arrbee99 1836 Posted October 16, 2016 Posted October 16, 2016 Having an issue with Live TV not working in Chrome (and maybe others), haven't tried yet. Still using NPVR on a Win 10 machine with internal Hauppauge card. The NPVR app works fine with Guide and Live TV playing. I recently reinstalled the Hauppauge software which also updated the driver. The Hauppauge app still has this habit of starting by itself so I disabled it in the Windows Startup list / thingy. I removed and reinstalled the NPVR plug-in but Emby won't show any guide or any Live TV. NPVR is latest release and am on latest Emby dev version. Any ideas please. Apologies for all the logs, but no idea which one to pick. server-63612285582.txt server-63612285577.txt server-63612285661.txt server-63612285667.txt server-63612289462.txt server-63612289603.txt server-63612289736.txt
Luke 42239 Posted October 16, 2016 Posted October 16, 2016 Your next pvr installation is returning a 500 error: 2016-10-17 08:12:34.2764 Error HttpClient: Error getting response from http://localhost:8866/public/GuideService/Listing?sid=9aedbe38648740848fd8827114db7336&stime=1476641554&etime=1477246354&channelId=7192 *** Error Report *** Version: 3.1.6133.21963 Command line: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe One or more errors occurred. System.AggregateException at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1d.MoveNext() InnerException: System.Net.WebException The remote server returned an error: (500) Internal Server Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
arrbee99 1836 Posted October 16, 2016 Author Posted October 16, 2016 I presume that means there's something wrong in the NextPVR app ? - would you happen to know if it's the software or the plug-in ?
Luke 42239 Posted October 16, 2016 Posted October 16, 2016 I don't know if it's a problem with the app or the way the plugin is trying to communicate with it. The next pvr api is returning a 500 error code which corresponds to internal server error. You will probably need to look at next pvr logs and then based on that potentially create a topic in their community.
arrbee99 1836 Posted October 16, 2016 Author Posted October 16, 2016 Ok. Will try that. Thanks for the help and the quick reply.
Solution arrbee99 1836 Posted October 16, 2016 Author Solution Posted October 16, 2016 FYI, got it working after applying a patch found here... http://forums.nextpvr.com/showthread.php?58699-Nowt-in-NPVR/page2 1
