socalredneck 11 Posted October 17, 2016 Posted October 17, 2016 Hello, I'm having trouble with viewing Live TV, it won't play on my Roku's (2 & 3) any more. I'm able to view Live TV via a browser (but it takes 30 seconds to load). I'm not sure what has caused the problem, but there have been several server upgrades, plus I recently had to replace my modem/router. I have the antenna version of an HDHomeRun Plus. Anyone have suggests where to start? Thank you.
Luke 42148 Posted October 17, 2016 Posted October 17, 2016 Hi, sorry to hear about this. In order to best help you, please provide the information requested in how to report a media playback issue. thanks !
socalredneck 11 Posted October 18, 2016 Author Posted October 18, 2016 I'm hoping this is the correct log file, sorry, but I've never posted my log files before. One thing I forgot to mention, when in Emby I'm able to select Live TV, and go to channels, guide, etc, but once I select the channel I want to view, it stays on that screen, then after about 10 seconds I'm booted all the way out of Emby and sent back to the Roku home page. Hope this helps. Emby Server Log_10-17-19.txt
Luke 42148 Posted October 18, 2016 Posted October 18, 2016 All requests to your HDHR are timing out, so i would suggest verifying that it's turned on, plugged in and connected to the network. Once you've verified that, next thing is ensuring the tuner ip address is correct in emby live tv setup.
Solution socalredneck 11 Posted October 19, 2016 Author Solution Posted October 19, 2016 Thanks for letting me know about it timing out. It's back up and running now. I noticed in my Emby configuration that it listed two different IP addresses for the tuners xxx.xxx.x.66, and xxx.xxx.x.67, so I deleted the tuners from my Emby configuration, then re-added them. Now both tuners have the same IP addresses. The problem had to come from when I had to replace my router. When I play Live TV on a browser now, it plays in about 15 seconds, not 30 like it was been recently. Thank you!!! 1
