WiteWulf 0 Posted January 16, 2019 Posted January 16, 2019 Are you trying to get accurate metadata for movies with Spanish titles? If so, check that you have the correct language set for the library
adriaurora 0 Posted January 16, 2019 Posted January 16, 2019 Are you trying to get accurate metadata for movies with Spanish titles? If so, check that you have the correct language set for the library Yes, I have set Spanish for the library. And the metadata is working for almost every title. But it has a high percentage in the indexing which is done wrong (Compare to Plex), and the name and the year are correctly entitled. But thanks for the advice anyway.
Luke 42239 Posted January 16, 2019 Posted January 16, 2019 I will review your feedback and examples to see what changes we can make. Thanks !
solabc16 379 Posted January 16, 2019 Author Posted January 16, 2019 Thanks for your earlier feedback @@adriaurora, appreciated. Best - James
enekraso 0 Posted February 9, 2019 Posted February 9, 2019 Hello @@aquaporin4 Please can you run the diagnostics followed by the send logs utilities, details below:- https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Run-Diagnostics https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Once done, just post the reference here and I'll take a look. Thanks - James Dear James, with the same problem please help. Upload completed successfully, please include this filename with your ticket... sendlogs_NAS_synology_bromolow_3615xs_20190209T102538UTC.tgz Evgeny
solabc16 379 Posted February 10, 2019 Author Posted February 10, 2019 Hello @@enekraso Thanks for the logs, I'll get back to you shortly. Best - James
enekraso 0 Posted February 13, 2019 Posted February 13, 2019 Hello @@enekraso Thanks for the logs, I'll get back to you shortly. Best - James Dear James, thank you for reply. I'll be waiting. Evgeny
457992195 0 Posted February 19, 2019 Posted February 19, 2019 Hello, my motherboard is asrock j3455 - itx. When installing emby, use https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 or https://synology.emby.media/?
apejovic 0 Posted March 2, 2019 Posted March 2, 2019 Hey Guys, maybe u can help me, since update to 4.x my Emby is not working. HP N54L baremetal installation. DSM 5.2-5967 Version 3.x was working for me. Even HWT was working. A bit weak, due to CPU power, but good enough for me. I've tried also a new install. Nothing. I can't start the package to run. Could you provide the old package for download or a solution to fix this problem? Right now I'm not able to update my server due to an old vesion of a tool I'm using. thanks guys
Luke 42239 Posted March 2, 2019 Posted March 2, 2019 Hey Guys, maybe u can help me, since update to 4.x my Emby is not working. HP N54L baremetal installation. DSM 5.2-5967 Version 3.x was working for me. Even HWT was working. A bit weak, due to CPU power, but good enough for me. I've tried also a new install. Nothing. I can't start the package to run. Could you provide the old package for download or a solution to fix this problem? Right now I'm not able to update my server due to an old vesion of a tool I'm using. thanks guys Hi there, what happens when you try to start the server?
apejovic 0 Posted March 3, 2019 Posted March 3, 2019 Hey, sorry for my late response. I can't start package in DSM. Here is the log from the package centre: Maybe this helps you for troubleshooting. thank you so much
solabc16 379 Posted March 13, 2019 Author Posted March 13, 2019 (edited) Hello All If you're running an XPEnology system using DSM5 and have been experiencing the Emby Server package not stopping/starting correctly after an update - requiring the system to be rebooted, this should be resolved with the latest 4.0.3.0 release for XPEnology. As always, let us know how you get on... Best - James Edited March 13, 2019 by solabc16
solabc16 379 Posted March 13, 2019 Author Posted March 13, 2019 (edited) Hello @@apejovic Are you using the correct package for your processor? e.g. https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Custom-Package-Architectures-for-XPEnology Based on the above, you would need to use the 'barcelona' architecture for your AMD based system. e.g. https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586&package_architecture=xpen-barcelona Best - James Edited March 13, 2019 by solabc16
ai4666 0 Posted March 13, 2019 Posted March 13, 2019 (edited) 嗨, 我使用的是AMD 200GE CPU,并且已经有了一个首映键。 当我选择高级选项,任何解决方案时,Emby都找不到任何硬件解码器或编码器? already use https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586&package_architecture=xpen-barcelona and tried other sources, emby encodes and decoders still not working Edited March 13, 2019 by ai4666
solabc16 379 Posted March 13, 2019 Author Posted March 13, 2019 (edited) Hello @@ai4666 In the first instance, you would need an XPEnology implementation that included driver support for AMD's GPU. I'm not sure such an implementation exists at this time. Emby Server will not be able to find any encoder or decoders, until the system itself is able to provide access to the graphics h/w. Best - James Edited March 13, 2019 by solabc16
ai4666 0 Posted March 14, 2019 Posted March 14, 2019 thx, is there any XPEnology support ds3715 DS6.2.1? cant not find it after searching internet
apejovic 0 Posted March 16, 2019 Posted March 16, 2019 (edited) Thank you for you time James. requiring the system to be rebooted, I did this. Install it again, reboot, nothing. It doesn't start anymore. Hello @@apejovic Are you using the correct package for your processor? https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586&package_architecture=xpen-barcelona Yes, I'm using that repository from the beginning. I will try again a new install and check the repository, just to make sure, there is no mistake. Thank you James and all other Members for your help EDIT: Repository okAn update was shown. Installed, reboot, package not started. Not possible to start. Deinstallation, reboot, check repository again, is ok, download and install 4.0.3.0, reboot, package not started. Not possible to start. ANOTHER EDIT: I don't know what happend now, right now the package is running I tidy up the server and uninstalled some packages. Reboot. Emby is running. I will check for full function and come back here. But maybe within the next days. Thank you, whatever you did Edited March 16, 2019 by apejovic
solabc16 379 Posted March 26, 2019 Author Posted March 26, 2019 Hello @@apejovic Thanks for the updates, just checking in to see how you're getting on - everything still ok? If you are able to run the Send Logs utility, I'll take a look and check everything is in order. Details here : https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Best - James
solabc16 379 Posted March 26, 2019 Author Posted March 26, 2019 (edited) Hello @@ai4666 thx, is there any XPEnology support ds3715 DS6.2.1? cant not find it after searching internet Did you find what you were looking for? If not, the XPEnology forums would be the best starting point. Best - James Edited March 26, 2019 by solabc16
apejovic 0 Posted March 28, 2019 Posted March 28, 2019 Hello @@apejovic Thanks for the updates, just checking in to see how you're getting on - everything still ok? If you are able to run the Send Logs utility, I'll take a look and check everything is in order. Details here : https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Best - James Hey James, sorry for my late response. Everything is working now as far as I can see. I will sent a log file, as soon I'm back home. I'm working abroad till April 18. No SSH possible from outside. Thank you
neibol 0 Posted April 8, 2019 Posted April 8, 2019 (edited) Hi. XPnology with DSM 6.2 and DS3615XS in a micro ATOM in NETGEAR readynas312. Emby installs but does not start. Thank you sendlogs_SERNA2_synology_bromolow_3615xs_20190408T210059UTC.tgz Edited April 8, 2019 by neibol
xuxulll 0 Posted June 9, 2019 Posted June 9, 2019 Hi, Emby server could not start on my xpenology. The diagnostic file should be sendlogs_Xu-300_synology_apollolake_918+_20190609T004335UTC.tgz
Luke 42239 Posted June 9, 2019 Posted June 9, 2019 Hi, Emby server could not start on my xpenology. The diagnostic file should be sendlogs_Xu-300_synology_apollolake_918+_20190609T004335UTC.tgz Hi there @xuxull, what happened when you tried to start Emby Server? Thanks !
