racerx4100 0 Posted January 19, 2014 Posted January 19, 2014 Wanted to first say this is going to be a great product for sure. I have a couple of issues playing 3d files I hope someone can help. Since i have kind of a weird setup. I am using a HTPC connected to a optoma hd65 and an optma 3d-xl box. so I get 720p 3d. 3D Works great with Powerdvd13 that I am using. My difficulty comes when I want to play regular movies with just the built in player not 3d files. I want only 3d mkv's and mp4 files to just use powerdvd from withing MBT only. everything other mkv or mp4 to use the built-in player. I also cannot force it to exit powerdvd with the force on stop button in the external player config.when hitting the stop button in powerdvd. Powerdvd stays open. I can't seem to find the proper structure to incorporate this with command lines or such to make it work. Any Help would be appreciated.
A8HTPC 38 Posted January 20, 2014 Posted January 20, 2014 These are all known issues since, I, as well as others have experienced all the same difficulties. I'm sure it will be worked out eventually.
Davidtt485 6 Posted January 20, 2014 Posted January 20, 2014 To kill power dvd When you hit stop try adding -Termend to [Path} Line But yes i have the same 3D MKV issues as well.
