Hello, I was hoping someone might be able to help me out. Ever since this emby app updated and changed its name to "Ember for Emby" I have been experiencing audio sync issues. All my files play with about a half second audio delay. I have messed with the playback audio settings, also uninstalled and re-installed the app. Still no luck on getting it synced properly.
Is there something I am missing or I can tweak to get the audio synced?
All these files will play correctly if I access them directly with VLC over the network, which are on another computer across the house over wired ethernet. The app is installed on a Windows 10 machine. Emby server is running on a Windows 8.1 machine.
Any ideas? Thanks.
  • 3 weeks later...
You're probably not going to find this helpful but ...I have no problem on my side. ^^"
The whole solution I am using:
  • Synology DS916+ DSM 6.0.2 with Emby server 3.0.8500
  • Xbox One with Ember for Emby 4.1.145
Just tested on Warcraft with HEVC and AC3. (The Atmos audio track makes the playback fail.)
Edited by willemavjc
  • 1 month later...
