Luke 42289 Posted January 21, 2014 Posted January 21, 2014 I don't think you're following me. We do support a series inside a collection..... We do support a series inside a collection. However, your second collection.xml file is forcing what is supposed to be a tv series into a collection instead. That is causing the system to think that your Season 4 folder is a tv series when it's not, it's just a season.
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 Because Chugginton Tv Show has no collection.xml.
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 you probably want to focus more on the colleciton.xml files
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 what about the file system? what's what i need screenshots of.
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 the presence of the series xml file inside of the season folder is possibly the issue
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 when you setup the media folder what type was used? tv?
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 also please post a screenshot of the parent folder
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 i mean the media folder type in the library setup
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 actually i need a screenshot of the parent and the parent of that
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 no, in the media library area of the dashboard.
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 that second screenshot - remove the collection.xml
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 maybe mcm recreated it? try shutting it down. in any event, that file is the problem. that folder needs to be a tv series, but the system think it's a collection.
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 series inside a collection is fine. the problem is you've got collection -> collection -> series when it should be collection -> series -> season
Luke 42289 Posted January 21, 2014 Posted January 21, 2014 if by chance collection -> collection -> series was working, then you were relying on unsupported behavior. And now you want that behavior to continue but that's not possible. so you really need to stop mcm from putting that file there and then you should be fine.
