solabc16 379 Posted November 30, 2017 Author Posted November 30, 2017 Hello @@ultimatevc Theoretically we shouldn't have any issues getting Emby Server running on your platform. To help us find out what is going on, can you run the diagnostics then the send logs utility. Details are here on the wiki:- https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Run-Diagnostics https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Best - James
frogger 0 Posted December 5, 2017 Posted December 5, 2017 Hi, I'm running a XPEnology DSM 6.1.3-15152 Update 8 on an older i7-920 bare metal rig. The previous Emby version (which installed just fine using https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586)was running smoothly until I tried to install the 3.2.40 update today. First off, updating to the latest version of Emby was not possible.The DSM package manager reported that the package download failed. The messages log contains the following corresponding errors: 2017-12-05T19:48:19+01:00 Helios synoscgi_SYNO.Core.Package.Thumb.Server_1_get[3527]: pkgimagetool.cpp:220 Wrong content type text/html; charset=UTF-8 in https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586/packages/synology/stable/3.2.40.0-1/EmbyServer_3.2.40.0-1_bromolow_thumb_72.png 2017-12-05T19:48:24+01:00 Helios synoscgi_SYNO.Core.Package.Installation_1_install[5088]: pkgserver.cpp:735 Warning: Failed to verify the package /volume1/@tmp/@synopkg/@download/EmbyServer/@SYNOPKG_DOWNLOAD_EmbyServer by MD5 ad9958e5c4e89c934236ad255d319ec1 2017-12-05T19:48:24+01:00 Helios synoscgi_SYNO.Core.Package.Installation_1_install[5088]: pkgserver.cpp:736 Warning: Failed to download EmbyServer from https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586/packages/synology/stable/3.2.40.0-1/EmbyServer_3.2.40.0-1_bromolow.spk 2017-12-05T19:48:24+01:00 Helios synoscgi_SYNO.Core.Package.Installation_1_install[5088]: pkgtool.cpp:1815 Failed to extract package INFO to /volume1/@tmp/qnWoZb 2017-12-05T19:48:24+01:00 Helios synoscgi_SYNO.Core.Package.Installation_1_install[5088]: pkgtool.cpp:1816 /bin/tar xf /volume1/@tmp/@synopkg/@download/EmbyServer/@SYNOPKG_DOWNLOAD_EmbyServer -C /volume1/@tmp/qnWoZb INFO --no-same-owner 2017-12-05T19:48:24+01:00 Helios synoscgi_SYNO.Core.Package.Installation_1_install[5088]: pkgtool.cpp:1862 Failed to query info 2017-12-05T19:48:24+01:00 Helios synoscgi_SYNO.Core.Package.Installation_1_install[5088]: pkgserver.cpp:747 Faild to download https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586/packages/synology/stable/3.2.40.0-1/EmbyServer_3.2.40.0-1_bromolow.spk After some experimenting with the repo link I managed to download EmbyServer_3.2.40.0-1_bromolow.spk and successfully installed it manually. I probably shouldn't have done that since Emby now refuses to start with no obvious errors in the log files. The start-stop-status log contains the following lines [2017-12-05 20:50:20 UTC] Script called with action [status]... [2017-12-05 20:50:20 UTC] >> PID file [/var/packages/EmbyServer/target/var/embysvr.pid] does not exist. [2017-12-05 20:50:20 UTC] >> Emby Server is not running. [2017-12-05 20:50:20 UTC] >> Exit status is [3]. [2017-12-05 20:50:20 UTC] Script called with action [log]... [2017-12-05 20:50:20 UTC] >> Returning log file location [/var/packages/EmbyServer/target/var/logs/start-stop-status_20171205.log]. [2017-12-05 20:50:20 UTC] >> Exit status is [0]. Diagnostic files here: sendlogs_Helios_synology_bromolow_3615xs_20171205T205238UTC.tgz Your help in fixing this issue is greatly appreciated!
solabc16 379 Posted December 6, 2017 Author Posted December 6, 2017 Hello @@frogger There's likely a couple of things going on here, firstly can you check that the certificate for the repository is still in place - see this post for details: https://emby.media/community/index.php?/topic/53177-cant-update-package-from-unknown-published/?p=514213. it looks like a DSM update on a small number of systems has been causing the certificate to 'disappear'. We haven't been able to produce this so far on any of our test/development systems. Best - James
frogger 0 Posted December 7, 2017 Posted December 7, 2017 Hi James, thanks for the hint. Based on that, I did some more experimenting and while the certificate was still in place it pointed me something else. For some unknown reason, DSM keeps adding a slash at the end of the URL. While this doesn't cause any issues for FQDN-only URLs like https://synology.emby.media/, doing so for an URL with GET parameters (?package_repository=360efc6e-de72-4073-b603-2bfbd7001586/) points curl to an unavailable location. Removing the trailing slash in /usr/syno/etc/packages/feeds and restarting the package manger solved the download issue. As a consequence a XPenology compatible Envy package gets downloaded and installed, which also resolves the non-startup issue. However, I've noticed that media will now more frequently hang for a couple of seconds when its being transcoded using the same resolution/bandwidth settings selected in the previous version. Can you please advise an architecture parameter and/or transcoder setting that more closely matches my i7-920 CPU? Alternatively, is there any way to download any previous version? I understand that rolling back a version can cause all kinds of issues but it would be nice to have the option (like a simple direct download archive), even if it means loosing the meta-data and starting from scratch. Again, thank you for your help!
HaiToo 0 Posted December 27, 2017 Posted December 27, 2017 Hi:@solabc16 The Celeron CPU,which one I select? or it can't work under this architecture? Logs: product: Intel® Celeron® CPU E3200 @ 2.40GHz vendor: Intel Corp. physical id: 4 bus info: cpu@0 version: Intel® Celeron® CPU E3200 @ 2.40GHz slot: LGA775 capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm xsave lahf_lm dtherm tpr_shadow vnmi flexpriority cpufreq configuration: cores=2 enabledcores=2 threads=2 thanks!!
genous5201314 0 Posted January 21, 2018 Posted January 21, 2018 (edited) Please let me know what I need to get this working on my hardware. Thanks. my xpenology running on DSM6.02-8451 rundiags_20180121T092019UTC.log Edited January 21, 2018 by genous5201314
matpez 0 Posted March 10, 2018 Posted March 10, 2018 Hi folks, newby user here... Installed emby from https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 And now I can`t get it to start... i did send log and this is file name sendlogs_Synology_synology_broadwell_3617xs_20180310T144919UTC.tgz Now, what to do to get it started? Thanks for your help in advance.
matpez 0 Posted March 10, 2018 Posted March 10, 2018 Hi folks, newby user here... Installed emby from https://synology.emby.media/?package_repository=360efc6e-de72-4073-b603-2bfbd7001586 And now I can`t get it to start... i did send log and this is file name sendlogs_Synology_synology_broadwell_3617xs_20180310T144919UTC.tgz Now, what to do to get it started? Thanks for your help in advance. Found it! If you take a look at this Wiki page - https://github.com/M...s-for-XPEnology, follow the instructions there and use the 'xpen-core2' alternate package architecture.
solabc16 379 Posted March 19, 2018 Author Posted March 19, 2018 Hello @@matpez Sorry for the delay in responding, great job on getting it sorted and thanks for letting us know. The 'xpen-core2' package is indeed the one optimised for your system. For other readers with XPEnology based systems, here's a couple of useful resources to help with identifying Core 2 based systems.... https://en.wikipedia.org/wiki/Intel_Core_2 https://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#%22Wolfdale-3M%22_(45_nm) Best - James
Beercules 0 Posted March 19, 2018 Posted March 19, 2018 FYI to anyone creating a XPENOLOGY server with EMBY I am using a E3-1275v and it works flawlessly with EMBY, followed the default synology instructions for install package and have access to Intel transcoding due to my xeon have a IGP. DSM 6.1x using Juno loader. My Specs below: Corsair 750d with 4 x HDD cages ASUS PS10WS Intel E3-1275 v6 8GB ECC memory LSI 9118-8i flashed in IT mode without bios for quick reboots 16GB Kingston USB3.0 as boot loader (size of a thumbnail) 2 x intel 520 120GB SSD 8 x 1TB WD Black 4 x 2TB Seagate 850watt PSU I use RAID1 for my SSDs and install all application on the SSD I use SHR-2 for my 8 x 1TB WD black HDD (6TB usable) primary library drive I use RAID10 for my 4 x 2TB Seagate HDD (4TB usable) backup drive Only change I have made is to the transcoding folder, I pointed to /dev/shm so it won't trash my SSD. I love the streamlined look of Plex but EMBY by far has better performance, and options. Thanks for all the hard work and supporting the Xpenology community. BEERCULES!
solabc16 379 Posted March 20, 2018 Author Posted March 20, 2018 Hello @@Beercules Thanks for the feedback, appreciated as always - great to hear h/w transcoding support is working for you on a DSM 6.1 based XPEnology system. The default package will work well on this CPU, although you may want to consider switching to the 'xpen-haswell' if you want to optimise further. See https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Custom-Package-Architectures-for-XPEnology for more details, and of course the opening post of this thread. We'll likely add support for newer Intel microarchitectures later this year. Best - James
Beercules 0 Posted March 20, 2018 Posted March 20, 2018 Hi James, Thanks for the suggestion but I think that would be a downgrade for me, I have the latest Kaby Lake Xeon that has a much better IGP for transcoding. I am currently working on a streamlined boot loader for my Xpenology that only has my dedicated hardware in it which will also include drivers for the latest IGP and Xeon processor, although I am considering moving Emby onto a dedicated server, just can't decided if I need ECC memory or not for the server. Beercules
solabc16 379 Posted March 20, 2018 Author Posted March 20, 2018 (edited) Hello @Beercules I think we may be at cross-purposes here, I'm referring to the software packages, which are optimised for different microarchitectures. The default XPEnology package is optimised for the 'nehalem' microarchitecture, as discussed here: https://emby.media/community/index.php?/topic/40411-xpenology-users-read-me/?p=377703 As you have a newer processor with additional features, you may want to consider switching to the 'xpen-haswell' package, which will take advantage of those features. Of course, dependent on your particular usage and workload, it may not prove significant - but good to know it's there, should you need it. Best - James EDIT: I initially wrote the default XPEnology package is optimised for the 'ivybridge' microarchitecture, where I of course meant 'nehalem'. Edited March 22, 2018 by solabc16 1
anonbro 1 Posted March 31, 2018 Posted March 31, 2018 (edited) Hello, I've installed Emby 3.3.1.0-1 on a brand new install of Xpenology with DSM 5.2-5967. The hardware running is a ex490 with 3 disks all running in basic mode with a volume on each disk. The package is visible in the app list and I've used the specific link given in the OP. However Emby doesn't want to start. I've ./rundiags and ./sendlogs which gave me the following filename : sendlogs_San_Datacenter_synology_bromolow_3615xs_20180331T195847UTC.tgz Let me know if can provide additionnal info. Thanks for your help, ---EDIT - adding some details on my CPU ~ # cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 22 model name : Intel(R) Celeron(R) CPU 450 @ 2.20GHz stepping : 1 microcode : 0x38 cpu MHz : 2194.767 cache size : 512 KB fpu : yes fpu_exception : yes cpuid level : 10 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss tm pbe syscall nx lm constant_ts c arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl tm2 s sse3 cx16 xtpr pdcm lahf_lm dtherm bogomips : 4389.53 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual I don't see a Conroe specific package for Xpenology so I suppose I am out of luck for this setup ? ---EDIT 2 - Got it working It runs OK with both xpen-core2-sse41 or xpen-core2. I am not very familliar with extended CPU flags, is there a version that would run better on my setup between these two ? Thanks, rundiags_20180405T192356UTC.zip Edited April 6, 2018 by anonbro
solabc16 379 Posted July 15, 2018 Author Posted July 15, 2018 Hello All Quick update, the XPEnology specific packages now support the DS916+ based loader - thanks to @@Joly0 for raising the issue. Best - James
solabc16 379 Posted July 18, 2018 Author Posted July 18, 2018 Hello Again As of stable release 3.5.0.0, XPEnology systems using the DS918+ based loader are also supported. Best - James
Pepa pig 1 Posted August 18, 2018 Posted August 18, 2018 Hello, i am using a hp proliant g8 with Xpenology dsm 5.2-5967 update 8 runs flawless e3-xeon 1260L 16gb of ram and had my server on a nvidia shied tv...but man what a diffrence
solabc16 379 Posted August 18, 2018 Author Posted August 18, 2018 Indeed, thanks @Pepa pig. Best - James 1
Pepa pig 1 Posted August 24, 2018 Posted August 24, 2018 Hello. Just updated to Dsm 6.2 o Man what a change that is. Works great. Emby server up to date and Just got a Emby premium account love it.. Only one thing thats not working for me. Is when i activate trailers for some strange reason the movie Will not play on my Sony xz premium. It stay's in loading mode Thanks and regards
Luke 42239 Posted August 24, 2018 Posted August 24, 2018 Hello. Just updated to Dsm 6.2 o Man what a change that is. Works great. Emby server up to date and Just got a Emby premium account love it.. Only one thing thats not working for me. Is when i activate trailers for some strange reason the movie Will not play on my Sony xz premium. It stay's in loading mode Thanks and regards Hi, can we look at an example? Thanks !
Pepa pig 1 Posted August 25, 2018 Posted August 25, 2018 Hi how do. i do that and i Just got a volley error also.. Gone cry now
Luke 42239 Posted August 25, 2018 Posted August 25, 2018 Please attach the information requested in how to report a problem: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/?view=getnewpost Thanks.
