audio sync issues
I have been having quite a bit of trouble with 24FPS TV shows losing audio sync as the video progresses.  One example is listed below.  I have had to resort to playing them in Windows Media Player, which works just fine.  I am using Shark007 codecs on Windows 10 x64 and MadVR default settings.
Is it just me or are others having issues too?  Server log attached.
General
Unique ID                                : 184327597652179734562922668667173470997 (0x8AAC3438A8660F07E103A3D1238A0315)
Complete name                            : D:\media\TV\Westworld (2016) [Western]\Season 1\Westworld - S01E03 - The Stray [unknown] [2016-10-16].mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 1.18 GiB
Duration                                 : 58 min 32 s
Overall bit rate                         : 2 889 kb/s
Encoded date                             : UTC 2016-10-17 04:19:06
Writing application                      : mkvmerge v9.0.1 ('Obstacles') 64bit
Writing library                          : libebml v1.3.3 + libmatroska v1.4.4
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 5 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 2 448 kb/s
Width                                    : 1 280 pixels
Height                                   : 716 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.111
Stream size                              : 1.00 GiB (85%)
Writing library                          : x264 core 148 r2705 3f5ed56
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Matrix coefficients                      : BT.709
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 384 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 spf)
Compression mode                         : Lossy
Stream size                              : 161 MiB (13%)
Default                                  : Yes
Forced                                   : No
server-63613632137.txt
Guest asrequested
Post a screenshot of your settings in ET, and please describe your hardware configuration.
Edited by Doofus
i7-6800, 32GB, Nvidia GTX770, ASUS Xonar D2X analog to power amps.  Used to work fine, seems to have become a problem in the past week or so.
Guest asrequested
So you're using analog audio?
Yes, since my first HTPC 12 years ago.
Now that I think about it, I may have had this problem before and it was associated with MadVR.  I'll try switching to EVR this evening and see if it doesn't go away.
Hey guys, I have noticed after the last update to 3.0.8400.0 that I am seeing a loss of audio sync in almost all videos regardless of the client.
I commonly use Kodi 16 on openelec or chrome on windows.
Not sure if it is related but thought I would put my 2 cents in...
Guest asrequested
This is specific to theater. You should make a new post with logs in the server area.
I switched to EVR+ and the audio sync problem went away, so it seems to be related to using MadVR.  This is on the i7-6800K that runs Emby server as well as Emby Theater.  I tried the same video on the i7-5820K computer that direct plays over the network to a TV using HDMI (not bitstreaming) and it did not have the audio sync problem using MadVR.
Guest asrequested
I have an i5 6500 in my HTPC and I was having similar issues with MadVR. For me, it turned out to be some of the settings. When I changed them (see screenshots), everything played well. Try altering some of them.
