wingatesl 3 Posted November 16, 2016 Posted November 16, 2016 In the official Roku app, the connection timeout should be set at line 198 of VideoPlayer.brs
dboyer 0 Posted November 17, 2016 Posted November 17, 2016 You have to change the source of the Blue Neon Night application. In the VideoPlayer.brs file, line 192 is currently blank, and just after player.SetPositionNotificationPeriod(1). Adding player.SetConnectionTimeout(30) in that spot will extend the timeout period for starting the stream. You then sideload the app. I have attached a modified version here that you can sideload using the developer page. I sideloaded the BNN.zip file. Yea, we are now able to see Live TV. Thanks very much, wingatesl
dmcneil 0 Posted November 17, 2016 Posted November 17, 2016 Nice work everyone. Hoping for a fix soon. Sent from my iPhone using Tapatalk
Vitale4 15 Posted November 17, 2016 Posted November 17, 2016 You have to change the source of the Blue Neon Night application. In the VideoPlayer.brs file, line 192 is currently blank, and just after player.SetPositionNotificationPeriod(1). Adding player.SetConnectionTimeout(30) in that spot will extend the timeout period for starting the stream. You then sideload the app. I have attached a modified version here that you can sideload using the developer page. wingatesl, thanks for the zip file. did the side load and like others it worked like a champ. great work.
Allenjs5 3 Posted November 17, 2016 Posted November 17, 2016 I successfully sideloaded the zip file above, and live TV is restored for me as well. Thank you guys all so much!
drewtlo 0 Posted November 17, 2016 Posted November 17, 2016 You have to change the source of the Blue Neon Night application. In the VideoPlayer.brs file, line 192 is currently blank, and just after player.SetPositionNotificationPeriod(1). Adding player.SetConnectionTimeout(30) in that spot will extend the timeout period for starting the stream. You then sideload the app. I have attached a modified version here that you can sideload using the developer page. I uploaded this last night and playback is working on our Roku 3 again! Thank you!
ebr 16335 Posted November 17, 2016 Posted November 17, 2016 FYI guys - we have submitted an update to the app with this workaround. However, they have a very large backlog right now plus they take most of next week off so it could be a bit before it makes it to the public. We'll see. It is also possible that Roku will fix it on their end before our update makes it out. I bought a new Roku just a couple days ago and it is not updating to 7.5. That tells me that they may have pulled the firmware update until they can fix this problem. 1
Happy2Play 9811 Posted November 19, 2016 Posted November 19, 2016 FYI guys - we have submitted an update to the app with this workaround. However, they have a very large backlog right now plus they take most of next week off so it could be a bit before it makes it to the public. We'll see. It is also possible that Roku will fix it on their end before our update makes it out. I bought a new Roku just a couple days ago and it is not updating to 7.5. That tells me that they may have pulled the firmware update until they can fix this problem. I think they have a staged rollout. I just got the update yesterday just like mediacowboy. Same version as everyone else 7.5 4096.
ebr 16335 Posted November 19, 2016 Posted November 19, 2016 Yeah, it appears my hopes were in vain. They are continuing to roll out 7.5 warts and all .
ebr 16335 Posted November 19, 2016 Posted November 19, 2016 I just read on their forums that 7.5.4099 is going to fix this. 1
Solution ray2357 2 Posted November 20, 2016 Solution Posted November 20, 2016 I just checked one of my Streaming Sticks that is on 7.5 and was not working. It has updated to 7.5.0 build 4099-24 and live is now working 2
dboyer 0 Posted November 20, 2016 Posted November 20, 2016 I just checked one of my Streaming Sticks that is on 7.5 and was not working. It has updated to 7.5.0 build 4099-24 and live is now working I wish Roku had some way to force an upgrade to 7.5.0 build 4099. In our Roku 3600X sticks, I go over to the Software Upgrade page a couple of times a day, to no avail.
chizz44 9 Posted November 20, 2016 Posted November 20, 2016 I have a Roku TV, and I just stumbled across this forum post today - rollback to 7.2 from 7.5 worked for me. Hopefully when it auto updates again it will go to the 7.5 4099-24. I'll post here when it does. Thanks to you guys for the troubleshooting you did, this was driving me nuts!
Happy2Play 9811 Posted November 20, 2016 Posted November 20, 2016 Since this is still being reported, did the update to the app not correct this issue? Or was that update to v2.25 only the beta channel? @@JohnsLibrary what Roku firmware and app version are you using?
Luke 42243 Posted November 21, 2016 Posted November 21, 2016 The app update is to the beta channel. We have submitted for the public channel as well but that will take time to go through the Roku approval process. 1
Happy2Play 9811 Posted November 21, 2016 Posted November 21, 2016 So anyone still having issues that haven't received the Roku firmware update 7.5 build 4099-24 should try the beta channel or side loading the app.
Vitale4 15 Posted November 22, 2016 Posted November 22, 2016 ROKU needed to update their release process, if you have a ROKU 3 and I think 2, you will be able to do a manual update to get the new version. I just did it and now the EMBY and EMBY Blue Neon Night works as expected.
dmcneil 0 Posted November 22, 2016 Posted November 22, 2016 I just updated to 4099 using the regular menu options. The secret screen method only showed 4096 as being available. Sent from my iPhone using Tapatalk
AmericanMike 18 Posted November 22, 2016 Author Posted November 22, 2016 (edited) Since I started this topic I felt compelled to give an update. I received the 4099 update yesterday and things appear to be working well. Just in time for Thanksgiving football. I do notice that once the live TV channel starts streaming I see to short breaks where the the screen says "Loading Please Wait...." but then will stream on that channel for hours. I haven't rebooted by server or router yet (scheduled this weekend) to see if it could be a latency issue. If it shows improvement after reboot I will update the group. Thanks.... Edited November 22, 2016 by AmericanMike
dboyer 0 Posted November 22, 2016 Posted November 22, 2016 Last night, I once again tried to force an firmware update on each of our Roku 360X0 sticks. It finally allowed us to upgrade both of our Roku sticks to 7.5.4099. Like AmericanMike, we also see short breaks when it starts to load, but it continues to play after that.
