Crestj 68 Posted October 28, 2016 Posted October 28, 2016 CoverArt had just updated to 4.0.20 in MB Server v3.1.59.0 Now, after an MB Server restart, there are no image adjustments applied to anything and the plugin doesn't show as installed. I can install it again and restart but after the restart it shows as not installed again. Just me?
ebr 16340 Posted October 28, 2016 Posted October 28, 2016 Need to see a log please: How to Report a Problem
Solution ebr 16340 Posted October 28, 2016 Solution Posted October 28, 2016 Update your server. You are on a very old beta version. 1
Crestj 68 Posted October 28, 2016 Author Posted October 28, 2016 (edited) That's odd, I have automatic server updating turned on using the Official Release. I did switch from the Beta Release to the Official a couple of months back, do you think it got stuck? [EDIT] Ah I see the latest version required .Net 4.6.2. I wonder if that's why the auto updating wasn't working. Edited October 28, 2016 by Crestj
ebr 16340 Posted October 28, 2016 Posted October 28, 2016 If you are going to go back to the Release version, you are going to have to remove all your plug-ins and then re-install the proper versions. The ones you have now will be incompatible.
Crestj 68 Posted October 28, 2016 Author Posted October 28, 2016 OK, I'll get the release version in then update it all. Half tempted to just stay on Beta if its this much effort!
Crestj 68 Posted October 28, 2016 Author Posted October 28, 2016 Server updated and plugins all uninstalled and reinstalled. All I can say is thank god the plugins keep their settings when you uninstall them! Really didn't want to have to find all the keys and ID's for all Radeons plugins and the Google Drive plugin!!! Thanks Ebr for your help. 1
