Navigation issue - LiveTV guide
When opening up item details from the Live TV guide, if the item is in the future, the channel name is highlighted - default focus (since Play obviously isn't an option).  When the cursor is there you cannot navigate down to Record unless you click Up first, then back down via the 3-dot button.
If the item is from the current time, you can navigate down from Play directly - no issue.
For future items, maybe make record button the default focus, or the 3-dot button.
Item from the future:
Item from current time:
I see that as well the channel number shouldnt be highlighted it doesnt look good. I agree with you record should be in focus.
It would be good for us that dont have a thumbnail to actually have the title of series to show up instead of just the episode title.
