ThermoDust 12 Posted October 21, 2016 Posted October 21, 2016 I told Emby to sync a video and found out offline mode is still in the works. I read you can play the videos offline using VLC or other media players. I just can't find the location of the video. Where would it be stored?
ebr 16336 Posted October 21, 2016 Posted October 21, 2016 Check the settings in the app. There is a place where this is indicated.
AgileHumor 123 Posted October 31, 2016 Posted October 31, 2016 (edited) First, the default setting is blank. There is no way to blank the setting except clearing all android data for that app. The default location is hidden in 99% of app video file managers (including Emby selection) on the device...so once you change the setting (it won't work, see below)...and you can't get it back to the default Emby hidden directory which will. So you will need something like ES File Explorer with the view hidden files shown. Also, I've tried syncing on 4 different android devices (4.4+)...and if you select anything but the default location...it doesn't work. If I store it on the internal storage "Movies" folder...or a MicroSD car...it won't sync. Edited November 1, 2016 by AgileHumor
Luke 42243 Posted July 16, 2017 Posted July 16, 2017 @@ThermoDust @@AgileHumor 2.9.32 is rolling out and supports offline browsing and playback. The feature is still very new so please make sure to leave your feedback and we will continue to improve it. Thanks ! 1
