kwilcox 78 Posted December 21, 2016 Author Posted December 21, 2016 (edited) Installed and works great, direct play works too! Couple of cosmetic issues mainly dealing w/ Collections (blank box, can only highlight the top most pixels of blank box), and some of the recorded frame grabs in the browser don't scale properly. But functionally, everything seems to work well. Congrats on the release! Custom collections aren't supported yet. See post 3 for details. The blank box issue occurs on other items when there's no valid thumb image stored. I'll call that a bug and fix things so a default image is displayed. Edited December 21, 2016 by kwilcox
Heuer 76 Posted December 22, 2016 Posted December 22, 2016 (edited) I have a new TV with WebOS2 but the app is not appearing in the store and the web checker says it is incompatible. TV details are: Model: 24MT48S-PZS (UK version) - HD Ready 720p webOSTV Version: 2.1.0-3149 (beehive-bighorn) Any ideas? Edited December 22, 2016 by Heuer
anderbytes 141 Posted December 22, 2016 Posted December 22, 2016 I have a new TV with WebOS2 but the app is not appearing in the store and the web checker says it is incompatible. TV details are: Model: 24MT48S-PZS (UK version) - HD Ready 720p webOSTV Version: 2.1.0-3149 (beehive-bighorn) Any ideas? Same as mine. Probably our 2.0 are Pseudo 2.0 migrated from 1.0, not the real one.
kwilcox 78 Posted December 22, 2016 Author Posted December 22, 2016 I have a new TV with WebOS2 but the app is not appearing in the store and the web checker says it is incompatible. TV details are: Model: 24MT48S-PZS (UK version) - HD Ready 720p webOSTV Version: 2.1.0-3149 (beehive-bighorn) Any ideas? I believe its because your TV is not FullHD. Screenplay needs 1920x1080 screen resolution.
Yotengrit 1 Posted December 22, 2016 Posted December 22, 2016 I also cannot find it in the store. Is it possible that it is not available in Hungary?
anderbytes 141 Posted December 22, 2016 Posted December 22, 2016 I believe its because your TV is not FullHD. Screenplay needs 1920x1080 screen resolution. Mine is... and it doesn't appear, also.
wilko834 0 Posted December 22, 2016 Posted December 22, 2016 Hello !! Available for model 55EG910V ? Available in France ?
Heuer 76 Posted December 22, 2016 Posted December 22, 2016 I believe its because your TV is not FullHD. Screenplay needs 1920x1080 screen resolution. Back to Plex!
Yotengrit 1 Posted December 22, 2016 Posted December 22, 2016 Okay I tried to change the location to United Kingdom in the TV`s settings and now there is a bunch new applications and media in the store but searching on Emby or Screenplay yields no results, I also tried to look it up manually in the application browser but still nothing. Am I doing something wrong? - Thanks
kwilcox 78 Posted December 22, 2016 Author Posted December 22, 2016 (edited) If you can't see screenplay in your store, its most likely because because your TV doesn't meet the app requirements: FullHD resolution - 1920x1080 or higher Your TV shipped with WebOS2.0 or higher Check the app store for your region on a Web browser (go to www.lgappstv.com and select your region) then find the screenplay app by clicking on the "store" link and looking under new apps. If you click on screenplay you can check compatibility with your tv by providing the credentials you use to log into LG on your TV itself. If your TV shows as not compatible you can go to displayspecifications.com, and enter your TV model number. Once shown, does the display spec show at least 1920x1080? Now search the page for "WebOS". Does it show at least WebOS 2.0.? Edited December 22, 2016 by kwilcox
woozle 2 Posted December 22, 2016 Posted December 22, 2016 I get that you wouldn't necessarily WANT to support less than FullHD, but are you saying that it's very specifically ONLY for FullHD sets? Will it not appear for anyone who's got a 4K set? I'd always assumed it would be >= FullHD
kwilcox 78 Posted December 22, 2016 Author Posted December 22, 2016 (edited) yes, FullHD and WebOS2.0 are minimum specs. For people who can't see screenplay in their app store, follow the instructions above or on post #3 of this thread. Let me know your model number and your region if displaystats.com shows your TV as having at least WebOS2.0 and 1920x1080 resolution. Edited December 22, 2016 by kwilcox
iMan 0 Posted December 23, 2016 Posted December 23, 2016 (edited) I get that you wouldn't necessarily WANT to support less than FullHD, but are you saying that it's very specifically ONLY for FullHD sets? Will it not appear for anyone who's got a 4K set? I'd always assumed it would be >= FullHD I can confirm that works in 4K TVs. I'm running it in LG 43UH620V WebOS 3.0 without any issue here in Spain... Edited December 23, 2016 by iMan
mastrmind11 722 Posted December 23, 2016 Posted December 23, 2016 I can confirm it works on 4K TVs and webOS 2.0 as well.
jaytea33 0 Posted December 23, 2016 Posted December 23, 2016 App has been working great on my 55UH6030 but I think my roommate is SOL for his 43LH5700. It supports 1920 x 1080 and the OS looks very similar to webOS 3.0 but despite being a 2016 model TV, the OS just says "Smart TV" on displayspecifications and it seems like a super gimped version of webOS. Bummer.
johnbury 4 Posted December 24, 2016 Posted December 24, 2016 @@kwilcox As ever, loving Screenplay! Thanks! I have a couple of minor observations. Situation: I have restarted my PC (Emby Server platform) but have forgotten to restart Emby Server (I chose manual start as a personal preference). When i next start Screenplay, it asks again for my Emby Server (name or IP address). If I then restart Emby Server, I cannot get around the Screenshow request to re-enter my server details. 'Closing' (can you close an app on WebOS3?) and restarting the app doesn't re-check for my server, nor does choosing another app then going back to Screenplay. Am I missing something? If backdrop images are missing from my TV Show folders, random backdrops from other shows are displayed... is this by design? Cheers
kwilcox 78 Posted December 24, 2016 Author Posted December 24, 2016 (edited) I've seen the odd behavior of your first observation too. Not sure what causes it; but its in the WebOS built-in AJAX routines somewhere. It may be related to emby server restarting when the first connect attempt is made. Your second observation is indeed by design. screenplay throws up a random backdrop if there's nothing for the particular item. Random backdrops happen on other screens also. Edited December 24, 2016 by kwilcox
johnbury 4 Posted December 24, 2016 Posted December 24, 2016 Thanks for the repl, the first is a bit of a pain, but not insurmountable. The other, it's a half decent warning that my metadata isn't complete! Have a great Xmas, you've earnt it! Cheers
lifenight 0 Posted December 25, 2016 Posted December 25, 2016 (edited) I have a 55lb650V-ZN, full hd of course but web os 1 My tv is only two year old ... why do not cover all webos versions ? Xplay work great on this, have you any plan to port on this system ? Edited December 25, 2016 by lifenight
Chrixr 0 Posted December 26, 2016 Posted December 26, 2016 My TV is 49LF5900 Full HD webOS 2.1.0-3151 (beehive-bighorn), but the app does not appear. On the page (lgappstv.com) says that my TV is not compatible. By the way, I'm from Mexico.
kwilcox 78 Posted December 26, 2016 Author Posted December 26, 2016 I have a 55lb650V-ZN, full hd of course but web os 1 My tv is only two year old ... why do not cover all webos versions ? Xplay work great on this, have you any plan to port on this system ? WebOS 1.0 doesn't support HLS sadly.
kwilcox 78 Posted December 26, 2016 Author Posted December 26, 2016 My TV is 49LF5900 Full HD webOS 2.1.0-3151 (beehive-bighorn), but the app does not appear. On the page (lgappstv.com) says that my TV is not compatible. By the way, I'm from Mexico. Good question. App is available in Mexico (8 downloads yesterday) and your TV appears to be compatible. I've sent the following inquiry to LG: I have a report from an owner in Mexico that his LG 49LF5900 (FullHD - 1920x1080, WebOS 2) was incompatible with screenplay when he checked on the lgappstv site. For this reason, he cannot see screenplay in his app store either. Can you tell me why this is? I'll let you know what their reply is.
LuckyLukeX 1 Posted December 26, 2016 Posted December 26, 2016 (edited) It works on a LG 55EF950V with WebOS 2.0; Italy LG app store.I'm waiting for the subtitles on/off feature ... I think could be a good improvement! There's a way to also list the name of the movie while browsing? Thanks a lot and great job!Luke Edited December 26, 2016 by LuckyLukeX
kwilcox 78 Posted December 27, 2016 Author Posted December 27, 2016 On most screens, the name of any highlighted movie is shown on the lower left. I'm working on subtitles now...
Jonz 11 Posted December 27, 2016 Posted December 27, 2016 Are u possibly looking into providing an option to change the view to a List View with perhaps smaller posters. Kinda challenging to scroll thru the tiles with hundreds of media around.
