cmcv 3 Posted January 20, 2014 Posted January 20, 2014 Hi I am trying to get MBT to work & when minimized the sound is in sync fine with the picture but the moment i put it to maximum it loses sync... I cant work out why & have lav spliter installed & set up as well as trying to change the audio speed to try to get it in sync with the full screen movie & or tv show. What am I missing its doing my head in.
pmac 143 Posted January 22, 2014 Posted January 22, 2014 Just out of curiosity, how can you tell if the audio is in sync while MBT is minimized?
cmcv 3 Posted January 22, 2014 Author Posted January 22, 2014 Hi ok I don't think I explained it to well. I mean when the screen is in the smaller minimum screen mode & not the maximum screen mode it is in sync but in maximum screen it is not.
Davidtt485 6 Posted January 24, 2014 Posted January 24, 2014 that sounds like a hardware accelleration issue. when it is windowed the computer downs the quality and it is easier on the cpu and gpu but when its full screen it has to play the file in full quality and i beleive your hardware accelleration is not working like it should be.
