Luke 42239 Posted March 29, 2020 Posted March 29, 2020 hi im currently running version 4.3.1.0 how do i update to Version 4.4.0.40, i check and dont see any update on synology package thanks Hi, it's coming, apologies for the delay.
FaNaTiK 0 Posted June 9, 2020 Posted June 9, 2020 (edited) Hello. Please help. My page with Emby server does not open http://192.168.1.111:8096/web/dashboard.html I have XPENOLOGY DSM 6.2-23739 on INTEL ATOM D525. It is displayed as INTEL Xeon D-1527 in DSM. I installed Emby server 4.4.3.0-1, using https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 repo link. When I start the server, the page opens in the browser, but it gives an error that it is not available. And yet, after installation, the server does not start on its own, I start it, after that an icon appears in the main menu, but after a few minutes it disappears. What me to do? Edited June 10, 2020 by FaNaTiK
Luke 42239 Posted June 22, 2020 Posted June 22, 2020 On 6/9/2020 at 2:36 PM, FaNaTiK said: Hello. Please help. My page with Emby server does not open http://192.168.1.111:8096/web/dashboard.html I have XPENOLOGY DSM 6.2-23739 on INTEL ATOM D525. It is displayed as INTEL Xeon D-1527 in DSM. I installed Emby server 4.4.3.0-1, using https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 repo link. When I start the server, the page opens in the browser, but it gives an error that it is not available. And yet, after installation, the server does not start on its own, I start it, after that an icon appears in the main menu, but after a few minutes it disappears. What me to do? We'll help you in your topic: Thanks.
figueroa34 0 Posted June 29, 2020 Posted June 29, 2020 hola necesito mucha ayuda llevo mas de una semana intentando usar emby y no logro hacer que funcione por favor he pagano emby pero no lo puedo usar ayudeme he instalado y desinstalado el sistema tambien con embi cambie de version de synology, no logre instalar los otros sistemas. Quote BusyBox v1.16.1 (2016-04-26 17:25:22 CST) built-in shell (ash) Enter 'help' for a list of built-in commands. STREAMGO> cd / var / packages / EmbyServer / scripts / utilities STREAMGO> sudo ./rundiags -ash: sudo: not found STREAMGO> ./rundiags -ash: ./rundiags: not found STREAMGO> cd/var/packages/EmbyServer/scripts/utilities -ash: cd/var/packages/EmbyServer/scripts/utilities: not found STREAMGO> cd /var/packages/EmbyServer/scripts/utilities STREAMGO> ./rundiags ******************************************************************************** Script invoked as [./rundiags] by [root]. File Version : 4.4.3.0-1 ******************************************************************************** This script will report on the currently installed package's configuration and collect system information related to its performance and operation. PLEASE ONLY USE AS DIRECTED BY SUPPORT Type [yes] and press return to continue: yes -------------------------------------------------------------------------------- Getting platform information: >> Platform : Linux STREAMGO 3.10.35 #1 SMP Sun Jul 17 16:02:22 CEST 2016 x86_64 GNU/Linux synology_bromolow_3615xs >> DSM Version : 5.2-5967 Update 0 [5.2.3|hotfix|2016/04/26|16:29:13] -------------------------------------------------------------------------------- Getting hardware information: -> System... OK streamgo description: Desktop Computer product: 945GCMX-S2 vendor: Gigabyte Technology Co., Ltd. width: 4294967295 bits capabilities: smbios-2.4 dmi-2.4 smp vsyscall32 configuration: boot=normal chassis=desktop uuid=00000000-0000-0000-0000-0011322CA603 -> Processor... OK *-cpu description: CPU product: Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz vendor: Intel Corp. physical id: 4 bus info: cpu@0 version: Intel(R) Core(TM)2 CPU 430 slot: Socket 775 size: 1800MHz capacity: 4GHz width: 64 bits clock: 200MHz capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl est tm2 ssse3 cx16 xtpr pdcm lahf_lm dtherm cpufreq -> Memory... OK *-firmware description: BIOS vendor: Award Software International, Inc. physical id: 0 version: F4 date: 05/24/2007 size: 128KiB capacity: 448KiB capabilities: pci pnp apm upgrade shadowing cdboot bootselect edd int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification *-cache:0 description: L1 cache physical id: 8 slot: Internal Cache size: 64KiB capacity: 64KiB capabilities: synchronous internal write-back configuration: level=1 *-cache:1 description: L2 cache physical id: 9 slot: External Cache size: 2MiB capacity: 2MiB capabilities: synchronous internal write-back configuration: level=2 *-memory description: System Memory physical id: 19 slot: System board or motherboard size: 2GiB capacity: 2GiB *-bank:0 description: DIMM [empty] product: None vendor: None physical id: 0 serial: None slot: A0 *-bank:1 description: DIMM 667 MHz (1.5 ns) product: None vendor: None physical id: 1 serial: None slot: A1 size: 2GiB width: 64 bits clock: 667MHz (1.5ns) -> CPUinfo... OK -> Looking for DRM devices... NONE -------------------------------------------------------------------------------- Available version(s) of MONO: -> 6.8.0.105 Available version(s) of SQLITE: -> 3.31.1 Available version(s) of IMAGEMAGICK: find: /var/packages/EmbyServer/target/3rdparty/imagemagick/*: No such file or directory Available version(s) of FFMPEG: -> 0.0.0 -> 4.3.0 -------------------------------------------------------------------------------- Validating version(s) of MONO: -> 6.8.0.105 OK Mono JIT compiler version 6.8.0.105 (tarball Sun Mar 29 22:53:48 UTC 2020) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: __thread SIGSEGV: normal Notifications: epoll Architecture: amd64 Disabled: none Misc: softdebug Interpreter: yes LLVM: supported, not enabled. Suspend: hybrid GC: sgen (concurrent by default) Validating version(s) of SQLITE: -> 3.31.1 OK 3.31.1 2020-01-27 19:55:54 3bfa9cc97da10598521b342961df8f5f68c7388fa117345eeb516eaa837bb4d6 Validating version(s) of IMAGEMAGICK: find: /var/packages/EmbyServer/target/3rdparty/imagemagick/*: No such file or directory Validating version(s) of FFMPEG: -> 0.0.0 OK Execution Date: 2020-06-29 13:28:00 ffmpeg version 4.3.0-emby_2020_02_24-20200407T105745UTC Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC built with gcc 7.3.0 (GCC) configuration: --prefix=/var/packages/EmbyServer/target/ffmpeg --enable-cross-compile --cross-prefix=x86_64-syno-linux-gnu- --target-os=linux --disable-rpath --enable-pthreads --arch=x86_64 --enable-libzimg --disable-libmfx --enable-vaapi --enable-x86asm --enable-gpl --enable-shared --disable-static --disable-debug --disable-ffplay --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --enable-gnutls --enable-libass --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libfreetype --enable-fontconfig --enable-gray --enable-libfribidi --enable-libvidstab --enable-libzvbi --disable-indev=sndio --disable-outdev=sndio --extra-version=20200407T105745UTC --extra-libs='-luuid -lstdc++' libavutil 56. 36.100 / 56. 36.100 libavcodec 58. 62.100 / 58. 62.100 libavformat 58. 35.100 / 58. 35.100 libavdevice 58. 9.101 / 58. 9.101 libavfilter 7. 67.100 / 7. 67.100 libswscale 5. 6.100 / 5. 6.100 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 -> 4.3.0 OK Execution Date: 2020-06-29 13:28:01 ffmpeg version 4.3.0-emby_2020_02_24-20200407T105745UTC Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC built with gcc 7.3.0 (GCC) configuration: --prefix=/var/packages/EmbyServer/target/ffmpeg --enable-cross-compile --cross-prefix=x86_64-syno-linux-gnu- --target-os=linux --disable-rpath --enable-pthreads --arch=x86_64 --enable-libzimg --disable-libmfx --enable-vaapi --enable-x86asm --enable-gpl --enable-shared --disable-static --disable-debug --disable-ffplay --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --enable-gnutls --enable-libass --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libfreetype --enable-fontconfig --enable-gray --enable-libfribidi --enable-libvidstab --enable-libzvbi --disable-indev=sndio --disable-outdev=sndio --extra-version=20200407T105745UTC --extra-libs='-luuid -lstdc++' libavutil 56. 36.100 / 56. 36.100 libavcodec 58. 62.100 / 58. 62.100 libavformat 58. 35.100 / 58. 35.100 libavdevice 58. 9.101 / 58. 9.101 libavfilter 7. 67.100 / 7. 67.100 libswscale 5. 6.100 / 5. 6.100 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 -------------------------------------------------------------------------------- Checking symlink for component MONO is valid and getting target: -> LOCAL : 3rdparty/mono/6.8.0.105 -> ACTUAL: /volume1/@appstore/EmbyServer/3rdparty/mono/6.8.0.105 PASSED Checking symlink for component SQLITE is valid and getting target: -> LOCAL : 3rdparty/sqlite/3.31.1 -> ACTUAL: /volume1/@appstore/EmbyServer/3rdparty/sqlite/3.31.1 PASSED Checking symlink for component IMAGEMAGICK is valid and getting target: FAILED Checking symlink for component FFMPEG is valid and getting target: -> LOCAL : 3rdparty/ffmpeg/4.3.0 -> ACTUAL: /volume1/@appstore/EmbyServer/3rdparty/ffmpeg/4.3.0 PASSED -------------------------------------------------------------------------------- Available version(s) of Emby Server: -> 4.4.3.0 -------------------------------------------------------------------------------- Validating Emby Server version(s): -> 4.4.3.0 Aborted FAILED ================================================================= Native Crash Reporting ================================================================= Got a SIGILL while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= ================================================================= Native stacktrace: ================================================================= 0x4b6094 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x4b642c - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x464ae9 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x431492 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x7f7e96f13330 - /var/packages/EmbyServer/target/system/lib/libpthread.so.0 : (null) 0x6ba73d - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x6ba824 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x6b2463 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x68e453 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x57ef24 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x434a1b - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x43ac31 - /var/packages/EmbyServer/target/mono/bin/mono : mono_main 0x42b953 - /var/packages/EmbyServer/target/mono/bin/mono : (null) 0x7f7e96d50b37 - /var/packages/EmbyServer/target/system/lib/libc.so.6 : __libc_start_main 0x42c0ca - /var/packages/EmbyServer/target/mono/bin/mono : _start ================================================================= Telemetry Dumper: ================================================================= ================================================================= External Debugger Dump: ================================================================= mono_gdb_render_native_backtraces not supported on this platform, unable to find gdb or lldb ================================================================= Basic Fault Address Reporting ================================================================= Memory around native instruction pointer (0x6ba73d):0x6ba72d 11 00 90 66 0f 28 c2 31 d2 48 89 f0 f2 0f 5e c1 ...f.(.1.H....^. 0x6ba73d 66 0f 3a 0b c0 09 f2 0f 2c c8 48 63 c9 48 f7 f1 f.:.....,.Hc.H.. 0x6ba74d 48 83 e0 f8 48 3d 40 1f 00 00 49 0f 47 c2 44 39 H...H=@...I.G.D9 0x6ba75d c8 89 c2 74 26 48 85 ff 74 06 49 63 c8 89 04 8f ...t&H..t.Ic.... -------------------------------------------------------------------------------- Checking symlink for Emby Server is valid and getting target: -> LOCAL : releases/4.4.3.0 -> ACTUAL: /volume1/@appstore/EmbyServer/releases/4.4.3.0 PASSED -------------------------------------------------------------------------------- Searching for system provided version(s) of FFMPEG: -> /usr/syno/bin/ffmpeg 1 version(s) found. Searching for system provided version(s) of FFPROBE: No versions found. -------------------------------------------------------------------------------- Getting system provided FFMPEG version information: -> /usr/syno/bin/ffmpeg OK ffmpeg version 2.0.2 built on Apr 1 2016 12:34:23 with gcc 4.6.4 (crosstool-NG 1.19.0) configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=i686 --target-os=linux --cross-prefix=/usr/local/i686-pc-linux-gnu/bin/i686-pc-linux-gnu- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-vaapi --disable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/i686-pc-linux-gnu/bin/i686-pc-linux-gnu-ccache-gcc --enable-yasm --enable-libx264 --enable-encoder=libx264 libavutil 52. 38.100 / 52. 38.100 libavcodec 55. 18.102 / 55. 18.102 libavformat 55. 12.100 / 55. 12.100 libavdevice 55. 3.100 / 55. 3.100 libavfilter 3. 79.101 / 3. 79.101 libswscale 2. 3.100 / 2. 3.100 libswresample 0. 17.102 / 0. 17.102 libpostproc 52. 3.100 / 52. 3.100 Getting system provided FFPROBE version information: No versions found. -------------------------------------------------------------------------------- Listing open files for user [embysvr]: OK lsof: netlink UNIX socket msg peer info error ******************************************************************************** Diagnostic script run completed, the log can be viewed at the location below... /var/packages/EmbyServer/scripts/utilities/logs/rundiags_20200629T202734UTC.log ******************************************************************************** ese es el diagnostico Seria muy feliz si funora evite lo mas posible escribir por aqui pero viendo que ya estoy cansado pido su ayuda por favor que hago mi placa es: gigabyte fsb1066 ga-945gcmx-s2
Luke 42239 Posted July 25, 2020 Posted July 25, 2020 For those interested in trying something new, please try this: Thanks !
n00b42 41 Posted July 31, 2020 Posted July 31, 2020 Will the new synology packages utilize the same optimizations as the platform dependent xpenology packages? Or will we need specific packages as well? I am currently on "https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586&package_architecture=xpen-silvermont" at 4.4.3.0-1
Luke 42239 Posted August 1, 2020 Posted August 1, 2020 16 hours ago, n00b42 said: Will the new synology packages utilize the same optimizations as the platform dependent xpenology packages? Or will we need specific packages as well? I am currently on "https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586&package_architecture=xpen-silvermont" at 4.4.3.0-1 Yes they are. On the x64 side, all components are built to target generic x86_64 architecture, which includes SSE2 extensions. On the armv7 side, NEON extensions are included, and on the armv8 side every CPU is about the same so nothing special there. Typically, libraries that would benefit from more advanced CPU instructions (SSE4, AVX) like libx264 and libx265 use runtime CPU detection to dynamically use them even if the lib is targeting SSE2 only.
figueroa34 0 Posted August 1, 2020 Posted August 1, 2020 I achieved the installation with docker it was very simple the truth. it is working perfectly.
Andist 0 Posted August 11, 2020 Posted August 11, 2020 (edited) Why my latest version of emby server on xpenology stays "4.5.0.13-1-beta"? I have received the following notice: Please help me,thanks! (This is the hardware details of my device.) Edited August 11, 2020 by Andist
Luke 42239 Posted August 11, 2020 Posted August 11, 2020 15 hours ago, Andist said: Why my latest version of emby server on xpenology stays "4.5.0.13-1-beta"? I have received the following notice: Please help me,thanks! (This is the hardware details of my device.)
Andist 0 Posted August 12, 2020 Posted August 12, 2020 3 hours ago, Luke said: Thanks a lot!In fact I've seen the version released page(https://emby.media/community/index.php?/topic/21348-emby-latest-versions/), but I'm not sure if I can install x86_64 version of emby server. But I tried to upgrade today and succeeded!
DJIemby 8 Posted September 29, 2020 Posted September 29, 2020 With version 4.5.1.0 officially released now, which version do we use from the download section compared to our original package? I currently have installed and running 'sandybridge' package architecture.
Luke 42239 Posted September 29, 2020 Posted September 29, 2020 13 minutes ago, DJIemby said: With version 4.5.1.0 officially released now, which version do we use from the download section compared to our original package? I currently have installed and running 'sandybridge' package architecture. That's 32-bit, right? For now you'll have to stay with the package that you're on. We'll look at building a new 32-bit package. For now I'll revert the download page to the older instructions for 32-bit.
DJIemby 8 Posted September 30, 2020 Posted September 30, 2020 My Microserver has an Intel Xeon E3-1265L v2 Processor which is a 64bit professor not 32bit to my knowledge.
Luke 42239 Posted September 30, 2020 Posted September 30, 2020 11 minutes ago, DJIemby said: My Microserver has an Intel Xeon E3-1265L v2 Processor which is a 64bit professor not 32bit to my knowledge. Ok, then you'll use the 64-bit package.
DJIemby 8 Posted September 30, 2020 Posted September 30, 2020 Thanks Luke. I have successfully upgraded to 4.5.1.0 with 64bit package.
Luke 42239 Posted September 30, 2020 Posted September 30, 2020 5 hours ago, DJIemby said: Thanks Luke. I have successfully upgraded to 4.5.1.0 with 64bit package. Thanks for the feedback.
dnatand 4 Posted October 1, 2020 Posted October 1, 2020 (edited) When will new build be available for https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586&package_architecture=xpen-barcelona ? Currently still on 4.4.3.0-1. Edited October 1, 2020 by dnatand
Luke 42239 Posted October 1, 2020 Posted October 1, 2020 16 hours ago, dnatand said: When will new build be available for https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586&package_architecture=xpen-barcelona ? Currently still on 4.4.3.0-1. Hi, there are new installation instructions and they can be found here: https://emby.media/download Thanks.
dnatand 4 Posted October 1, 2020 Posted October 1, 2020 5 minutes ago, Luke said: Hi, there are new installation instructions and they can be found here: https://emby.media/download Thanks. To confirm, I will need to run a manual install as instructed on my AMD Turion based Xpenology? Do I need uninstall the current emby server (4.4.3.0-1) first? Synology X64 Download and install emby-server-synology_4.5.1.0_x86_64.spk – Install using the Synology web interface. – When the installation is over, launch the Emby Server application on your Synology.
Luke 42239 Posted October 5, 2020 Posted October 5, 2020 On 10/1/2020 at 12:40 PM, dnatand said: To confirm, I will need to run a manual install as instructed on my AMD Turion based Xpenology? Do I need uninstall the current emby server (4.4.3.0-1) first? Synology X64 Download and install emby-server-synology_4.5.1.0_x86_64.spk – Install using the Synology web interface. – When the installation is over, launch the Emby Server application on your Synology. @dnatand our package is not built to be Intel-specific, so yes it should work on Xpenology.
dnatand 4 Posted October 5, 2020 Posted October 5, 2020 2 hours ago, Luke said: @dnatand our package is not built to be Intel-specific, so yes it should work on Xpenology. Followed the new instruction and got upgraded to 4.5.1.0 successfully. Thanks!
Luke 42239 Posted October 5, 2020 Posted October 5, 2020 1 hour ago, dnatand said: Followed the new instruction and got upgraded to 4.5.1.0 successfully. Thanks! Thanks for the feedback.
