Valodia De Seynes 2 Posted October 29, 2016 Posted October 29, 2016 Hello, It seems there is an issue with the Emby for Kodi app concerning external subtitles. Whenever I play a video in Kodi, it doesn't detect any subtitles for it even though the server-side has detected the subtitles. This doesn't happen when the subtitles are part of the video file (like .mkv). Also, I'm pretty sure the issue arose with version 2.3.0 because I remember being able to play external subtitles with version 2.2.19. I'm not certain any log is necessary but I can provide them if you need them.
Angelblue05 4132 Posted October 30, 2016 Posted October 30, 2016 (edited) Yes, please post your log to start with. (Usually always post your log as it's needed 95% of the time). No Kodi debug. I've been trying to fix encoding issues with external subs to make sure they would display correctly. Hopefully your log will indicate what's wrong. Sent from my iPhone using Tapatalk Edited October 30, 2016 by Angelblue05
Valodia De Seynes 2 Posted October 30, 2016 Author Posted October 30, 2016 (edited) I've attached my log file. Edit: Huh it didn't seem to work. I'm going to post the full log here. Edited October 30, 2016 by Valodia De Seynes
Solution Angelblue05 4132 Posted October 30, 2016 Solution Posted October 30, 2016 Thanks for the log, can you give this a try? plugin.video.emby-2.3.2~alpha.zip 1
Valodia De Seynes 2 Posted October 30, 2016 Author Posted October 30, 2016 Yes it works. The problem is fixed, thanks! 1
