BestYohman 5 Posted October 20, 2016 Posted October 20, 2016 I'm using emby from my phone to control my emby theater running on windows 8. Everything works except the volume keys. I'm able to mute but that is it. Sent from my HTC6545LVW using Tapatalk
ebr 16335 Posted October 20, 2016 Posted October 20, 2016 If the item is bitstreaming audio through Emby Theater then there is no way to adjust the volume other than with the actual audio device that is decoding that stream.
Luke 42243 Posted October 20, 2016 Posted October 20, 2016 Yes in other words, your receiver most likely. So first thing to do is check that.
