MSattler 390 Posted October 18, 2016 Posted October 18, 2016 Latest Beta client on Nvidia Shield, connect to Surround Sound Receive via HDMI Client 1.2.66g Server: 3.1.191 Tried playing back a movie, and the movie plays back fine, but the audio does not come through for some reason. In other instances I have had to stop playback. Play the movie back elsewhere to get a new resume point. Then go back to the shield and play it, and it will work. It's almost as if for some reason the sound for the first remux isn't correct. While this movie is avi, this has happened with series as well that are mkv. Log: http://192.168.1.125:8096/emby/videos/7f0de1d291505305094edc45eb44ff50/stream.mkv?DeviceId=3a3c59cfbb737f78&MediaSourceId=7f0de1d291505305094edc45eb44ff50&VideoCodec=h264&AudioCodec=ac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=39872000&AudioBitrate=128000&MaxAudioChannels=6&StartTimeTicks=16366080000&Level=51&Profile=high&PlaySessionId=940a4199766648a2857eee7c9259fbca&api_key=ee7ef681eb444c0caa1a95ac1daf3415&CopyTimestamps=true&EnableSubtitlesInManifest=false&Tag=bae47ac609c4a028794ce92a453193b2&EnableSplittingOnNonKeyFrames=false{"Protocol":"File","Id":"7f0de1d291505305094edc45eb44ff50","Path":"\\\\tower\\kids\\Peter Pan\\Peter Pan.avi","Type":"Default","Container":"avi","Name":"SD/MPEG4/MP3","ETag":"bae47ac609c4a028794ce92a453193b2","RunTimeTicks":44620000000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"mpeg4","CodecTag":"XVID","TimeBase":"1/25","CodecTimeBase":"1/25","IsInterlaced":false,"BitRate":1192639,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":480,"Width":640,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Simple Profile","Type":"Video","AspectRatio":"4:3","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":3,"IsAnamorphic":false},{"Codec":"mp3","TimeBase":"32/1225","CodecTimeBase":"1/44100","DisplayTitle":"MP3 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":128000,"Channels":2,"SampleRate":44100,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"srt","Language":"eng","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"\\\\tower\\kids\\Peter Pan\\Peter Pan.eng.srt"}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":1332900,"RequiredHttpHeaders":{}}B:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -ss 00:27:16.608 -fflags +genpts -i file:"\\tower\kids\Peter Pan\Peter Pan.avi" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -avoid_negative_ts disabled -start_at_zero -preset 7 -look_ahead 0 -b:v 1192639 -maxrate 1192639 -bufsize 2385278 -vsync -1 -profile:v high -level 4.1 -map_metadata -1 -threads 0 -codec:a:0 copy -y "B:\Users\Administrator\AppData\Roaming\Emby-Server\transcoding-temp\transcoding-temp\c607a0207036a21a0bd15890939d4e8f.mkv"ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developersbuilt with gcc 5.3.0 (GCC)configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zliblibavutil 55. 20.100 / 55. 20.100libavcodec 57. 34.100 / 57. 34.100libavformat 57. 32.100 / 57. 32.100libavdevice 57. 0.101 / 57. 0.101libavfilter 6. 41.100 / 6. 41.100libswscale 4. 1.100 / 4. 1.100libswresample 2. 0.101 / 2. 0.101libpostproc 54. 0.100 / 54. 0.100Input #0, avi, from 'file:\\tower\kids\Peter Pan\Peter Pan.avi':Duration: 01:14:22.00, start: 0.000000, bitrate: 1332 kb/sStream #0:0: Video: mpeg4 (Simple Profile) (XVID / 0x44495658), yuv420p, 640x480 [sAR 1:1 DAR 4:3], 1192 kb/s, 25 fps, 25 tbr, 25 tbn, 25 tbcStream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16p, 128 kb/sOutput #0, matroska, to 'B:\Users\Administrator\AppData\Roaming\Emby-Server\transcoding-temp\transcoding-temp\c607a0207036a21a0bd15890939d4e8f.mkv':Metadata:encoder : Lavf57.32.100Stream #0:0: Video: h264 (h264_qsv) (H264 / 0x34363248), nv12, 640x480 [sAR 1:1 DAR 4:3], q=2-31, 1192 kb/s, 25 fps, 1k tbn, 25 tbcMetadata:encoder : Lavc57.34.100 h264_qsvSide data:cpb: bitrate max/min/avg: 1192639/0/1192639 buffer size: 2385278 vbv_delay: -1Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, 128 kb/sStream mapping:Stream #0:0 -> #0:0 (mpeg4 (native) -> h264 (h264_qsv))Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for helpframe= 339 fps=0.0 q=-0.0 size= 2240kB time=00:27:30.36 bitrate= 11.1kbits/s speed=3.29e+003xframe= 685 fps=684 q=-0.0 size= 4438kB time=00:27:44.20 bitrate= 21.8kbits/s speed=1.66e+003xframe= 1023 fps=681 q=-0.0 size= 6809kB time=00:27:57.74 bitrate= 33.2kbits/s speed=1.12e+003xframe= 1366 fps=682 q=-0.0 size= 8932kB time=00:28:11.45 bitrate= 43.3kbits/s speed= 845xframe= 1706 fps=682 q=-0.0 size= 11168kB time=00:28:25.06 bitrate= 53.7kbits/s speed= 681xframe= 2049 fps=682 q=-0.0 size= 13401kB time=00:28:38.78 bitrate= 63.9kbits/s speed= 572xframe= 2385 fps=681 q=-0.0 size= 15553kB time=00:28:52.20 bitrate= 73.6kbits/s speed= 494xframe= 2727 fps=681 q=-0.0 size= 17843kB time=00:29:05.89 bitrate= 83.7kbits/s speed= 436xframe= 3072 fps=682 q=-0.0 size= 19988kB time=00:29:19.68 bitrate= 93.1kbits/s speed= 391xframe= 3398 fps=679 q=-0.0 size= 22145kB time=00:29:32.74 bitrate= 102.3kbits/s speed= 354xframe= 3740 fps=679 q=-0.0 size= 24267kB time=00:29:46.41 bitrate= 111.3kbits/s speed= 324xframe= 4079 fps=679 q=-0.0 size= 26501kB time=00:29:59.96 bitrate= 120.6kbits/s speed=300xframe= 4422 fps=680 q=-0.0 size= 28588kB time=00:30:13.70 bitrate= 129.1kbits/s speed= 279xframe= 4756 fps=679 q=-0.0 size= 30767kB time=00:30:27.05 bitrate= 138.0kbits/s speed= 261xframe= 5099 fps=679 q=-0.0 size= 33036kB time=00:30:40.77 bitrate= 147.0kbits/s speed= 245xframe= 5438 fps=679 q=-0.0 size= 35215kB time=00:30:54.32 bitrate= 155.6kbits/s speed= 232xframe= 5767 fps=678 q=-0.0 size= 37475kB time=00:31:07.49 bitrate= 164.4kbits/s speed= 219xframe= 6103 fps=677 q=-0.0 size= 39618kB time=00:31:20.94 bitrate= 172.5kbits/s speed= 209xframe= 6444 fps=677 q=-0.0 size= 41860kB time=00:31:34.58 bitrate= 181.0kbits/s speed= 199xframe= 6776 fps=677 q=-0.0 size= 43946kB time=00:31:47.85 bitrate= 188.7kbits/s speed= 191xframe= 7120 fps=677 q=-0.0 size= 46159kB time=00:32:01.61 bitrate= 196.8kbits/s speed= 183xframe= 7447 fps=676 q=-0.0 size= 48235kB time=00:32:14.70 bitrate= 204.2kbits/s speed= 176xframe= 7765 fps=674 q=-0.0 size= 50370kB time=00:32:27.40 bitrate= 211.9kbits/s speed= 169xframe= 8071 fps=672 q=-0.0 size= 52288kB time=00:32:39.65 bitrate= 218.6kbits/s speed= 163xframe= 8403 fps=671 q=-0.0 size= 54484kB time=00:32:52.92 bitrate= 226.2kbits/s speed= 158xframe= 8717 fps=670 q=-0.0 size= 56496kB time=00:33:05.48 bitrate= 233.1kbits/s speed= 153xframe= 9031 fps=668 q=-0.0 size= 58513kB time=00:33:18.05 bitrate= 239.9kbits/s speed= 148xframe= 9338 fps=666 q=-0.0 size= 60453kB time=00:33:30.33 bitrate= 246.3kbits/s speed= 143xframe= 9640 fps=664 q=-0.0 size= 62478kB time=00:33:42.42 bitrate= 253.1kbits/s speed= 139xframe= 9942 fps=662 q=-0.0 size= 64480kB time=00:33:54.49 bitrate= 259.6kbits/s speed= 135xframe=10244 fps=660 q=-0.0 size= 66395kB time=00:34:06.56 bitrate= 265.8kbits/s speed= 132xframe=10584 fps=660 q=-0.0 size= 68597kB time=00:34:20.17 bitrate= 272.8kbits/s speed= 129xframe=10909 fps=660 q=-0.0 size= 70711kB time=00:34:33.18 bitrate= 279.4kbits/s speed= 125xframe=11218 fps=659 q=-0.0 size= 72657kB time=00:34:45.53 bitrate= 285.4kbits/s speed= 122xframe=11534 fps=658 q=-0.0 size= 74721kB time=00:34:58.18 bitrate= 291.7kbits/s speed= 120xframe=11845 fps=657 q=-0.0 size= 76788kB time=00:35:10.61 bitrate= 298.0kbits/s speed= 117xframe=12156 fps=656 q=-0.0 size= 78694kB time=00:35:23.05 bitrate= 303.6kbits/s speed= 115xframe=12472 fps=655 q=-0.0 size= 80754kB time=00:35:35.69 bitrate= 309.8kbits/s speed= 112xframe=12798 fps=655 q=-0.0 size= 82930kB time=00:35:48.72 bitrate= 316.2kbits/s speed= 110xframe=13125 fps=655 q=-0.0 size= 84938kB time=00:36:01.81 bitrate= 321.9kbits/s speed= 108xframe=13461 fps=656 q=-0.0 size= 87091kB time=00:36:15.24 bitrate= 328.0kbits/s speed= 106xframe=13790 fps=656 q=-0.0 size= 89337kB time=00:36:28.40 bitrate= 334.4kbits/s speed= 104xframe=14095 fps=655 q=-0.0 size= 91321kB time=00:36:40.60 bitrate= 340.0kbits/s speed= 102xframe=14403 fps=654 q=-0.0 size= 93207kB time=00:36:52.93 bitrate= 345.0kbits/s speed=100xframe=14715 fps=653 q=-0.0 size= 95165kB time=00:37:05.42 bitrate= 350.3kbits/s speed=98.8x
ebr 16354 Posted October 18, 2016 Posted October 18, 2016 It is passing the audio straight through. Sounds more like some sort of breakdown in the hdmi/audio chain.
MSattler 390 Posted October 18, 2016 Author Posted October 18, 2016 It is passing the audio straight through. Sounds more like some sort of breakdown in the hdmi/audio chain. Sure, I went that route too. Except that I get full audio through everything else. And when I reboot the Shield, and re-open Emby, it still persists. Rebooting Shield doesn't fix it. Turning TV on off doesn't fix it. Turning AVR on off doesn't fix it. What does fix it, is playing the show back on my phone, getting a new resume point. And then it magically works.
MSattler 390 Posted October 18, 2016 Author Posted October 18, 2016 Sure, I went that route too. Except that I get full audio through everything else. And when I reboot the Shield, and re-open Emby, it still persists. Rebooting Shield doesn't fix it. Turning TV on off doesn't fix it. Turning AVR on off doesn't fix it. What does fix it, is playing the show back on my phone, getting a new resume point. And then it magically works. And this only started happening with the last 4 or 5 beta's. Before that this was never an issue.
CBers 7576 Posted October 18, 2016 Posted October 18, 2016 I have had instances where, if I rewind a bit and then play, I get no audio. If I rewind again it usually comes back. Stopping/starting also fixes it most times. Always assumed it was just one of those things, so never reported it. This is all Direct/V playback.
Luke 42289 Posted October 18, 2016 Posted October 18, 2016 I would give it a try without Quick Sync in case that might be related.
MSattler 390 Posted October 18, 2016 Author Posted October 18, 2016 I have had instances where, if I rewind a bit and then play, I get no audio. If I rewind again it usually comes back. Stopping/starting also fixes it most times. Always assumed it was just one of those things, so never reported it. This is all Direct/V playback. Yeah, it has happened in those instances, although I rarely do that. Maybe it's time to see if MXPlayer works yet with TrueHD out on the shield. 1
Luke 42289 Posted October 18, 2016 Posted October 18, 2016 So it works when you don't start from the beginning?
MSattler 390 Posted October 18, 2016 Author Posted October 18, 2016 I would give it a try without Quick Sync in case that might be related. Um... would that really cause an issue here? It's only remuxing the sound, and the sound works on other occasions. This is a random event that just happens sometimes. Never had an issue with it before....
Luke 42289 Posted October 18, 2016 Posted October 18, 2016 Um... would that really cause an issue here? It's only remuxing the sound, and the sound works on other occasions. This is a random event that just happens sometimes. Never had an issue with it before.... You're probably right but right now we're just looking for information that might help.
ebr 16354 Posted October 18, 2016 Posted October 18, 2016 I have had instances where, if I rewind a bit and then play, I get no audio. If I rewind again it usually comes back. Stopping/starting also fixes it most times. Always assumed it was just one of those things, so never reported it. This is all Direct/V playback. Since he is transcoding his issue would be happening in the internal player. The fact that starting from a different point works is very strange. I would be sure and try what Luke suggested and turn off QS.
