13 21:46:13.8842 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2017-04-13 21:46:13.8842 Info App: Loading data from C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\connect.txt 2017-04-13 21:46:13.8842 Info App: Loading data from C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\wan.dat 2017-04-13 21:46:13.8982 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0130008 seconds 2017-04-13 21:46:13.8982 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2017-04-13 21:46:13.8982 Info App: Sqlite version: 3.18.0 2017-04-13 21:46:13.8982 Info App: Sqlite compiler options: COMPILER=msvc-1500,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_SYNCHRONOUS=2,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1 2017-04-13 21:46:13.8982 Info App: Default journal_mode for C:\Users\Bonaparte\AppData\Roaming\Emby-Server\data\sync14.db is wal 2017-04-13 21:46:13.8982 Info App: PRAGMA synchronous=1 2017-04-13 21:46:13.8982 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0060003 seconds 2017-04-13 21:46:13.8982 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2017-04-13 21:46:13.8982 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0 seconds 2017-04-13 21:46:13.8982 Info App: Starting entry point Emby.Security.PluginSecurityManager 2017-04-13 21:46:13.8982 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0 seconds 2017-04-13 21:46:13.8982 Info App: Starting entry point Emby.Server.Core.IO.LibraryMonitorStartup 2017-04-13 21:46:13.8982 Info App: Entry point completed: Emby.Server.Core.IO.LibraryMonitorStartup. Duration: 0.0030002 seconds 2017-04-13 21:46:13.8982 Info App: Starting entry point Emby.Server.Core.EntryPoints.ExternalPortForwarding 2017-04-13 21:46:13.8982 Info App: Entry point completed: Emby.Server.Core.EntryPoints.ExternalPortForwarding. Duration: 0 seconds 2017-04-13 21:46:13.8982 Info App: All entry points have started 2017-04-13 21:46:13.8982 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.2.55 2017-04-13 21:46:13.9692 Info HttpServer: HTTP Response 200 to ::1. Time: 246ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:14.0222 Info HttpClient: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2017-04-13 21:46:14.0562 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=b505d44a2504a1f301a79154b660b413 2017-04-13 21:46:14.4142 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=b505d44a2504a1f301a79154b660b413 2017-04-13 21:46:14.7232 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:14.7232 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:14.7232 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:14.7232 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:16.4233 Info TaskManager: StartupTrigger fired for task: Check for application updates 2017-04-13 21:46:16.4233 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2017-04-13 21:46:16.4233 Info TaskManager: Queueing task PluginUpdateTask 2017-04-13 21:46:16.4233 Info TaskManager: Queueing task SystemUpdateTask 2017-04-13 21:46:16.4233 Info TaskManager: Executing Check for plugin updates 2017-04-13 21:46:16.4233 Info TaskManager: Executing Check for application updates 2017-04-13 21:46:16.4233 Info InstallationManager: Opening C:\Users\Bonaparte\AppData\Roaming\Emby-Server\cache\serverpackages.json 2017-04-13 21:46:16.4233 Info HttpClient: Checking for cache file C:\Users\Bonaparte\AppData\Roaming\Emby-Server\cache\httpclient\f70ca6622474da8168a3b6c06f651a16 2017-04-13 21:46:16.4433 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2017-04-13 21:46:16.4553 Info TaskManager: ExecuteQueuedTasks 2017-04-13 21:46:16.4923 Info HttpClient: HttpClientManager.GetTempFileResponse url: https://www.mb3admin.com/admin/service/MB3Packages.json 2017-04-13 21:46:16.4923 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2017-04-13 21:46:16.4923 Info TaskManager: ExecuteQueuedTasks 2017-04-13 21:46:17.7234 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:17.7234 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:17.7234 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:17.7234 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:18.7235 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:18.7235 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:18.8625 Info HttpClient: HttpClientManager POST: http://192.168.2.1:1780 2017-04-13 21:46:18.8625 Info HttpClient: HttpClientManager POST: http://192.168.2.1:1780 2017-04-13 21:46:18.8625 Error HttpClient: Error getting response from http://192.168.2.1:1780 *** Error Report *** Version: 3.2.12.0 Command line: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Bonaparte\AppData\Roaming\Emby-Server Application directory: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__22.MoveNext() ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)<--- System.AggregateException at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__22.MoveNext() InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2017-04-13 21:46:18.8625 Error PortMapper: Error creating port map: One or more errors occurred. 2017-04-13 21:46:18.8625 Error HttpClient: Error getting response from http://192.168.2.1:1780 *** Error Report *** Version: 3.2.12.0 Command line: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Bonaparte\AppData\Roaming\Emby-Server Application directory: C:\Users\Bonaparte\AppData\Roaming\Emby-Server\system System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__22.MoveNext() ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)<--- System.AggregateException at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__22.MoveNext() InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2017-04-13 21:46:18.8625 Error PortMapper: Error creating port map: One or more errors occurred. 2017-04-13 21:46:18.9065 Info HttpClient: HttpClientManager GET: http://bot.whatismyipaddress.com 2017-04-13 21:46:19.1115 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=b505d44a2504a1f301a79154b660b413 2017-04-13 21:46:19.2575 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=b505d44a2504a1f301a79154b660b413 2017-04-13 21:46:19.7225 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:19.7225 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:19.7225 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:19.7225 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:22.7217 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:22.7217 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:22.7217 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:22.7247 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:23.7228 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:23.7228 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:24.7228 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:24.7228 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:24.7228 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:24.7228 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:27.7230 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:27.7230 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:27.7230 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:27.7230 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:28.7220 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:28.7220 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:29.7221 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:29.7221 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:29.7221 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:29.7221 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:32.7233 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:32.7243 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:32.7243 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:32.7243 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:33.7233 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:33.7233 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:34.7244 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:34.7244 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:34.7244 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:34.7244 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:37.7226 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:37.7226 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:37.7226 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:37.7226 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:38.7226 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:38.7226 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:39.7227 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:39.7227 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:39.7227 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:39.7227 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:42.7238 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:42.7238 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:42.7238 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:42.7238 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:43.7239 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:43.7239 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:44.7240 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:44.7240 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:44.7240 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:44.7240 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:47.7231 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:47.7231 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:47.7231 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:47.7231 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:48.7222 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:48.7222 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:49.7222 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:49.7222 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:49.7222 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:49.7222 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:52.7234 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:52.7234 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:52.7234 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:52.7234 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:53.7235 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:53.7235 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:54.7225 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:54.7225 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:54.7225 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:54.7225 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:57.7237 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:57.7237 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:57.7237 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:57.7237 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:58.7228 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:58.7228 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:59.7228 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:59.7228 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:46:59.7228 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:46:59.7278 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:02.7240 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:02.7240 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:02.7240 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:02.7240 Info HttpServer: HTTP Response 200 to ::1. Time: 0ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:03.7230 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:03.7230 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:04.7231 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:04.7231 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:04.7231 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:04.7231 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:07.7233 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:07.7233 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:07.7233 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:07.7233 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:08.7243 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 2017-04-13 21:47:08.7243 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2017-04-13 21:47:09.4684 Info HttpServer: HTTP POST http://localhost:8096/mediabrowser/System/Shutdown. UserAgent: 2017-04-13 21:47:09.4684 Info HttpServer: HTTP Response 204 to ::1. Time: 1ms. http://localhost:8096/mediabrowser/System/Shutdown 2017-04-13 21:47:09.5724 Info Main: Disposing app host 2017-04-13 21:47:09.5724 Info App: Disposing WindowsAppHost 2017-04-13 21:47:09.5724 Info App: Disposing TaskManager 2017-04-13 21:47:09.5724 Info App: Disposing HttpClientManager 2017-04-13 21:47:09.5724 Info App: Disposing IsoManager 2017-04-13 21:47:09.5724 Info App: Disposing InstallationManager 2017-04-13 21:47:09.5724 Info App: Disposing SqliteUserRepository 2017-04-13 21:47:09.5724 Info App: Disposing SqliteDisplayPreferencesRepository 2017-04-13 21:47:09.5724 Info App: Disposing SqliteItemRepository 2017-04-13 21:47:09.5724 Info App: Disposing SqliteFileOrganizationRepository 2017-04-13 21:47:09.5724 Info App: Disposing AuthenticationRepository 2017-04-13 21:47:09.5724 Info App: Disposing LibraryMonitor 2017-04-13 21:47:09.5724 Info App: Disposing ProviderManager 2017-04-13 21:47:09.5724 Info App: Disposing ServerManager 2017-04-13 21:47:09.5724 Info ServerManager: Disposing web socket connections 2017-04-13 21:47:09.5724 Info ServerManager: Disposing http server 2017-04-13 21:47:09.5724 Info HttpServer: Stopping HttpListener... 2017-04-13 21:47:09.5724 Info HttpServer: HttpListener stopped 2017-04-13 21:47:09.5724 Info App: Disposing ImageProcessor 2017-04-13 21:47:09.5724 Info App: Disposing MediaSourceManager 2017-04-13 21:47:09.5724 Info App: Disposing LiveTvManager 2017-04-13 21:47:09.5724 Info App: Disposing ContentDirectory 2017-04-13 21:47:09.5724 Info App: Disposing MediaReceiverRegistrar 2017-04-13 21:47:09.5724 Info App: Disposing MediaEncoder 2017-04-13 21:47:09.5724 Info App: Disposing SharingRepository 2017-04-13 21:47:09.5724 Info App: Disposing ActivityRepository 2017-04-13 21:47:09.5724 Info App: Disposing SqliteNotificationsRepository 2017-04-13 21:47:09.5724 Info App: Disposing MovieDbProvider 2017-04-13 21:47:09.5724 Info App: Disposing EmbyTV 2017-04-13 21:47:09.5874 Info App: Disposing OpenSubtitleDownloader 2017-04-13 21:47:09.5874 Info App: Disposing EntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing ApiEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing ServerEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing CleanMissingEpisodesEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing Notifications 2017-04-13 21:47:09.5874 Info App: Disposing WebSocketNotifier 2017-04-13 21:47:09.5874 Info App: Disposing NewsEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing EntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing FileOrganizationNotifier 2017-04-13 21:47:09.5874 Info App: Disposing AutomaticRestartEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing KeepServerAwake 2017-04-13 21:47:09.5874 Info App: Disposing LibraryChangedNotifier 2017-04-13 21:47:09.5874 Info App: Disposing LoadRegistrations 2017-04-13 21:47:09.5874 Info App: Disposing RecordingNotifier 2017-04-13 21:47:09.5874 Info App: Disposing RefreshUsersMetadata 2017-04-13 21:47:09.5874 Info App: Disposing ServerEventNotifier 2017-04-13 21:47:09.5874 Info App: Disposing StartupWizard 2017-04-13 21:47:09.5874 Info App: Disposing SystemEvents 2017-04-13 21:47:09.5874 Info App: Disposing UdpServerEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing UsageEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing UserDataChangeNotifier 2017-04-13 21:47:09.5874 Info App: Disposing ActivityLogEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing LibraryMonitorStartup 2017-04-13 21:47:09.5874 Info App: Disposing ExternalPortForwarding 2017-04-13 21:47:09.5874 Info App: Disposing DlnaProfileEntryPoint 2017-04-13 21:47:09.5874 Info App: Disposing DlnaEntryPoint
chiksilog 1 Posted July 15, 2017 Posted July 15, 2017 Has this been resolved? I'm also having the same problem with Trailers stuttering and buffering constantly Emby for WMC: Constant stuttering and buffering Via browser on the same PC where Emby for WMC is installed: Works fine Emby for Android: Works fine 1
Luke 42255 Posted July 15, 2017 Posted July 15, 2017 Please try again with the next release of Emby Server. Thanks !
chiksilog 1 Posted July 16, 2017 Posted July 16, 2017 Please try again with the next release of Emby Server. Thanks ! Ok I will wait for the next release to be available and report back. Thanks
edward1987 1 Posted November 24, 2017 Posted November 24, 2017 i have the same problem. I have FULL GB internet connection on fiber so , no problem there.
Luke 42255 Posted November 25, 2017 Posted November 25, 2017 @@edward1987, please attach the information requested in how to report a media playback issue. thanks !
edward1987 1 Posted November 25, 2017 Posted November 25, 2017 i do not have a problem with emby media , media from my library is working fine, my problem is when i enable cinema mode trailers are buffering every 5 - 10 seconds so that is not good. i think the server from where i get trailers have connection or load problems. I watch log files about this and there is nothing in the logs. i will enable debuging and try again to se if there is any problem there. In rest transconding , downloading , playing video from my local library no problem. So , emby is not the problem here is cinema mode with trailer plugin. Not all trailers make buffering , but most of them do. 1
vferg 7 Posted January 15, 2018 Posted January 15, 2018 Sorry not at home right now so I dont have any logs at the moment but just wanted to say that the trailers have been doing this to me as well for the last 3 months or so and finally decided to see if I can find anything out that may be going on. Trailers ONLY stutter anywhere from 10-30 seconds in and is basically unwatchable after that until I hit next. My content plays fine though. I am running Emby on Synology. This effects every user and doesnt seem to matter what device or application is used to play the content which is what leads me to believe its also an issue with the source of where the trailers are pulled from? There dont appear to be any settings to change so I couldnt really try anything out either. Just wanted to add another say into this since it doesnt appear I am the only one experiencing the same issues as others here. If you believe logs are needed I can post later or tomorrow when I get a minute. Thanks
vferg 7 Posted January 15, 2018 Posted January 15, 2018 I also just saw that there may have been an update in early December judjing from another post about getting it updated. If so this may be around when the issues started for me. Obviously not sure if that was the cause at all but it does seem to match up with the approx time I started seeing the buffering issues. Thanks again
Luke 42255 Posted January 19, 2018 Posted January 19, 2018 Yea some of the trailers are just really high bitrate and I think that is the issue. We can look into using lower quality versions.
screwfaze 38 Posted February 24, 2018 Posted February 24, 2018 Hi, I have also got this problem with trailers stuttering, is there a fix for this or can the trailers be transcoded maybe?
Luke 42255 Posted February 24, 2018 Posted February 24, 2018 I suppose forcing a transcode is possible.
WalBob 9 Posted February 26, 2018 Posted February 26, 2018 I have this issue also and it would appear to be specific to the Trailer Source. The problem for me is only with "trailers from new and upcoming movies". Trailers from "new and upcoming movies on Dvd & Blu-ray" and "new and upcoming movies on Netflix" work fine. The issue manifests in both Emby for WMC and Emby Theater and the Web Client (Chrome) (all versions including plugins are current). A clean install did not resolve the issue for me. The issue is buffering during the initial streaming of the Trailer. Re-playing the trailer a 2nd time results in no issue as it has presumably cached locally at that point. I have had to exclude "Trailers from new and upcoming movies" as a work-around for Cinema Mode to function without stuttering. Hope this helps.....??
screwfaze 38 Posted March 21, 2018 Posted March 21, 2018 So will it be possible to transcode trailers or choose lower quality ones? Thanks
Ekomax 14 Posted March 22, 2018 Posted March 22, 2018 same here. Trailer puffer every 10 sec. ATV 4k best regards
Luke 42255 Posted March 22, 2018 Posted March 22, 2018 I think we will just have to switch those to lower resolution versions because the bitrates are very high. Thanks.
