MrWebsmith 598 Posted May 28, 2014 Posted May 28, 2014 lol st... 2 posts above you said "dohness" so im gonna let toggleable slide for now 1
AsparagusTrevor 1 Posted May 28, 2014 Posted May 28, 2014 Added some options to toggle the media info bar items. Not all items will be "toggleable" (if thats even a word). Will be part of the next release. Looks exactly how I was thinking, brilliant stuff!
MrFlibbles 21 Posted May 29, 2014 Posted May 29, 2014 Done, will be part of the next update. Fan-bloody-tastic. Thanks soultaker!
Smitty018210 147 Posted June 1, 2014 Posted June 1, 2014 Is there a way to edit the size of the font for the overview and poster summaries? In know that you could do it the past with the CustomFonts.mcml file. Is this still possible? Thanks!
Soultaker 225 Posted June 1, 2014 Author Posted June 1, 2014 @smity018210 Should be able to with the custom fonts. Why dont you try it out and report back your findings?
Smitty018210 147 Posted June 1, 2014 Posted June 1, 2014 @@Soultaker, I asked because I haven't yet been able to find that file in the new MB3 folders (server, or classic) Any idea where it might be located now?
Soultaker 225 Posted June 1, 2014 Author Posted June 1, 2014 (edited) Hmm I wouldn't know mate if stuff has been changed. I always thought your simply drop in a file in C:\ProgramData\MediaBrowser-Classic folder named [Theme]CustomFonts.mcml so for square it's simply: SquareCustomFonts.mcml The font you are looking for is Sq_Medium Edited June 1, 2014 by Soultaker
Smitty018210 147 Posted June 1, 2014 Posted June 1, 2014 ok cool, I didn't remember having to do that last time, but I must have. lol Thanks guys I let you know what happens.
Smitty018210 147 Posted June 1, 2014 Posted June 1, 2014 (edited) Doesn't seem to be working. With the file in place MBC wont start. If I take file out stars with no problem. Any ideas?Here is the log. I think. MBClassic-162014f104215d1c9d4dceb3d79606b02bc058.log Edited June 1, 2014 by Smitty018210
Soultaker 225 Posted June 1, 2014 Author Posted June 1, 2014 The error log says it cant read any markup, try adding these lines into your file. <Mcml xmlns="http://schemas.microsoft.com/2006/mcml" xmlns:cor="assembly://MsCorLib/System" xmlns:me="Me"> </Mcml> 1
Smitty018210 147 Posted June 1, 2014 Posted June 1, 2014 (edited) That did it! Thanks a lot for helping me out. I really appreciate the extra effort Soultaker. Square is a fantastic theme. Thank for your hard work. Edited June 1, 2014 by Smitty018210
phonk 15 Posted June 3, 2014 Posted June 3, 2014 (edited) Hi phonk, A picture would be very useful, I'm having trouble visualizing what you mean. Hi soultaker, sorry for the late answer. If I select an episode from the OneTV Menu the videobackdrop starts in the detail view: Edited June 3, 2014 by phonk
ronvp 92 Posted June 3, 2014 Posted June 3, 2014 @@ronvp Hey ron, I've been away from the scene a while but can you tell me in MBC which other themes have genre thumbs working? FYI. after updating to the latest server (Version 3.0.5264.17006), thumbs now work correctly for genres..
ebr 16342 Posted June 3, 2014 Posted June 3, 2014 FYI. after updating to the latest server (Version 3.0.5264.17006), thumbs now work correctly for genres.. Actually, you needed to update to the MBC dev build for this to get fixed so I assume you did that as well. 1
Soultaker 225 Posted June 3, 2014 Author Posted June 3, 2014 Hi soultaker, sorry for the late answer. If I select an episode from the OneTV Menu the videobackdrop starts in the detail view: @@phonk ahh that is working as expected. I don't have plans to change that - sorry. FYI. after updating to the latest server (Version 3.0.5264.17006), thumbs now work correctly for genres.. Actually, you needed to update to the MBC dev build for this to get fixed so I assume you did that as well. @@ronvp All the hard work was done by ebr, I guess Square merely highlighted the issue. Thx ebr.
Yogi 367 Posted June 8, 2014 Posted June 8, 2014 Hi ST, I recevied an Invalid Application Error when entering the Upcoming TV icon,never had an issue before.Logs attached below. wmc.txt MBClassic-862014404b5f91591d460c845b719ee42dea37.log
ronvp 92 Posted June 8, 2014 Posted June 8, 2014 Actually, you needed to update to the MBC dev build for this to get fixed so I assume you did that as well. sure did..thanks for the help..
Soultaker 225 Posted June 8, 2014 Author Posted June 8, 2014 @@Yogi Yea I'm already aware of this. There was a breaking Server change (can't recall which one exactly) that caused this. I've fixed this but I'm waiting on a full on release version of MBC.
Lee 212 Posted June 8, 2014 Posted June 8, 2014 @@Soultaker not sure if you missed my earlier post. Extras don't show up anywhere for me in Square, they show up fine in the webclient....
Soultaker 225 Posted June 8, 2014 Author Posted June 8, 2014 just to clarify I mean special features in movies... I dont know what you are referring to.
techywarrior 689 Posted June 8, 2014 Posted June 8, 2014 I think that it's actually something that isn't in MBC yet. ST, check with Ebr but what Lee is talking about is that you can have special features for movies. Like behind the scenes etc. You put them into a folder called "specials" in the movie folder and they appear in a section called specials in the web client. These don't appear in MBC but I seem to remember Ebr saying that he hadn't implemented that yet (or maybe he has since then and you need to update Square). Lee, have you tried switching to Chocolate and seeing if they show up in that theme? 1
Soultaker 225 Posted June 8, 2014 Author Posted June 8, 2014 I see, well if anyone has any "specials" I can borrow to test with that would be useful.
