manics 1 Posted October 21, 2016 Posted October 21, 2016 (edited) serverlog.txtHelp im pulling my hair out I am running emby server in an unraid docker which has been working fine untill today i started adding a new series which was identified correctly however it wont display any episodes, i then tried adding episodes to an existing series and again it wont display the new episodes. i have tried running the clean database which seams to complete very quickly rescanned several times tried removing library and cleaned and scanned even tried removing the library.db and rescanned my folder structure is tvshow/season/tvshowname - 1x1 - episode name, i have not had any issues before server Version 3.0.8300.0 i have just noticed in the correctly identified episodes there is an xml file for each of the episodes, however the new episodes dont have this thanks Edited October 21, 2016 by manics
Luke 42244 Posted October 21, 2016 Posted October 21, 2016 Hi, welcome. Can you discuss an example? What do you see?
manics 1 Posted October 22, 2016 Author Posted October 22, 2016 Solved it think it was to do with permissions in unraid, thanks for replying
