RobsterUK 23 Posted October 13, 2020 Posted October 13, 2020 As an early adopter of Emby on an Xpenology system running DSM 5.2 5967 for about 4 years. Just wanted to report that I have finally upgraded my NAS. I actually purchased new hardware and migrated the whole system, by backup & restore methods. So I am now running DSM 6.2.3 25426. I've installed the .Net 4.5.2 server using the x64 .spk (Intel i38100 CPU) without a hitch! Not sure if anyone else is still on DSM 5.2 there may have been some others early days. This may affect future development if you no longer have to consider the older DSM versions. I'm sure there used to be a thread somewhere about which version members were running, but I can't find it.
Luke 42239 Posted October 13, 2020 Posted October 13, 2020 11 minutes ago, RobsterUK said: As an early adopter of Emby on an Xpenology system running DSM 5.2 5967 for about 4 years. Just wanted to report that I have finally upgraded my NAS. I actually purchased new hardware and migrated the whole system, by backup & restore methods. So I am now running DSM 6.2.3 25426. I've installed the .Net 4.5.2 server using the x64 .spk (Intel i38100 CPU) without a hitch! Not sure if anyone else is still on DSM 5.2 there may have been some others early days. This may affect future development if you no longer have to consider the older DSM versions. I'm sure there used to be a thread somewhere about which version members were running, but I can't find it. Hi, that's great info, thanks !
ltworf13 3 Posted November 9, 2020 Posted November 9, 2020 Hi All hoping someone can help me here. DS3615xs DSM 6.1.7-15284 2018/05/19 INTL Core i3 Running Emby Server Version 4.4.3.0, with remove enabled My problem is my family members remotely constantly getting kicked out or can't connect at all one minute then fine the next after a reboot my server. How can I troubleshoot the issue. I see that there's a message on the Dashboard that there's a new version but my thoughts are that if this is an issue now I don't think an updated version with solve this. I could be wrong LOL. Please help, my family members that are using this can't afford cable so I opened up my Emby server to help them out
DJIemby 8 Posted November 9, 2020 Posted November 9, 2020 Sounds to me your server and/or upload connection cannot handle the amount of data your family is trying to watch. If they are transcoding then your server is having to work more so will slow things down. Have you trialled different bitrates for the remote users and check in dashboard for stats on stream?
ltworf13 3 Posted November 9, 2020 Posted November 9, 2020 1 hour ago, DJIemby said: Sounds to me your server and/or upload connection cannot handle the amount of data your family is trying to watch. If they are transcoding then your server is having to work more so will slow things down. Have you trialled different bitrates for the remote users and check in dashboard for stats on stream? Can you tell me please how to set their bitrates. I'm on gigabyte plan. however, I'll do a speed test maybe there's an issue with my ISP. What should the setting be for the transcode. I've tried a few settings but to be honest I have no idea what each setting is doing. I did see once that one user was showing direct play and the other was transcoding. But when they can't even connect what should I be troubleshooting/setting for that, please and thank you in advance
ltworf13 3 Posted November 9, 2020 Posted November 9, 2020 (edited) 58 minutes ago, ltworf13 said: Can you tell me please how to set their bitrates. I'm on gigabyte plan. however, I'll do a speed test maybe there's an issue with my ISP. What should the setting be for the transcode. I've tried a few settings but to be honest I have no idea what each setting is doing. I did see once that one user was showing direct play and the other was transcoding. But when they can't even connect what should I be troubleshooting/setting for that, please and thank you in advance my speed it very low I should be on 1 gigabit and I'm only getting 379 download and 33 upload. I also checked my router and for some reason I have two port fwd setup one with 8290 and the other with 8096 which is the correct one. I'm on with my ISP now to look into the speed and I've delete the other port. Also along with Port fwd do I need to set a virtual server? Edited November 9, 2020 by ltworf13
ltworf13 3 Posted November 9, 2020 Posted November 9, 2020 So far my son can connect backup again but I'm not sure if it's because I reboot the server and/or because I removed the second port I had for Emby. still waiting on my ISP to chat with regarding my speed. My son is testing playing a 4k MKV 4gb file and the dashboard shows as follows:
ltworf13 3 Posted November 9, 2020 Posted November 9, 2020 (edited) 45 minutes ago, ltworf13 said: So far my son can connect backup again but I'm not sure if it's because I reboot the server and/or because I removed the second port I had for Emby. still waiting on my ISP to chat with regarding my speed. My son is testing playing a 4k MKV 4gb file and the dashboard shows as follows: Both my son and I were running fine remotely then he got kick off. I stopped playing the file closed the app on my phone then I too could not connect so frustrating I don't know what the issue is. Speedtest wise. my ISP said the 1 gig is cumulative based on the number of devices connected in the home. Still doesn't explain the 378 speed. Edited November 9, 2020 by ltworf13
ltworf13 3 Posted November 9, 2020 Posted November 9, 2020 just discovered something but I'm not sure how to resolve. With my Xpenology after I rebooted my server and testing the Control Pannel>>Router Configuration which passed. My son was then able to access as usual either via Emby Connect or the App. Then when he was kicked out I reran the test and the connection shows failed.
DJIemby 8 Posted November 9, 2020 Posted November 9, 2020 are you both logging on with different accounts with same privileges? Both Test some 1080p files from your mobile on 4g etc to see what happens. Its your upload speed that matters not your download speed when playing files remotely. More than likely sounds like a speed issue or maybe your server cannot keep up with numerous connections.
ltworf13 3 Posted November 9, 2020 Posted November 9, 2020 1 hour ago, DJIemby said: are you both logging on with different accounts with same privileges? Both Test some 1080p files from your mobile on 4g etc to see what happens. Its your upload speed that matters not your download speed when playing files remotely. More than likely sounds like a speed issue or maybe your server cannot keep up with numerous connections. yes different accounts. Not sure what you mean about with same privileges?. We were both connected me via LTE and him via wifi at his house. both running a small 4k file for an hour no issues. then my DSM port fwd fails and we both lose connection.
ltworf13 3 Posted November 10, 2020 Posted November 10, 2020 RESOLVED! I was unaware that in the router I not only needed to add a port trigger but also the virtual server within the port forwarding configuration. I was under the impression that the virtual server section was for those servers that are set up with VMware so I initially ignore that section
Gonzoide 0 Posted January 17, 2021 Posted January 17, 2021 Hi, Trying to launch Emby installed from XPenology repo on my HP Proliant (AMD Turion(tm) II Neo N40L Dual-Core Processor) fails (button back to "Launch"). rundiags show the following issues : - find: `/var/packages/EmbyServer/target/3rdparty/imagemagick/*': No such file or directory ./rundiags: line 605: 15720 Aborted (core dumped) ${pkg_default_mono_root}/bin/ikdasm $version/EmbyServer.exe -assembly &> ${output_file} (SIGKILL received) Would anybody know what the problem is ? Thanks. rundiags.log
Luke 42239 Posted January 18, 2021 Posted January 18, 2021 7 hours ago, Gonzoide said: Hi, Trying to launch Emby installed from XPenology repo on my HP Proliant (AMD Turion(tm) II Neo N40L Dual-Core Processor) fails (button back to "Launch"). rundiags show the following issues : - find: `/var/packages/EmbyServer/target/3rdparty/imagemagick/*': No such file or directory ./rundiags: line 605: 15720 Aborted (core dumped) ${pkg_default_mono_root}/bin/ikdasm $version/EmbyServer.exe -assembly &> ${output_file} (SIGKILL received) Would anybody know what the problem is ? Thanks. rundiags.log 14.97 kB · 0 downloads Hi there, did you follow the installation instructions on our website? https://emby.media/synology-server.html
Gonzoide 0 Posted January 18, 2021 Posted January 18, 2021 (edited) No, I actually used the repo https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 since I'm using Xpenology Symptoms identical to Andythediver on page 6 Edited January 18, 2021 by Gonzoide
Luke 42239 Posted January 18, 2021 Posted January 18, 2021 3 hours ago, Gonzoide said: No, I actually used the repo https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 since I'm using Xpenology Symptoms identical to Andythediver on page 6 Hi, that is obsolete now. Please use the instructions on our website: https://emby.media/synology-server.html Thanks.
Luke 42239 Posted January 19, 2021 Posted January 19, 2021 4 hours ago, Gonzoide said: Perfect, it worked ! Thanks Thanks for the feedback !
evor190562 0 Posted July 30, 2021 Posted July 30, 2021 Hi Noticed emby said that new version on server page. does emby still support DSM 5 on xpenology on a HP54l AMD not sure which one to use from the list tried 64bit and 32bit but both rejected 64-bit NAS ARMv8 (x18 Series) ARMv7 - Supported models: armada375: DS115, DS215j armada38x: DS419slim, DS218j, RS217, DS116, DS216j, DS216, DS416j, DS416slim, RS816 comcerto2k: DS414j monaco: DS216play ARMv7 (all other ARMv7 models) ARMv5 32-bit (X86) If newer versions are not being supported for DSM 5 is there a link to upload last supported version,
Luke 42239 Posted August 1, 2021 Posted August 1, 2021 On 7/30/2021 at 2:29 PM, evor190562 said: Hi Noticed emby said that new version on server page. does emby still support DSM 5 on xpenology on a HP54l AMD not sure which one to use from the list tried 64bit and 32bit but both rejected 64-bit NAS ARMv8 (x18 Series) ARMv7 - Supported models: armada375: DS115, DS215j armada38x: DS419slim, DS218j, RS217, DS116, DS216j, DS216, DS416j, DS416slim, RS816 comcerto2k: DS414j monaco: DS216play ARMv7 (all other ARMv7 models) ARMv5 32-bit (X86) If newer versions are not being supported for DSM 5 is there a link to upload last supported version, Hi, our packages have always been based on at least DSM 6. You might be able to get lucky and find an older version that will work with DSM 5, but I don't know how far back you'd have to go.
evor190562 0 Posted August 1, 2021 Posted August 1, 2021 2 hours ago, Luke said: Hi, our packages have always been based on at least DSM 6. You might be able to get lucky and find an older version that will work with DSM 5, but I don't know how far back you'd have to go. Hi Thanks thought that might be the case. The version on the machine works just that I noticed there was another version available. Assumed it was still auto updating from the repository.
Bobby121418 17 Posted October 16, 2021 Posted October 16, 2021 Hi I have posted to another thread but maybe here is more appropriate. I have recently been testing xpenology on an old machine. I have AMD Athlon II X2 250 with 4GB of ram running DSM 6.2.3-25426 update 3 running as ds3617xs. I have installed emby server for Synology 64 bit latest. I cannot seem to stream to more than one stream of x264 video or to more than one evice. Is there a way to improve this? Also I realise this is an old hardware but would hardware transcoding be possible? Many thanks
Luke 42239 Posted October 16, 2021 Posted October 16, 2021 1 minute ago, Bobby121418 said: Hi I have posted to another thread but maybe here is more appropriate. I have recently been testing xpenology on an old machine. I have AMD Athlon II X2 250 with 4GB of ram running DSM 6.2.3-25426 update 3 running as ds3617xs. I have installed emby server for Synology 64 bit latest. I cannot seem to stream to more than one stream of x264 video or to more than one evice. Is there a way to improve this? Also I realise this is an old hardware but would hardware transcoding be possible? Many thanks Re:
Lotusd 0 Posted January 19, 2022 Posted January 19, 2022 Hi, what would be the reason of non starting the server. It stopped one day after reboot of my Xpenology and never up. I have upgraded to the latest version from the instructions above manually, but the server does not start anyway. Please help before my kids killed me ))
Luke 42239 Posted January 20, 2022 Posted January 20, 2022 20 hours ago, Lotusd said: Hi, what would be the reason of non starting the server. It stopped one day after reboot of my Xpenology and never up. I have upgraded to the latest version from the instructions above manually, but the server does not start anyway. Please help before my kids killed me )) HI there, what happens when you try to start the server?
