cqjs2001 0 Posted November 3, 2016 Posted November 3, 2016 I have a Roku 3. when i try to open Emby, I get a screen that says retrieving. Some times you can see the Emby logo in the top left corner and sometimes you can only see the very top of the logo. this screen is up for about 5 seconds and then it goes back to the Roku home screen. I have tried to uninstall and reinstall the app and reboot the Roku. that had no effect. I am still able to access Emby through my phone app, that still works. please help. I don't know how to pull any logs from the roku or how to get them here if I did.
speechles 2060 Posted November 3, 2016 Posted November 3, 2016 (edited) I have a Roku 3. when i try to open Emby, I get a screen that says retrieving. Some times you can see the Emby logo in the top left corner and sometimes you can only see the very top of the logo. this screen is up for about 5 seconds and then it goes back to the Roku home screen. I have tried to uninstall and reinstall the app and reboot the Roku. that had no effect. I am still able to access Emby through my phone app, that still works. please help. I don't know how to pull any logs from the roku or how to get them here if I did. You've used emby connect, and you've used sign out. This post explains why it happens: https://emby.media/community/index.php?/topic/24151-theme-blue-neon-night/page-41&do=findComment&comment=382135 You can fix it by removing all emby apps from your roku. It should ask, "are you sure?". When it asks this it will also delete the registry for the app. After deleting all of the emby apps restart your roku. When the roku reboots add back your emby roku apps. Remember when using emby connect, do not use sign out, use change server instead. This is what creates the problem. Edited November 3, 2016 by speechles
