FordGT90Concept 103 Posted October 15, 2016 Posted October 15, 2016 (edited) I tried using the new active recording feature to watch something as it is being recorded via Edge browser on a Windows 10 machine. Video worked fine but there was no audio. I tried playing Jungle 2 Jungle (pre-recorded) on the same system and it had sound. I went back to the Active Recording and again, no sound. I pulled up the same thing on a different computer (also Edge + Windows 10) and no audio there either. The audio layer on it is AC3, 48000 Hz, 6ch, 384 kbps. Pretty standard stuff for ATSC. Emby Server 3.0.8100.0 Edited October 15, 2016 by FordGT90Concept
Luke 42290 Posted October 15, 2016 Posted October 15, 2016 Hi there, we're sorry to hear about this. In order to best help you, please provide the information requested in how to report a media playback issue. Thanks !
FordGT90Concept 103 Posted October 16, 2016 Author Posted October 16, 2016 (edited) Here's the logs. The computer that it happened on originally was BY-2009. I tested it on BY-2015 as well. Edge browser for both. It was probably around 3pm that it happened. logs.zip Edited October 16, 2016 by FordGT90Concept
Solution Luke 42290 Posted October 16, 2016 Solution Posted October 16, 2016 Thanks, should be resolved now in the latest beta. It will be in the next stable update. 1
FordGT90Concept 103 Posted October 20, 2016 Author Posted October 20, 2016 (edited) Confirmed it is fixed in stable 3.0.8200 Edited October 20, 2016 by FordGT90Concept
