just.RooT 0 Posted October 21, 2016 Posted October 21, 2016 Hello, when i try to refresh the Live-TV Guide following errors appeared: 2016-10-21 00:36:55.8269 Info HttpServer: HTTP Response 200 to 85.212.44.200. Time: 21ms. http://emby.unselt-online.de:8096/ScheduledTasks?isHidden=false2016-10-21 00:36:55.9399 Info App: [DVBLink] - Channels found on server: 112016-10-21 00:36:55.9411 Info App: [DVBLink] - Logos path not found2016-10-21 00:36:56.0104 Info App: Refreshing guide with 7 days of guide data2016-10-21 00:36:56.0173 Info App: [DVBLink] - Get Programs, retrieve all programs for ChannelId: 101100002016-10-21 00:36:56.3325 Info App: [DVBLink] - Programs found for channel : 10110000 - 12016-10-21 00:36:56.3687 Error App: Error getting programs for channel Das Erste HD *** Error Report *** Version: 3.0.8300.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package="synology" -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe Operating system: Unix 3.10.77.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/packages/EmbyServer/target/var Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Oct 17 03:41:44 CST 2016) Application Path: /volume1/@appstore/EmbyServer/releases/v3.0.8300/MediaBrowser.Server.Mono.exe Index was outside the bounds of the array. System.IndexOutOfRangeException at MediaBrowser.Server.Implementations.Persistence.SqliteItemRepository.DeserializeProviderIds (System.String value, MediaBrowser.Controller.Entities.BaseItem item) [0x00052] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.Persistence.SqliteItemRepository.GetItem (System.Data.IDataReader reader, MediaBrowser.Controller.Entities.InternalItemsQuery query) [0x00c0e] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.Persistence.SqliteItemRepository.GetItemList (MediaBrowser.Controller.Entities.InternalItemsQuery query) [0x00234] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemList (MediaBrowser.Controller.Entities.InternalItemsQuery query) [0x00070] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>d__bb.MoveNext () [0x005b6] in <e36bce1ff65f413585edc97cf7d42376>:0 2016-10-21 00:36:56.3687 Info App: [DVBLink] - Get Programs, retrieve all programs for ChannelId: 101200002016-10-21 00:36:56.4715 Info HttpServer: HTTP GET http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml. UserAgent: Linux/3.10.77, UPnP/1.0, Portable SDK for UPnP devices/1.6.182016-10-21 00:36:56.4729 Info Dlna: No matching device profile found. The default will need to be used. HOST: 127.0.0.1:8096 DATE: Thu, 20 Oct 2016 22:36:56 GMT CONNECTION: close USER-AGENT: Linux/3.10.77, UPnP/1.0, Portable SDK for UPnP devices/1.6.182016-10-21 00:36:56.4745 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 3ms. http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml2016-10-21 00:36:56.4777 Info HttpServer: HTTP GET http://192.168.178.200:8096/dlna/2cc97c4242ce7029c86cce021718ad6d/description.xml. UserAgent: Linux/3.10.77, UPnP/1.0, Portable SDK for UPnP devices/1.6.182016-10-21 00:36:56.4790 Info Dlna: No matching device profile found. The default will need to be used. HOST: 192.168.178.200:8096 DATE: Thu, 20 Oct 2016 22:36:56 GMT CONNECTION: close USER-AGENT: Linux/3.10.77, UPnP/1.0, Portable SDK for UPnP devices/1.6.182016-10-21 00:36:56.4818 Info HttpServer: HTTP Response 200 to 192.168.178.200. Time: 4ms. http://192.168.178.200:8096/dlna/2cc97c4242ce7029c86cce021718ad6d/description.xml2016-10-21 00:36:56.4825 Info HttpServer: HTTP GET http://172.17.0.1:8096/dlna/096631d4ad9b5712610e502d462ef2fa/description.xml. UserAgent: Linux/3.10.77, UPnP/1.0, Portable SDK for UPnP devices/1.6.182016-10-21 00:36:56.4839 Info Dlna: No matching device profile found. The default will need to be used. HOST: 172.17.0.1:8096 DATE: Thu, 20 Oct 2016 22:36:56 GMT CONNECTION: close USER-AGENT: Linux/3.10.77, UPnP/1.0, Portable SDK for UPnP devices/1.6.182016-10-21 00:36:56.4852 Info HttpServer: HTTP Response 200 to 192.168.178.200. Time: 3ms. http://172.17.0.1:8096/dlna/096631d4ad9b5712610e502d462ef2fa/description.xml2016-10-21 00:36:56.5663 Info App: [DVBLink] - Programs found for channel : 10120000 - 12016-10-21 00:36:56.5687 Error App: Error getting programs for channel kabel eins *** Error Report *** Version: 3.0.8300.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package="synology" -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe Operating system: Unix 3.10.77.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/packages/EmbyServer/target/var Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Oct 17 03:41:44 CST 2016) Application Path: /volume1/@appstore/EmbyServer/releases/v3.0.8300/MediaBrowser.Server.Mono.exe Index was outside the bounds of the array. System.IndexOutOfRangeException at MediaBrowser.Server.Implementations.Persistence.SqliteItemRepository.DeserializeProviderIds (System.String value, MediaBrowser.Controller.Entities.BaseItem item) [0x00052] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.Persistence.SqliteItemRepository.GetItem (System.Data.IDataReader reader, MediaBrowser.Controller.Entities.InternalItemsQuery query) [0x00c0e] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.Persistence.SqliteItemRepository.GetItemList (MediaBrowser.Controller.Entities.InternalItemsQuery query) [0x00234] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemList (MediaBrowser.Controller.Entities.InternalItemsQuery query) [0x00070] in <e36bce1ff65f413585edc97cf7d42376>:0 at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>d__bb.MoveNext () [0x005b6] in <e36bce1ff65f413585edc97cf7d42376>:0 My System: Emby Server Version 3.0.8300.0 on Synology NAS DVBLink 6.0.0 Newest Version! Status: Ok DVBLink Plugin 1.2.1.0 (same Problem with stable 1.1.6) Any Idea? Thanks and Best regards. just.RooT
just.RooT 0 Posted October 21, 2016 Author Posted October 21, 2016 Oh find same Problem here: https://emby.media/community/index.php?/topic/16771-devdvblink-live-tv-plugin/page-24
AlwinHummels 134 Posted October 24, 2016 Posted October 24, 2016 I've installed the new version but still the same issue. as mentioned above
Pseudomax 3 Posted November 22, 2016 Posted November 22, 2016 (edited) I can add my voice to the fact that I am getting a similar error. I was getting it with version 1.1.6 and still with 1.3.0 beta ... I read about certain files to delete to solve this, but I might be mixing up solutions ... please help if there is a solution?! I have just done a fresh install of Windows with all the apps, but used a backup (that was working fine) to restore my settings. Edited November 22, 2016 by Pseudomax
Luke 42242 Posted November 22, 2016 Posted November 22, 2016 Hi, we're sorry about this particular issue. The next release of Emby Server will resolve it.
