OpenSourceUser 6 Posted October 20, 2016 Posted October 20, 2016 (edited) Hello theI have Kodi 16.1 Jarvis running on LibreElec 7.1.0 on top of an ODROID-C2. After I added the repository and installed "repository.beta.emby.kodi-1.0.5.zip" (from which I got a notification that it is enabled) nothing happened. Even a reboot did not help. So I uninstalled the beta application and tried the stable zip, but again there was no prompt to configure the addon.The kodi log file says:19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.podgod19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.xbmc.org19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.beta.emby.kodi19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.libreelec.tv[...]18:03:45 T:547957567488 ERROR: GetDirectory - Error getting addons://sources/18:03:45 T:547957567488 ERROR: CGUIMediaWindow::GetDirectory(addons://sources/) failedIs there a way to start the emby addon via ssh or have a dedicated log file for it?Kind regards Edited October 20, 2016 by OpenSourceUser
Solution mastrmind11 722 Posted October 20, 2016 Solution Posted October 20, 2016 Hello the I have Kodi 16.1 Jarvis running on LibreElec 7.1.0 on top of an ODROID-C2. After I added the repository and installed "repository.beta.emby.kodi-1.0.5.zip" (from which I got a notification that it is enabled) nothing happened. Even a reboot did not help. So I uninstalled the beta application and tried the stable zip, but again there was no prompt to configure the addon. The kodi log file says: 19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.podgod 19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.xbmc.org 19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.beta.emby.kodi 19:51:13 T:547957567488 NOTICE: ADDONS: Using repository repository.libreelec.tv [...] 18:03:45 T:547957567488 ERROR: GetDirectory - Error getting addons://sources/ 18:03:45 T:547957567488 ERROR: CGUIMediaWindow::GetDirectory(addons://sources/) failed Is there a way to start the emby addon via ssh or have a dedicated log file for it? Kind regards Go to your video addons, select Emby for Kodi, select configure, point it at your box. 1
OpenSourceUser 6 Posted October 20, 2016 Author Posted October 20, 2016 Oh dear! My bad, sorry. Thanks for the quick reply.
CBers 7554 Posted October 20, 2016 Posted October 20, 2016 Go to your video addons, select Emby for Kodi, select configure, point it at your box. Oh dear! My bad, sorry. Thanks for the quick reply. You should have got the configuration screen displayed on install. Did that not happen?
Delphi 83 Posted October 20, 2016 Posted October 20, 2016 (edited) @@CBers @@OpenSourceUser only installed the repo not the addon... Edited October 20, 2016 by Delphi
CBers 7554 Posted October 20, 2016 Posted October 20, 2016 @@CBers @@OpenSourceUser only installed the repo not the addon... LOL
