heula 192 Posted January 20, 2014 Posted January 20, 2014 (edited) Just installed serverwmc and I see this live tv with guide etc is available in the webclient. This is a nice feature and now I don't have to use remote potato anymore. What I have always missed in media center was to be able to schedule recordings, watch the guide etc from every pc in the house instead of just the one with the tv cards in them. Can we expect to see the guide, live tv etc in mbc some day? Edited January 20, 2014 by heula
ebr 16332 Posted January 20, 2014 Posted January 20, 2014 Some day. This will be particularly difficult because it doesn't fit any display paradigm any of the themes understand.
heula 192 Posted January 20, 2014 Author Posted January 20, 2014 Some day. This will be particularly difficult because it doesn't fit any display paradigm any of the themes understand. okay, let's hope they some day will.
Deihmos 170 Posted January 20, 2014 Posted January 20, 2014 You can use My Media Center. It is available for basically all platforms including mobile.
ebr 16332 Posted January 20, 2014 Posted January 20, 2014 The wmc guide is only available on the machine with the tuner card in it. He was wanting to see this information on other media centers that don't have the live tv capability. This is a reasonable application, but is something that will not be easily implemented and, given the fact that most MBC users will have easy access to the actual WMC live tv stuff, will probably not be a huge priority. It is likely it would be via some sort of add-on like if I bring MBPlus back. That way I could control the presentation of it regardless of the theme.
Solution Latchmor 584 Posted January 20, 2014 Solution Posted January 20, 2014 Hi, I guess something like this would be cool. It's currently using Remote Potato though, which I intend to remove when I can... http://www.thegreenbutton.tv/forums/viewtopic.php?f=9&t=523 Cheers 1
Deihmos 170 Posted January 20, 2014 Posted January 20, 2014 (edited) You should get a network tuner and then problem solved. All your PCs can then have a guide. Edited January 20, 2014 by Deihmos
heula 192 Posted January 21, 2014 Author Posted January 21, 2014 (edited) You should get a network tuner and then problem solved. All your PCs can then have a guide. That's an option but that's not what I'm going to do. With the serverwmc webclient on my ipad is a better and cheaper solution. Edited January 20, 2014 by heula
Luke 42239 Posted January 21, 2014 Posted January 21, 2014 i think what he means is network tuner + server wmc. really the ideal solution so that it's not tied to a single machine.
Deihmos 170 Posted January 21, 2014 Posted January 21, 2014 i think what he means is network tuner + server wmc. really the ideal solution so that it's not tied to a single machine. That is exactly what I meant. I am using the HDHomerun Prime.
Luke 42239 Posted January 21, 2014 Posted January 21, 2014 Well I assume he wants to stay within Media Browser because if you're going to talk about using another app you might as well just use the wmc guide. 1
Lee 212 Posted January 22, 2014 Posted January 22, 2014 Don't see network tuners in the uk... Sent by my HTC8X using Tapatalk
Lee 212 Posted January 22, 2014 Posted January 22, 2014 I think mediabrowser theater should be the front end used once complete anyway. Removes the need for WMC completely now! Sent by my HTC8X using Tapatalk
wally007 6 Posted January 24, 2014 Posted January 24, 2014 i think what he means is network tuner + server wmc. really the ideal solution so that it's not tied to a single machine. But how would this help to have "one guide" on multiple machines ? Currently I have Network Tuner (Dreambox) and two WMC machines connect to it. The problem comes when someone sets up recordng on one machine, the other one does not know about it since they dont share same guide recording database. Does ServerWMC help in anyway in this scenario ?
mini__me 28 Posted January 24, 2014 Posted January 24, 2014 I can see this being useful to be able to continue using my MCE extenders till they die, but have one GUI (MB3) through the whole house, as I'm fairly sure I remember reading a way to boot an extender to something other than one of the MCE default options. This would also give remote control of the content played to the extender through an MB3 application running on an old iPad / Surface in a similar way to the current Ceton My Media Center that I'm using now to control 7MC. If I can boot the extender straight into MB3 then it may also allow me to upgrade my current 7MC / MB3 server to Windows 8.1 and run MBT with the additional plugins to launch some of the Win 8 stuff. Obviously end game is to bin off the extender and have something small running MBT but if I have the extender hardware it would be good to continue using it till it dies 1
