ebr 16309 Posted June 9, 2016 Posted June 9, 2016 We don't currently support multiple resolutions of episodes.
bfahner 0 Posted June 10, 2016 Posted June 10, 2016 Ahh thats why.. Any chance you could work this out in one of the near releases? I have a script running that allows me to "prep" episodes. My HW isn't strong enough to do so on the fly. Anyway, thanks for clearing that up Cheers, Bauke
Luke 42203 Posted June 10, 2016 Posted June 10, 2016 The latest beta has pooling of series and seasons, but not yet episodes. but at least they all show up together. 1
adam.niescierowicz 6 Posted August 11, 2017 Posted August 11, 2017 Hi, i have question regarding library scanning for multiversion movies. From what i have read so far you are creating multi version videos using filenames. Why don't you use information from NFO files that you create upon library scan. In NFO files are information like: imdbid and tmdbid - you can group video files using this information fileinfo with width/height and bitrate - you can use this for video version
Luke 42203 Posted August 11, 2017 Posted August 11, 2017 Hi, i have question regarding library scanning for multiversion movies. From what i have read so far you are creating multi version videos using filenames. Why don't you use information from NFO files that you create upon library scan. In NFO files are information like: imdbid and tmdbid - you can group video files using this information fileinfo with width/height and bitrate - you can use this for video version Well for one, what if there is no imdbid or tmdbid? That's why we use something more primitive such as the file name. Second, we don't read file info from nfo's. We need accurate media info in order to ensure features will work properly and therefore we can't trust user-created content.
adam.niescierowicz 6 Posted August 11, 2017 Posted August 11, 2017 Well for one, what if there is no imdbid or tmdbid? That's why we use something more primitive such as the file name. If we don't have imdbid or tmdbid this mean that we need to manualy add movie metadata to emby, yes? if we need to add metadata manualy we can add multiversion data or the movie will be separate file. Second, we don't read file info from nfo's. We need accurate media info in order to ensure features will work properly and therefore we can't trust user-created content. I'm thinking about NFO files created by emby. I believe that we can trust this data. Do music videos support multiversion?
Luke 42203 Posted August 11, 2017 Posted August 11, 2017 If the content is user-editable, which nfo's are, then we can't consider them trusted. It looks like the feature is not enabled for music videos but we can try enabling it for the next release, thanks.
adam.niescierowicz 6 Posted August 11, 2017 Posted August 11, 2017 It seems to me that it mistakenly used the name of NFO. I'm thinking about internal metadata in emby. If the content is user-editable, which nfo's are, then we can't consider them trusted. If we allow users to change data, then we trust him to do it correctly.If not, why do we allow the user to change the data? It looks like the feature is not enabled for music videos but we can try enabling it for the next release, thanks. Very thanks, if i'm using beta release, when i can update?
adam.niescierowicz 6 Posted August 12, 2017 Posted August 12, 2017 Is there a way to preserve original filename and use multiversion? My file structure would be like this "RootDIR/Year.Month/Name of the movie/file" I think that original filename is very important thing, there are information about: source video - Remux, BDRip, DVD, TS, ... audioformat - like Multi language, file creator
Luke 42203 Posted August 12, 2017 Posted August 12, 2017 Have you checked out our wiki in regards to multi-version naming? https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming Thanks !
adam.niescierowicz 6 Posted August 12, 2017 Posted August 12, 2017 Have you checked out our wiki in regards to multi-version naming? https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming Thanks ! I have read the wiki before, I see that at this moment it is required to rename the file. So at the same time the loss of some kind of video publisher information or image source. At this moment it is no longer a problem. For those who do not want to lose the file name. You can save the file name in the container video metadata as a comment. Luke thanks for the help.
adam.niescierowicz 6 Posted October 31, 2017 Posted October 31, 2017 Hi, to @@Luke, Can you add multiversion across two library? My situation: Because Emby addon for kodi does not support multi version. I'm choose appropriate video library access in user settings. I created two main directory one Video.highbitrate and second Video.lowbitrate. I want that users with better internet connection have access to both library. I created one account with such configuration but video isn't show with two version. I checked this in emby web interface.
