Soultaker 225 Posted September 8, 2014 Author Posted September 8, 2014 Are there any speed tweaks you could employ here or is it WMC holding us back? Other than speed I can't see how square could be improved!! um... you are so silly there are at least hundred things wrong with Square.... 2
Soultaker 225 Posted September 14, 2014 Author Posted September 14, 2014 Latest square is now available, as always details are in the 2nd post on this thread http://mediabrowser.tv/community/index.php?/topic/4082-square-theme-general-help-thread/?p=62484. Some of whats new... square bar ehs square list view 3
browned 33 Posted September 17, 2014 Posted September 17, 2014 Is it just me or is Square no longer taking note of the DefaultViewType setting in the <username>-MediaBrowserXML.config file? I have this set to CoverFlow and have noticed that as each of my machines have updated to the lastest version of Square the views are returning to Poster and require a manual change to fix them even though the xml file still has CoverFlow set. 1
heula 192 Posted September 17, 2014 Posted September 17, 2014 Since the 1.9.14.0 update my photo collection is no longer being displayed. Just a black screen.
ebr 16342 Posted September 17, 2014 Posted September 17, 2014 Is it just me or is Square no longer taking note of the DefaultViewType setting in the -MediaBrowserXML.config file? I have this set to CoverFlow and have noticed that as each of my machines have updated to the lastest version of Square the views are returning to Poster and require a manual change to fix them even though the xml file still has CoverFlow set. That setting only applies to brand new folders. The view type for any particular folder, once loaded, is stored on the server.
BAS 225 Posted September 17, 2014 Posted September 17, 2014 (edited) Is it just me or is Square no longer taking note of the DefaultViewType setting in the <username>-MediaBrowserXML.config file? I have this set to CoverFlow and have noticed that as each of my machines have updated to the lastest version of Square the views are returning to Poster and require a manual change to fix them even though the xml file still has CoverFlow set. This happened to me also, I'm sure it has to do with the 3 new view types in Square. Not sure why its not embracing that value on the reset though as mine was set to coverflow as well in the .xml but in square was reset to Poster as well. Just a heads up Soultaker in case you add more views in the future. Edited September 17, 2014 by BAS
Soultaker 225 Posted September 17, 2014 Author Posted September 17, 2014 Since the 1.9.14.0 update my photo collection is no longer being displayed. Just a black screen. Can you try changing views?
Soultaker 225 Posted September 17, 2014 Author Posted September 17, 2014 I dont respect the default folder view at the moment... I had a little trouble verifying stuff but I'll have another go at that. 1
ebr 16342 Posted September 17, 2014 Posted September 17, 2014 I dont respect the default folder view at the moment... I had a little trouble verifying stuff but I'll have another go at that. Honestly, ST, I'm not sure MBC in general respects this setting anymore as it is local and display preferences come from the server now.
heula 192 Posted September 17, 2014 Posted September 17, 2014 Can you try changing views? No photos at all views.
browned 33 Posted September 17, 2014 Posted September 17, 2014 Ebr, Where do we set the defaults on the server?
Soultaker 225 Posted September 17, 2014 Author Posted September 17, 2014 No photos at all views. I also have a photos section, and it is working fine for me. I do not use localized language could that be an issue here?
ebr 16342 Posted September 17, 2014 Posted September 17, 2014 Ebr, Where do we set the defaults on the server? You don't. This isn't exposed anywhere.
Cheesegeezer 3106 Posted September 17, 2014 Posted September 17, 2014 No photos at all views. I've just tested this with square and I don't have any issues. Just check that your locations on the server for Photo's collection are correctly configured and that you actually have photos in that location on the hard drive and that you haven't set any private permissions for it.
browned 33 Posted September 17, 2014 Posted September 17, 2014 I am guessing it would be complicated to get the relevant plugin information back to the server to make the CoverFlow option selectable if it was available on the server. cheers
heula 192 Posted September 18, 2014 Posted September 18, 2014 I also have a photos section, and it is working fine for me. I do not use localized language could that be an issue here? Fixed, it was a server issue. Changed from Dev to Beta and now I see my photos in MBC again. They were visable in the webclient but not in MBC with several themes.
Redshirt 1487 Posted September 18, 2014 Posted September 18, 2014 I also have a photos section, and it is working fine for me. I do not use localized language could that be an issue here? The newer server builds have renamed some of the photo entities, ebr accounted for it in the newest versions of MBC but if your theme is referencing the photo folder by entity name it may be an issue.
Soultaker 225 Posted September 18, 2014 Author Posted September 18, 2014 The newer server builds have renamed some of the photo entities, ebr accounted for it in the newest versions of MBC but if your theme is referencing the photo folder by entity name it may be an issue. Thanks for the info but rest assured Square doesn't do any direct referencing like that an
ebr 16342 Posted September 18, 2014 Posted September 18, 2014 Fixed, it was a server issue. Changed from Dev to Beta and now I see my photos in MBC again. They were visable in the webclient but not in MBC with several themes. Generally, you will need to keep your clients and server on the same update track. That is, if you allow your server to update at dev level but not MBC, you will likely run into issues like this. You may still run into them when server changes are made, but they will correct much quicker if you have MBC set to dev as well. If you want a stable environment, I'd keep both at Release or Beta. 1
MrWebsmith 598 Posted September 19, 2014 Posted September 19, 2014 @@Soultaker bug located: subtitles toggle doesnt work lvl 2 S.A, tech confirm this via skype (no rush) 1
Soultaker 225 Posted September 21, 2014 Author Posted September 21, 2014 @@Soultaker bug located: subtitles toggle doesnt work lvl 2 S.A, tech confirm this via skype (no rush) Bug confirmed, will be fixed as part of next release thanks for the feedback MWS! Next release on schedule for mid week. 1
AgileHumor 123 Posted September 21, 2014 Posted September 21, 2014 I have a really bad bug that marked all my content as played. If you select any item in the "Latest Unplayed" and press the star (*) key, and mark the item as played...it doesn't just mark that content as played...but 100% of your content as played. Is that by design?
