Koleckai Silvestri 1154 Posted January 19, 2014 Posted January 19, 2014 You know. I don't use WMC or actually have equipment to record Live TV at the moment. However I was wondering if I could set up the plugin just for the guide itself. Wouldn't have to go to another site to get that then.
Deihmos 170 Posted January 19, 2014 Posted January 19, 2014 (edited) You wouldn't be able to do that because wmc has to be setup for live TV. You cannot setup wmc for live TV without the equipment. Get the Hdhome run prime and save on not having to rent a box from the cable company. I could be wrong. Sent from my HTC One using Tapatalk Edited January 19, 2014 by Deihmos
Koleckai Silvestri 1154 Posted January 19, 2014 Posted January 19, 2014 Don't currently have a cable box but I'll look into that.
Deihmos 170 Posted January 19, 2014 Posted January 19, 2014 (edited) It also works with OTA. You don't need cable. Edited January 19, 2014 by Deihmos
gillmacca 17 Posted January 20, 2014 Posted January 20, 2014 Either that or one of our talented devs may be able to come up with a dummy tv tuner. I also would like access to the tv guide, but don't have a tv card
bloodtaker 71 Posted January 20, 2014 Author Posted January 20, 2014 The thing with the tuner guide is it is setup within location. WMC requires a tv tuner in the computer for it to work no work arounds. As of right now they are using ServerWMC which requires WMC with a tuner for it to work. NextPVR require a tuner to get the epg as well. You can get a cheap tuner for around 25 to 50 bucks now. NewEgg TV Tuners KWorld UB435-Q USB ATSC TV Tuner Stick 25.99 on newegg they work really well. you would still need either ota tv or cable tv. ota is free basically rabbit ears antenna cable is of course cable wmc thus serverwmc would only show station that are avaliable to you.
mentasm 43 Posted January 21, 2014 Posted January 21, 2014 I've been digging around for TV logos for Australia. FInding it hard to find nice large logo files that will look nice in the web interface. When I get home I'll post the best links I found so far. Found some links on media portal site, wikipedia and on the overclockers.com.au forum. I was using a small program called My TV Logos which grabs logos for most of the common Aus stations, but they are quite small (96x96 I think)
Deihmos 170 Posted January 21, 2014 Posted January 21, 2014 Network tuners are the way to go. The HDhomerun refurbished cost 54 on newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16815345017
bloodtaker 71 Posted January 21, 2014 Author Posted January 21, 2014 I've been digging around for TV logos for Australia. FInding it hard to find nice large logo files that will look nice in the web interface. When I get home I'll post the best links I found so far. Found some links on media portal site, wikipedia and on the overclockers.com.au forum. I was using a small program called My TV Logos which grabs logos for most of the common Aus stations, but they are quite small (96x96 I think) get me a list of your stations and ill see if i can either make some or find some in higher quality for you
Deihmos 170 Posted January 21, 2014 Posted January 21, 2014 My channel logos xl grabs large channel logos. Sent from my HTC One using Tapatalk
bloodtaker 71 Posted January 21, 2014 Author Posted January 21, 2014 126 x 42 is not large logo inside the web site it would look rather small the ones i do are at least 400x200ish 400 is the width the hight is adjusted to keep aspect ration. I usually start out at 2000x what ever the aspect ratio of that logo is so it keeps it nice and crisp and clear
robsch 45 Posted January 23, 2014 Posted January 23, 2014 (edited) @@bloodtaker - Did you manually put the logos in, or did it do it automatically for you? I just set this up today and non of my channels have logos. I found some @ http://forum.xbmc.org/showthread.php?tid=86047 though was curious. Thanks Edited January 23, 2014 by robsch
bloodtaker 71 Posted January 24, 2014 Author Posted January 24, 2014 Manually I took large formated png images of the logos and downsized them where they were no more than 400 pixels wide hight depended on the aspect ratio of the logo
