hemandk 12 Posted January 19, 2017 Posted January 19, 2017 Luke is there any news? As mentioned then the problems is related to the channel mapping somehow.
Luke 42243 Posted January 19, 2017 Posted January 19, 2017 Yes, some changes have been made for the next release, thanks.
optimalt 10 Posted January 25, 2017 Posted January 25, 2017 Yes, some changes have been made for the next release, thanks.Still stops at 13% in latest Version 3.1.6234.3758 dev.
Luke 42243 Posted January 25, 2017 Posted January 25, 2017 @@optimalt, please provide the information requested in how to report a problem. thanks !
haraldov 10 Posted January 28, 2017 Posted January 28, 2017 (edited) Some improvements has been made . Emby server Version 3.1.287.0 beta on Ubuntu 16.04. Notice that I have done the testing with another Ubuntu server. I must now manually map the channels to the honeybee.xml source. Earlier I did not have to do that. After importing the honeybee.xml into Emby and starting "Refresh Guide Data" the EPG import from honeybee stops at 28,5 %. Attached in "ImportHoneybeeEPG-280117.7z": Honeybee.xml, m3u-file, Emby server log and some snapshots. ImportHoneybeeEPG-280117.7z Edited January 28, 2017 by haraldov
Luke 42243 Posted January 29, 2017 Posted January 29, 2017 @@haraldov please attach the complete emby server log as well. thanks !
hemandk 12 Posted January 29, 2017 Posted January 29, 2017 (edited) Hi luke, So after latest official server release it now stops at 15%. If I dont map the channels then nothing is wrong, but as soon as I map a channel the xml data cant refresh anymore. If have now tried to download the xml file to a local folder but problem is the same. Attached server log. Edited February 11, 2017 by hemandk
haraldov 10 Posted January 29, 2017 Posted January 29, 2017 I think nothing has changed since yesterday when I today imported the m3u and xmltv file. Today every channel-id are mapped to the xmltv channel id and the Refresh Guide Data progressbar is stopping at 25 % . Attach the complete log and the xml and the m3u file. Import-honeybee-290117.7z
hemandk 12 Posted February 4, 2017 Posted February 4, 2017 @@Luke - Would it help to simple connect you directly with the guy running honeybee.it / xmltv.se ? I would say that his service is the only alternative for scandinaviens to get EPG data. I have tried scheduel direct and it was missing lots of channels and they never got it working.
Luke 42243 Posted February 4, 2017 Posted February 4, 2017 @@hemandk so yours is working ok for you now?
hemandk 12 Posted February 4, 2017 Posted February 4, 2017 Hi Luke, No it is still not working. As soon as I map a channel it stops at 15%. I was simply suggesting that you talked directly with guy hosting honeybee.it since almost all Scandinavian users will use his service and it was smart if it was working on emby.
Luke 42243 Posted February 4, 2017 Posted February 4, 2017 I tested this sample again and it's still working OK. Is it possible you're just not being patient enough?
hemandk 12 Posted February 4, 2017 Posted February 4, 2017 I have tried waiting for two days. As I said before it works until you do channel mapping. Have you tried doing that?
Luke 42243 Posted February 4, 2017 Posted February 4, 2017 Well based on that sample they all auto-mapped so nothing was needed. However, I did go ahead and manually change a few mappings and it still completed successfully.
hemandk 12 Posted February 4, 2017 Posted February 4, 2017 OK well it is still stuck here. So any suggestions what to do?
Luke 42243 Posted February 4, 2017 Posted February 4, 2017 in other words it was not necessary to map.
maegibbons 1287 Posted February 4, 2017 Posted February 4, 2017 @@Luke I am a bit confused. In this thread IF automap is working then it is channel-id tag in m3u that is mapping to channel-id in xml. I thought you had said in my thread in Schedules Direct sub-forum that it is tvg-id in m3u that maps to channel-id in xml (which also fails for me) As I understood it channel-id in m3u is for display and sorting in the guide and tvg-id is for mapping. This needs to be clearly defined or configurable in the m3u setup section.. Krs Mark
hemandk 12 Posted February 11, 2017 Posted February 11, 2017 @@Luke This is still not working for me. Is there any other way then looking at the server log to try and find the root course?
haraldov 10 Posted February 11, 2017 Posted February 11, 2017 Tried again with Emby server Version 3.2.1.102 beta on Ubuntu 16.04. After importing the honeybee.xml into Emby and starting "Refresh Guide Data" the xmltv import from honeybee.it stops at 28,5 %. Attaching the server log, m3u file and xmltv file. Difference from the last import. I have updated the m3u file because the new channel mapping support in 3.1.294. Thanks for this update. This which give me correct sorting of the tv-channels (1-13) i LiveTv. #EXTINF:-1, channel-id="1" tvg-id="1879.honeybee.it" tvg-name="NRK1" tvg-logo="https://hbcdn.uk/channel/logo/1879/nrk1.nrk.no.png" http://192.168.9.1:9981/stream/channelid/1332783438&profile=pass Import-honeybee-11022017.7z
Luke 42243 Posted February 11, 2017 Posted February 11, 2017 What is your server's default metadata language setting?
Luke 42243 Posted February 11, 2017 Posted February 11, 2017 Nevermind. This time i can reproduce. It's resolved for the next release, thanks ! 1
hemandk 12 Posted February 11, 2017 Posted February 11, 2017 (edited) Edited. Just installed your beta and it works Thanks for all the effort Luke, really nice to have an EPG Edited February 11, 2017 by hemandk 1
