KRA 39 Posted October 15, 2016 Posted October 15, 2016 (edited) First off, really loving the new insanely fast skipping available in live-tv. I really hope in the future it will show the correct lengt of the show/recording and not grow as you watch/skip. For Live-TV a more informative progress bar would be great. With indicators like: 1-----------------2--------------3--------------4 1 start point of program (19:30) 2 your current position (19:42) 3 current live position (19:48) 4 end point of program (20:00) Suggestion: Start and end time is given, 2 suggestions for current position and live point - have a two color bar, so from start to current is green, current to live is blue - have the the green bar as today, but a divider/marker at the current live point. But over to my problem, I'm not getting any sound. Not in Live-TV or Recordings. I'm no expert but looking at the log it seems like the recording is stream copy'd to HLS, but the MP3 sound is tagged as DTS ? http://192.168.10.205:8096/emby/videos/a22d46b4c7ba2cc2fb72d18f9d03488f/live.m3u8?DeviceId=a79308163e26439c9e0e91d81ad088f4&MediaSourceId=2&VideoCodec=h264&AudioCodec=ac3,aac,mp3&AudioStreamIndex=0&VideoBitrate=1396107636&AudioBitrate=256000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=66b96717549642e8bc076d058edeb67b&api_key=dd39c82f8a7348b7b6b48f6defa4a44f&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_41c95b6de5174f82acbc56fe82d0a2f8_2&CopyTimestamps=false&TranscodingMaxAudioChannels=2&EnableSubtitlesInManifest=false {"Protocol":"Http","Id":"2","Path":"http://emby:media@192.168.10.205:9981/dvrfile/1227756028","Type":"Default","Container":"matroska,webm","Size":8951641692,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"1a755974de5dc3461dc6ecae8ddec68b_41c95b6de5174f82acbc56fe82d0a2f8_2","MediaStreams":[{"Codec":"mp3","Language":"nor","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Nor MP3 stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":256000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/100","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":13261642,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":50,"RealFrameRate":50,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":13261642,"RequiredHttpHeaders":{},"DefaultAudioStreamIndex":0} /var/lib/emby-server/ffmpeg/20160215/ffmpeg -fflags +genpts -i "http://emby:media@192.168.10.205:9981/dvrfile/1227756028" -map_metadata -1 -threads 0 -map 0:1 -map 0:0 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -sc_threshold 0 -codec:a:0 copy -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/42bb7903ceaa43919c6b0c1d53ba038b/" -y "/var/lib/emby-server/transcoding-temp/42bb7903ceaa43919c6b0c1d53ba038b.m3u8" ffmpeg version N-52954-g295de3e-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.1 (Debian 5.3.1-8) 20160205 configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --cc=gcc libavutil 55. 17.103 / 55. 17.103 libavcodec 57. 24.102 / 57. 24.102 libavformat 57. 25.100 / 57. 25.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 31.100 / 6. 31.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [h264 @ 0x4788960] co located POCs unavailable [h264 @ 0x4788960] Increasing reorder buffer to 1 [h264 @ 0x4788960] co located POCs unavailable Last message repeated 1 times [h264 @ 0x4788960] Increasing reorder buffer to 2 Input #0, matroska,webm, from 'http://emby:media@192.168.10.205:9981/dvrfile/1227756028': Metadata: title : The Stream encoder : Tvheadend Matroska muxer DATE_BROADCASTED: 2016-10-15 17:00:00 ORIGINAL_MEDIA_TYPE: TV TVCHANNEL : TV2 Norway SUMMARY : Ny tid, nye stjerner! I TV 2s helt nye musikk-konkurranse The Stream kommer drømmen nærmere virkeligheten. Verdens tre største plateselskaper skal, sammen alle vi som lytter til musikk, finne Norges mest populære artist. Tarjei Strøm er programleder, SUMMARY-nor : Ny tid, nye stjerner! I TV 2s helt nye musikk-konkurranse The Stream kommer drømmen nærmere virkeligheten. Verdens tre største plateselskaper skal, sammen alle vi som lytter til musikk, finne Norges mest populære artist. Tarjei Strøm er programleder, track : 8 SEASON/PART_NUMBER: 1 SYNOPSIS : Episode 8 of 17 season 1 COMMENT : Auto recording: Created from EPG query COMMENT-nor : Auto recording: Created from EPG query Duration: 01:30:00.02, start: 0.013000, bitrate: 13261 kb/s Chapter #0:0: start 5162.800000, end 5400.033000 Stream #0:0(nor): Audio: mp3, 48000 Hz, stereo, s16p, 256 kb/s (default) Stream #0:1(eng): Video: h264 (Main), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 1k tbn, 100 tbc (default) Output #0, hls, to '/var/lib/emby-server/transcoding-temp/42bb7903ceaa43919c6b0c1d53ba038b.m3u8': Metadata: encoder : Lavf57.25.100 Chapter #0:0: start 5162.787000, end 5400.020000 Stream #0:0: Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 50 fps, 50 tbr, 90k tbn, 50 tbc (default) Stream #0:1: Audio: mp3, 48000 Hz, stereo, 256 kb/s (default) Stream mapping: Stream #0:1 -> #0:0 (copy) Stream #0:0 -> #0:1 (copy) Press [q] to stop, [?] for help [hls @ 0x4dfeec0] Non-monotonous DTS in output stream 0:0; previous: 34830, current: 34830; changing to 34831. This may result in incorrect timestamps in the output file. frame= 7223 fps=0.0 q=-1.0 size=N/A time=00:02:24.54 bitrate=N/A speed= 289x frame=14548 fps=14547 q=-1.0 size=N/A time=00:04:51.04 bitrate=N/A speed= 291x frame=22040 fps=14693 q=-1.0 size=N/A time=00:07:20.88 bitrate=N/A speed= 294x frame=29518 fps=14758 q=-1.0 size=N/A time=00:09:50.44 bitrate=N/A speed= 295x frame=33193 fps=9360 q=-1.0 size=N/A time=00:11:03.94 bitrate=N/A speed= 187x frame=36805 fps=5256 q=-1.0 size=N/A time=00:12:16.18 bitrate=N/A speed= 105x frame=36819 fps=4312 q=-1.0 size=N/A time=00:12:16.46 bitrate=N/A speed=86.3x frame=43977 fps=4866 q=-1.0 size=N/A time=00:14:39.62 bitrate=N/A speed=97.3x frame=46409 fps=4217 q=-1.0 Lsize=N/A time=00:15:28.26 bitrate=N/A speed=84.3x video:1472882kB audio:28979kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Edited October 15, 2016 by KRA
KRA 39 Posted October 15, 2016 Author Posted October 15, 2016 (edited) As for Live-TV test it seems it's trying to encode MP2 to AC3, seems like a waste, but it's not working either: http://192.168.10.205:8096/emby/videos/e2e94d9e367252e4a85124d5d95adc34/live.m3u8?DeviceId=a79308163e26439c9e0e91d81ad088f4&MediaSourceId=1&VideoCodec=h264&AudioCodec=ac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=1396171636&AudioBitrate=192000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=42a73015e90f450b9c7c16fe21f59d58&api_key=dd39c82f8a7348b7b6b48f6defa4a44f&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_41c95b6de5174f82acbc56fe82d0a2f8_1&CopyTimestamps=false&TranscodingMaxAudioChannels=2&EnableSubtitlesInManifest=false {"Protocol":"Http","Id":"1","Path":"http://emby:media@192.168.10.205:9981/stream/channelid/2094999119","Type":"Default","Container":"mpegts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"1a755974de5dc3461dc6ecae8ddec68b_41c95b6de5174f82acbc56fe82d0a2f8_1","MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":false,"IsAVC":false,"BitRate":8000000,"BitDepth":8,"RefFrames":3,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":50,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"mp2","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"EngMP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"dvbsub","Language":"swe","TimeBase":"1/90000","CodecTimeBase":"1/90000","DisplayTitle":"Swe","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"dvbsub","Language":"nor","TimeBase":"1/90000","CodecTimeBase":"1/90000","DisplayTitle":"Nor","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":192000,"RequiredHttpHeaders":{"Authorization":"Basic ZW1ieTptZWRpYQ=="},"DefaultAudioStreamIndex":1} /var/lib/emby-server/ffmpeg/20160215/ffmpeg -fflags +genpts -i "http://emby:media@192.168.10.205:9981/stream/channelid/2094999119"-map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -tune zerolatency -b:v 8000000 -maxrate 8000000 -bufsize 16000000 -vsync -1 -profile:v high -level 4.1 -force_key_frames "expr:gte(t,n_forced*3)" -flags -global_header -sc_threshold 0 -codec:a:0 ac3 -ac 2 -ab 192000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/cd8b3ec992f2eebc1d4143ad3e8c2ced/" -y "/var/lib/emby-server/transcoding-temp/cd8b3ec992f2eebc1d4143ad3e8c2ced.m3u8" ffmpeg version N-52954-g295de3e-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.1 (Debian 5.3.1-8) 20160205 configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --cc=gcc libavutil 55. 17.103 / 55. 17.103 libavcodec 57. 24.102 / 57. 24.102 libavformat 57. 25.100 / 57. 25.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 31.100 / 6. 31.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x579b2c0] decode_slice_header error [h264 @ 0x579b2c0] no frame! [h264 @ 0x579b2c0] mmco: unref short failure Last message repeated 1 times [h264 @ 0x579b2c0] number of reference frames (0+4) exceeds max (3; probably corrupt input), discarding one [h264 @ 0x579b2c0] Increasing reorder buffer to 2 Input #0, mpegts, from 'http://emby:media@192.168.10.205:9981/stream/channelid/2094999119': Duration: N/A, start: 43753.585700, bitrate: N/A Program 1060 Metadata: service_name : ?Travel Channel HD service_provider: ?Canal Digital KTV Stream #0:0[0x3ec]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc Stream #0:1[0xd1c](eng): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s Stream #0:2[0x17ff](swe): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:3[0x17fe](nor): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) [libx264 @ 0x579e340] using SAR=1/1 [libx264 @ 0x579e340] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0x579e340] profile High, level 4.1 Output #0, hls, to '/var/lib/emby-server/transcoding-temp/cd8b3ec992f2eebc1d4143ad3e8c2ced.m3u8': Metadata: encoder : Lavf57.25.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=-1--1, 8000 kb/s, 25 fps, 90k tbn, 25 tbc Metadata: encoder : Lavc57.24.102 libx264 Side data: unknown side data type 10 (24 bytes) Stream #0:1: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc57.24.102 ac3 Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> ac3 (native)) Press [q] to stop, [?] for help [h264 @ 0x60a6460] reference picture missing during reorder [h264 @ 0x60a6460] Missing reference picture, default is 2147483647 [h264 @ 0x61468a0] mmco: unref short failure [h264 @ 0x61468a0] reference picture missing during reorder [h264 @ 0x61468a0] Missing reference picture, default is 65492 [h264 @ 0x618d9c0] mmco: unref short failure [h264 @ 0x60ff780] mmco: unref short failure frame= 46 fps=0.0 q=21.0 size=N/A time=00:00:01.84 bitrate=N/A dup=42 drop=0 speed=3.68x frame= 80 fps= 79 q=21.0 size=N/A time=00:00:03.20 bitrate=N/A dup=42 drop=0 speed=3.15x frame= 112 fps= 74 q=22.0 size=N/A time=00:00:04.48 bitrate=N/A dup=42 drop=0 speed=2.95x frame= 143 fps= 70 q=22.0 size=N/A time=00:00:05.72 bitrate=N/A dup=42 drop=0 speed=2.82x frame= 171 fps= 67 q=23.0 size=N/A time=00:00:06.84 bitrate=N/A dup=42 drop=0 speed=2.69x frame= 196 fps= 64 q=22.0 size=N/A time=00:00:07.84 bitrate=N/A dup=42 drop=0 speed=2.57x frame= 224 fps= 63 q=22.0 size=N/A time=00:00:08.96 bitrate=N/A dup=42 drop=0 speed=2.53x frame= 237 fps= 58 q=22.0 size=N/A time=00:00:09.48 bitrate=N/A dup=42 drop=0 speed=2.34x frame= 248 fps= 54 q=21.0 size=N/A time=00:00:09.92 bitrate=N/A dup=42 drop=0 speed=2.17x frame= 266 fps= 52 q=20.0 size=N/A time=00:00:10.64 bitrate=N/A dup=42 drop=0 speed= 2.1x frame= 275 fps= 49 q=27.0 size=N/A time=00:00:11.00 bitrate=N/A dup=42 drop=0 speed=1.97x frame= 295 fps= 48 q=28.0 size=N/A time=00:00:11.80 bitrate=N/A dup=42 drop=0 speed=1.94x frame= 310 fps= 47 q=29.0 size=N/A time=00:00:12.40 bitrate=N/A dup=42 drop=0 speed=1.88x frame= 328 fps= 46 q=27.0 size=N/A time=00:00:13.12 bitrate=N/A dup=42 drop=0 speed=1.85x frame= 338 fps= 44 q=22.0 size=N/A time=00:00:13.52 bitrate=N/A dup=42 drop=0 speed=1.77x frame= 351 fps= 43 q=25.0 size=N/A time=00:00:14.04 bitrate=N/A dup=42 drop=0 speed=1.72x frame= 368 fps= 42 q=19.0 size=N/A time=00:00:14.72 bitrate=N/A dup=42 drop=0 speed=1.69x frame= 379 fps= 41 q=26.0 size=N/A time=00:00:15.16 bitrate=N/A dup=42 drop=0 speed=1.64x frame= 391 fps= 40 q=25.0 size=N/A time=00:00:15.64 bitrate=N/A dup=42 drop=0 speed= 1.6x frame= 400 fps= 39 q=27.0 size=N/A time=00:00:16.00 bitrate=N/A dup=42 drop=0 speed=1.56x frame= 412 fps= 38 q=28.0 size=N/A time=00:00:16.48 bitrate=N/A dup=42 drop=0 speed=1.53x frame= 432 fps= 38 q=19.0 size=N/A time=00:00:17.28 bitrate=N/A dup=42 drop=0 speed=1.53x frame= 443 fps= 38 q=23.0 size=N/A time=00:00:17.72 bitrate=N/A dup=42 drop=0 speed= 1.5x frame= 449 fps= 36 q=26.0 size=N/A time=00:00:17.96 bitrate=N/A dup=42 drop=0 speed=1.46x frame= 462 fps= 36 q=22.0 size=N/A time=00:00:18.48 bitrate=N/A dup=42 drop=0 speed=1.44x frame= 475 fps= 36 q=23.0 size=N/A time=00:00:19.00 bitrate=N/A dup=42 drop=0 speed=1.42x frame= 497 fps= 36 q=21.0 size=N/A time=00:00:19.88 bitrate=N/A dup=42 drop=0 speed=1.43x frame= 510 fps= 35 q=21.0 size=N/A time=00:00:20.40 bitrate=N/A dup=42 drop=0 speed=1.42x frame= 518 fps= 35 q=19.0 size=N/A time=00:00:20.72 bitrate=N/A dup=42 drop=0 speed=1.39x frame= 532 fps= 35 q=20.0 size=N/A time=00:00:21.28 bitrate=N/A dup=42 drop=0 speed=1.38x frame= 544 fps= 34 q=20.0 size=N/A time=00:00:21.76 bitrate=N/A dup=42 drop=0 speed=1.37x frame= 551 fps= 33 q=23.0 size=N/A time=00:00:22.04 bitrate=N/A dup=42 drop=0 speed=1.34x frame= 567 fps= 33 q=20.0 size=N/A time=00:00:22.68 bitrate=N/A dup=42 drop=0 speed=1.33x frame= 579 fps= 33 q=21.0 size=N/A time=00:00:23.16 bitrate=N/A dup=42 drop=0 speed=1.32x frame= 591 fps= 33 q=24.0 size=N/A time=00:00:23.64 bitrate=N/A dup=42 drop=0 speed=1.31x frame= 606 fps= 33 q=25.0 size=N/A time=00:00:24.24 bitrate=N/A dup=42 drop=0 speed= 1.3x frame= 623 fps= 33 q=25.0 size=N/A time=00:00:24.92 bitrate=N/A dup=42 drop=0 speed= 1.3x frame= 636 fps= 32 q=27.0 size=N/A time=00:00:25.44 bitrate=N/A dup=42 drop=0 speed= 1.3x frame= 654 fps= 32 q=23.0 size=N/A time=00:00:26.16 bitrate=N/A dup=42 drop=0 speed= 1.3x frame= 662 fps= 32 q=23.0 size=N/A time=00:00:26.48 bitrate=N/A dup=42 drop=0 speed=1.28x frame= 679 fps= 32 q=22.0 size=N/A time=00:00:27.16 bitrate=N/A dup=42 drop=0 speed=1.28x frame= 693 fps= 32 q=20.0 size=N/A time=00:00:27.72 bitrate=N/A dup=42 drop=0 speed=1.28x frame= 700 fps= 32 q=19.0 size=N/A time=00:00:28.00 bitrate=N/A dup=42 drop=0 speed=1.26x frame= 713 fps= 31 q=23.0 size=N/A time=00:00:28.52 bitrate=N/A dup=42 drop=0 speed=1.25x frame= 726 fps= 31 q=23.0 size=N/A time=00:00:29.04 bitrate=N/A dup=42 drop=0 speed=1.25x frame= 735 fps= 31 q=23.0 size=N/A time=00:00:29.40 bitrate=N/A dup=42 drop=0 speed=1.24x frame= 750 fps= 31 q=22.0 size=N/A time=00:00:30.00 bitrate=N/A dup=42 drop=0 speed=1.24x frame= 759 fps= 31 q=23.0 size=N/A time=00:00:30.36 bitrate=N/A dup=42 drop=0 speed=1.22x frame= 777 fps= 31 q=23.0 size=N/A time=00:00:31.08 bitrate=N/A dup=42 drop=0 speed=1.23x frame= 787 fps= 30 q=23.0 size=N/A time=00:00:31.48 bitrate=N/A dup=42 drop=0 speed=1.22x frame= 804 fps= 30 q=21.0 size=N/A time=00:00:32.16 bitrate=N/A dup=42 drop=0 speed=1.22x frame= 818 fps= 30 q=21.0 size=N/A time=00:00:32.72 bitrate=N/A dup=42 drop=0 speed=1.22x frame= 835 fps= 30 q=22.0 size=N/A time=00:00:33.40 bitrate=N/A dup=42 drop=0 speed=1.22x frame= 846 fps= 30 q=22.0 size=N/A time=00:00:33.84 bitrate=N/A dup=42 drop=0 speed=1.21x frame= 854 fps= 30 q=22.0 size=N/A time=00:00:34.16 bitrate=N/A dup=42 drop=0 speed= 1.2x frame= 862 fps= 30 q=25.0 size=N/A time=00:00:34.48 bitrate=N/A dup=42 drop=0 speed=1.19x frame= 874 fps= 30 q=24.0 size=N/A time=00:00:34.96 bitrate=N/A dup=42 drop=0 speed=1.19x frame= 886 fps= 30 q=24.0 size=N/A time=00:00:35.44 bitrate=N/A dup=42 drop=0 speed=1.18x frame= 899 fps= 29 q=25.0 size=N/A time=00:00:35.96 bitrate=N/A dup=42 drop=0 speed=1.18x frame= 919 fps= 30 q=24.0 size=N/A time=00:00:36.76 bitrate=N/A dup=42 drop=0 speed=1.18x frame= 931 fps= 29 q=25.0 size=N/A time=00:00:37.24 bitrate=N/A dup=42 drop=0 speed=1.18x frame= 941 fps= 29 q=26.0 size=N/A time=00:00:37.64 bitrate=N/A dup=42 drop=0 speed=1.17x frame= 960 fps= 29 q=24.0 size=N/A time=00:00:38.40 bitrate=N/A dup=42 drop=0 speed=1.18x frame= 979 fps= 30 q=24.0 size=N/A time=00:00:39.16 bitrate=N/A dup=42 drop=0 speed=1.18x frame= 992 fps= 29 q=22.0 size=N/A time=00:00:39.68 bitrate=N/A dup=42 drop=0 speed=1.18x frame= 1001 fps= 29 q=23.0 size=N/A time=00:00:40.04 bitrate=N/A dup=42 drop=0 speed=1.17x frame= 1014 fps= 29 q=20.0 size=N/A time=00:00:40.56 bitrate=N/A dup=42 drop=0 speed=1.17x frame= 1027 fps= 29 q=22.0 size=N/A time=00:00:41.08 bitrate=N/A dup=42 drop=0 speed=1.16x frame= 1043 fps= 29 q=22.0 size=N/A time=00:00:41.72 bitrate=N/A dup=42 drop=0 speed=1.16x frame= 1053 fps= 29 q=24.0 size=N/A time=00:00:42.12 bitrate=N/A dup=42 drop=0 speed=1.16x frame= 1067 fps= 29 q=22.0 size=N/A time=00:00:42.68 bitrate=N/A dup=42 drop=0 speed=1.16x frame= 1082 fps= 29 q=22.0 size=N/A time=00:00:43.28 bitrate=N/A dup=42 drop=0 speed=1.16x frame= 1095 fps= 29 q=22.0 size=N/A time=00:00:43.80 bitrate=N/A dup=42 drop=0 speed=1.16x frame= 1110 fps= 29 q=22.0 size=N/A time=00:00:44.40 bitrate=N/A dup=42 drop=0 speed=1.16x frame= 1122 fps= 29 q=22.0 size=N/A time=00:00:44.88 bitrate=N/A dup=42 drop=0 speed=1.15x frame= 1135 fps= 29 q=22.0 size=N/A time=00:00:45.40 bitrate=N/A dup=42 drop=0 speed=1.15x frame= 1142 fps= 29 q=22.0 size=N/A time=00:00:45.68 bitrate=N/A dup=42 drop=0 speed=1.14x frame= 1156 fps= 29 q=22.0 size=N/A time=00:00:46.24 bitrate=N/A dup=42 drop=0 speed=1.14x frame= 1170 fps= 29 q=22.0 size=N/A time=00:00:46.80 bitrate=N/A dup=42 drop=0 speed=1.14x frame= 1184 fps= 29 q=23.0 size=N/A time=00:00:47.36 bitrate=N/A dup=42 drop=0 speed=1.14x frame= 1195 fps= 28 q=22.0 size=N/A time=00:00:47.80 bitrate=N/A dup=42 drop=0 speed=1.14x frame= 1203 fps= 28 q=23.0 size=N/A time=00:00:48.12 bitrate=N/A dup=42 drop=0 speed=1.13x frame= 1220 fps= 28 q=22.0 size=N/A time=00:00:48.80 bitrate=N/A dup=42 drop=0 speed=1.13x frame= 1235 fps= 28 q=22.0 size=N/A time=00:00:49.40 bitrate=N/A dup=42 drop=0 speed=1.13x frame= 1246 fps= 28 q=22.0 size=N/A time=00:00:49.84 bitrate=N/A dup=42 drop=0 speed=1.13x frame= 1256 fps= 28 q=24.0 size=N/A time=00:00:50.24 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1267 fps= 28 q=24.0 size=N/A time=00:00:50.68 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1279 fps= 28 q=25.0 size=N/A time=00:00:51.16 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1295 fps= 28 q=24.0 size=N/A time=00:00:51.80 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1311 fps= 28 q=24.0 size=N/A time=00:00:52.44 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1330 fps= 28 q=23.0 size=N/A time=00:00:53.20 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1344 fps= 28 q=23.0 size=N/A time=00:00:53.76 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1355 fps= 28 q=24.0 size=N/A time=00:00:54.20 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1370 fps= 28 q=25.0 size=N/A time=00:00:54.80 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1385 fps= 28 q=25.0 size=N/A time=00:00:55.40 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1397 fps= 28 q=25.0 size=N/A time=00:00:55.88 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1413 fps= 28 q=25.0 size=N/A time=00:00:56.52 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1427 fps= 28 q=25.0 size=N/A time=00:00:57.08 bitrate=N/A dup=42 drop=0 speed=1.12x frame= 1439 fps= 28 q=25.0 size=N/A time=00:00:57.56 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1452 fps= 28 q=26.0 size=N/A time=00:00:58.08 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1463 fps= 28 q=27.0 size=N/A time=00:00:58.52 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1482 fps= 28 q=26.0 size=N/A time=00:00:59.28 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1494 fps= 28 q=24.0 size=N/A time=00:00:59.76 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1509 fps= 28 q=28.0 size=N/A time=00:01:00.36 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1520 fps= 28 q=28.0 size=N/A time=00:01:00.80 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1528 fps= 28 q=28.0 size=N/A time=00:01:01.12 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1540 fps= 28 q=27.0 size=N/A time=00:01:01.60 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1557 fps= 28 q=28.0 size=N/A time=00:01:02.28 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1575 fps= 28 q=24.0 size=N/A time=00:01:03.00 bitrate=N/A dup=42 drop=0 speed=1.11x frame= 1586 fps= 28 q=24.0 size=N/A time=00:01:03.44 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1600 fps= 28 q=20.0 size=N/A time=00:01:04.00 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1606 fps= 27 q=21.0 size=N/A time=00:01:04.24 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1615 fps= 27 q=26.0 size=N/A time=00:01:04.60 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1627 fps= 27 q=22.0 size=N/A time=00:01:05.08 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1649 fps= 27 q=24.0 size=N/A time=00:01:05.96 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1664 fps= 27 q=23.0 size=N/A time=00:01:06.56 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1675 fps= 27 q=23.0 size=N/A time=00:01:07.00 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1688 fps= 27 q=22.0 size=N/A time=00:01:07.52 bitrate=N/A dup=42 drop=0 speed= 1.1x frame= 1703 fps= 27 q=24.0 size=N/A time=00:01:08.12 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1712 fps= 27 q=26.0 size=N/A time=00:01:08.48 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1723 fps= 27 q=26.0 size=N/A time=00:01:08.92 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1734 fps= 27 q=28.0 size=N/A time=00:01:09.36 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1747 fps= 27 q=31.0 size=N/A time=00:01:09.88 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1758 fps= 27 q=35.0 size=N/A time=00:01:10.32 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1773 fps= 27 q=33.0 size=N/A time=00:01:10.92 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1789 fps= 27 q=33.0 size=N/A time=00:01:11.56 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1808 fps= 27 q=28.0 size=N/A time=00:01:12.32 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1822 fps= 27 q=30.0 size=N/A time=00:01:12.88 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1836 fps= 27 q=27.0 size=N/A time=00:01:13.44 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1849 fps= 27 q=24.0 size=N/A time=00:01:13.96 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1861 fps= 27 q=21.0 size=N/A time=00:01:14.44 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1874 fps= 27 q=21.0 size=N/A time=00:01:14.96 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1886 fps= 27 q=21.0 size=N/A time=00:01:15.44 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1899 fps= 27 q=21.0 size=N/A time=00:01:15.96 bitrate=N/A dup=42 drop=0 speed=1.09x frame= 1911 fps= 27 q=18.0 size=N/A time=00:01:16.44 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1918 fps= 27 q=18.0 size=N/A time=00:01:16.72 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1932 fps= 27 q=24.0 size=N/A time=00:01:17.28 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1948 fps= 27 q=24.0 size=N/A time=00:01:17.92 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1962 fps= 27 q=25.0 size=N/A time=00:01:18.48 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1972 fps= 27 q=25.0 size=N/A time=00:01:18.88 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 1989 fps= 27 q=29.0 size=N/A time=00:01:19.56 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2004 fps= 27 q=28.0 size=N/A time=00:01:20.16 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2016 fps= 27 q=28.0 size=N/A time=00:01:20.64 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2028 fps= 27 q=28.0 size=N/A time=00:01:21.12 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2040 fps= 27 q=27.0 size=N/A time=00:01:21.60 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2055 fps= 27 q=24.0 size=N/A time=00:01:22.20 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2066 fps= 27 q=23.0 size=N/A time=00:01:22.64 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2077 fps= 27 q=25.0 size=N/A time=00:01:23.08 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2092 fps= 27 q=24.0 size=N/A time=00:01:23.68 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2106 fps= 27 q=23.0 size=N/A time=00:01:24.24 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2115 fps= 27 q=23.0 size=N/A time=00:01:24.60 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2128 fps= 27 q=30.0 size=N/A time=00:01:25.12 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2142 fps= 27 q=32.0 size=N/A time=00:01:25.68 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2158 fps= 27 q=25.0 size=N/A time=00:01:26.32 bitrate=N/A dup=42 drop=0 speed=1.08x frame= 2171 fps= 27 q=24.0 size=N/A time=00:01:26.84 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2183 fps= 27 q=21.0 size=N/A time=00:01:27.32 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2196 fps= 27 q=19.0 size=N/A time=00:01:27.84 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2204 fps= 27 q=19.0 size=N/A time=00:01:28.16 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2222 fps= 27 q=18.0 size=N/A time=00:01:28.88 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2234 fps= 27 q=18.0 size=N/A time=00:01:29.36 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2247 fps= 27 q=18.0 size=N/A time=00:01:29.88 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2261 fps= 27 q=18.0 size=N/A time=00:01:30.44 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2267 fps= 27 q=18.0 size=N/A time=00:01:30.68 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2289 fps= 27 q=18.0 size=N/A time=00:01:31.56 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2297 fps= 27 q=18.0 size=N/A time=00:01:31.88 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2306 fps= 27 q=24.0 size=N/A time=00:01:32.24 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2319 fps= 27 q=24.0 size=N/A time=00:01:32.76 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2328 fps= 27 q=24.0 size=N/A time=00:01:33.12 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2339 fps= 27 q=24.0 size=N/A time=00:01:33.56 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2359 fps= 27 q=22.0 size=N/A time=00:01:34.36 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2379 fps= 27 q=21.0 size=N/A time=00:01:35.16 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2391 fps= 27 q=21.0 size=N/A time=00:01:35.64 bitrate=N/A dup=42 drop=0 speed=1.07x frame= 2402 fps= 27 q=22.0 size=N/A time=00:01:36.08 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2412 fps= 27 q=21.0 size=N/A time=00:01:36.48 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2422 fps= 27 q=21.0 size=N/A time=00:01:36.88 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2433 fps= 26 q=24.0 size=N/A time=00:01:37.32 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2444 fps= 26 q=25.0 size=N/A time=00:01:37.76 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2458 fps= 26 q=25.0 size=N/A time=00:01:38.32 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2472 fps= 26 q=29.0 size=N/A time=00:01:38.88 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2488 fps= 26 q=31.0 size=N/A time=00:01:39.52 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2503 fps= 27 q=30.0 size=N/A time=00:01:40.12 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2521 fps= 27 q=26.0 size=N/A time=00:01:40.84 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2534 fps= 27 q=26.0 size=N/A time=00:01:41.36 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2547 fps= 27 q=24.0 size=N/A time=00:01:41.88 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2559 fps= 26 q=25.0 size=N/A time=00:01:42.36 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2568 fps= 26 q=24.0 size=N/A time=00:01:42.72 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2584 fps= 26 q=24.0 size=N/A time=00:01:43.36 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2598 fps= 26 q=23.0 size=N/A time=00:01:43.92 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2608 fps= 26 q=24.0 size=N/A time=00:01:44.32 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2620 fps= 26 q=24.0 size=N/A time=00:01:44.80 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2632 fps= 26 q=28.0 size=N/A time=00:01:45.28 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2644 fps= 26 q=26.0 size=N/A time=00:01:45.76 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2660 fps= 26 q=26.0 size=N/A time=00:01:46.40 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2675 fps= 26 q=26.0 size=N/A time=00:01:47.00 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2688 fps= 26 q=27.0 size=N/A time=00:01:47.52 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2702 fps= 26 q=26.0 size=N/A time=00:01:48.08 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2719 fps= 26 q=24.0 size=N/A time=00:01:48.76 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2733 fps= 26 q=23.0 size=N/A time=00:01:49.32 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2746 fps= 26 q=22.0 size=N/A time=00:01:49.84 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2753 fps= 26 q=22.0 size=N/A time=00:01:50.12 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2772 fps= 26 q=23.0 size=N/A time=00:01:50.88 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2777 fps= 26 q=27.0 size=N/A time=00:01:51.08 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2792 fps= 26 q=24.0 size=N/A time=00:01:51.68 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2810 fps= 26 q=22.0 size=N/A time=00:01:52.40 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2818 fps= 26 q=23.0 size=N/A time=00:01:52.72 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2828 fps= 26 q=26.0 size=N/A time=00:01:53.12 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2843 fps= 26 q=26.0 size=N/A time=00:01:53.72 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2862 fps= 26 q=27.0 size=N/A time=00:01:54.48 bitrate=N/A dup=42 drop=0 speed=1.06x frame= 2873 fps= 26 q=25.0 size=N/A time=00:01:54.92 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2883 fps= 26 q=29.0 size=N/A time=00:01:55.32 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2897 fps= 26 q=25.0 size=N/A time=00:01:55.88 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2912 fps= 26 q=28.0 size=N/A time=00:01:56.48 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2924 fps= 26 q=28.0 size=N/A time=00:01:56.96 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2937 fps= 26 q=28.0 size=N/A time=00:01:57.48 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2948 fps= 26 q=28.0 size=N/A time=00:01:57.92 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2959 fps= 26 q=28.0 size=N/A time=00:01:58.36 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2974 fps= 26 q=28.0 size=N/A time=00:01:58.96 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2987 fps= 26 q=29.0 size=N/A time=00:01:59.48 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 2996 fps= 26 q=27.0 size=N/A time=00:01:59.84 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3015 fps= 26 q=21.0 size=N/A time=00:02:00.60 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3026 fps= 26 q=21.0 size=N/A time=00:02:01.04 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3038 fps= 26 q=21.0 size=N/A time=00:02:01.52 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3046 fps= 26 q=21.0 size=N/A time=00:02:01.84 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3056 fps= 26 q=25.0 size=N/A time=00:02:02.24 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3066 fps= 26 q=24.0 size=N/A time=00:02:02.64 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3079 fps= 26 q=26.0 size=N/A time=00:02:03.16 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3095 fps= 26 q=25.0 size=N/A time=00:02:03.80 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3117 fps= 26 q=27.0 size=N/A time=00:02:04.68 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3132 fps= 26 q=29.0 size=N/A time=00:02:05.28 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3144 fps= 26 q=28.0 size=N/A time=00:02:05.76 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3155 fps= 26 q=29.0 size=N/A time=00:02:06.20 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3166 fps= 26 q=29.0 size=N/A time=00:02:06.64 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3179 fps= 26 q=24.0 size=N/A time=00:02:07.16 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3191 fps= 26 q=23.0 size=N/A time=00:02:07.64 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3207 fps= 26 q=22.0 size=N/A time=00:02:08.28 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3215 fps= 26 q=21.0 size=N/A time=00:02:08.60 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3231 fps= 26 q=27.0 size=N/A time=00:02:09.24 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3248 fps= 26 q=26.0 size=N/A time=00:02:09.92 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3263 fps= 26 q=25.0 size=N/A time=00:02:10.52 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3274 fps= 26 q=26.0 size=N/A time=00:02:10.96 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3283 fps= 26 q=25.0 size=N/A time=00:02:11.32 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3300 fps= 26 q=24.0 size=N/A time=00:02:12.00 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3314 fps= 26 q=25.0 size=N/A time=00:02:12.56 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3329 fps= 26 q=24.0 size=N/A time=00:02:13.16 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3342 fps= 26 q=23.0 size=N/A time=00:02:13.68 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3353 fps= 26 q=23.0 size=N/A time=00:02:14.12 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3362 fps= 26 q=23.0 size=N/A time=00:02:14.48 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3376 fps= 26 q=21.0 size=N/A time=00:02:15.04 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3395 fps= 26 q=25.0 size=N/A time=00:02:15.80 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3408 fps= 26 q=27.0 size=N/A time=00:02:16.32 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3422 fps= 26 q=22.0 size=N/A time=00:02:16.88 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3432 fps= 26 q=21.0 size=N/A time=00:02:17.28 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3446 fps= 26 q=20.0 size=N/A time=00:02:17.84 bitrate=N/A dup=42 drop=0 speed=1.05x frame= 3455 fps= 26 q=23.0 size=N/A time=00:02:18.20 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3467 fps= 26 q=22.0 size=N/A time=00:02:18.68 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3482 fps= 26 q=25.0 size=N/A time=00:02:19.28 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3495 fps= 26 q=26.0 size=N/A time=00:02:19.80 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3510 fps= 26 q=24.0 size=N/A time=00:02:20.40 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3519 fps= 26 q=29.0 size=N/A time=00:02:20.76 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3536 fps= 26 q=31.0 size=N/A time=00:02:21.44 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3547 fps= 26 q=29.0 size=N/A time=00:02:21.88 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3559 fps= 26 q=29.0 size=N/A time=00:02:22.36 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3576 fps= 26 q=30.0 size=N/A time=00:02:23.04 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3587 fps= 26 q=31.0 size=N/A time=00:02:23.48 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3592 fps= 26 q=30.0 size=N/A time=00:02:23.68 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3612 fps= 26 q=22.0 size=N/A time=00:02:24.48 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3625 fps= 26 q=26.0 size=N/A time=00:02:25.00 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3638 fps= 26 q=21.0 size=N/A time=00:02:25.52 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3651 fps= 26 q=22.0 size=N/A time=00:02:26.04 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3664 fps= 26 q=24.0 size=N/A time=00:02:26.56 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3675 fps= 26 q=25.0 size=N/A time=00:02:27.00 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3687 fps= 26 q=26.0 size=N/A time=00:02:27.48 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3699 fps= 26 q=26.0 size=N/A time=00:02:27.96 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3715 fps= 26 q=25.0 size=N/A time=00:02:28.60 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3728 fps= 26 q=25.0 size=N/A time=00:02:29.12 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3736 fps= 26 q=25.0 size=N/A time=00:02:29.44 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3749 fps= 26 q=24.0 size=N/A time=00:02:29.96 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3766 fps= 26 q=26.0 size=N/A time=00:02:30.64 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3779 fps= 26 q=24.0 size=N/A time=00:02:31.16 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3792 fps= 26 q=24.0 size=N/A time=00:02:31.68 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3807 fps= 26 q=26.0 size=N/A time=00:02:32.28 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3822 fps= 26 q=25.0 size=N/A time=00:02:32.88 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3832 fps= 26 q=25.0 size=N/A time=00:02:33.28 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3844 fps= 26 q=24.0 size=N/A time=00:02:33.76 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3857 fps= 26 q=24.0 size=N/A time=00:02:34.28 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3871 fps= 26 q=25.0 size=N/A time=00:02:34.84 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3883 fps= 26 q=26.0 size=N/A time=00:02:35.32 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3895 fps= 26 q=26.0 size=N/A time=00:02:35.80 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3905 fps= 26 q=26.0 size=N/A time=00:02:36.20 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3922 fps= 26 q=19.0 size=N/A time=00:02:36.88 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3935 fps= 26 q=23.0 size=N/A time=00:02:37.40 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3943 fps= 26 q=26.0 size=N/A time=00:02:37.72 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3959 fps= 26 q=28.0 size=N/A time=00:02:38.36 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3974 fps= 26 q=29.0 size=N/A time=00:02:38.96 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 3988 fps= 26 q=26.0 size=N/A time=00:02:39.52 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4002 fps= 26 q=25.0 size=N/A time=00:02:40.08 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4011 fps= 26 q=24.0 size=N/A time=00:02:40.44 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4028 fps= 26 q=22.0 size=N/A time=00:02:41.12 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4039 fps= 26 q=22.0 size=N/A time=00:02:41.56 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4056 fps= 26 q=22.0 size=N/A time=00:02:42.24 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4066 fps= 26 q=22.0 size=N/A time=00:02:42.64 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4079 fps= 26 q=22.0 size=N/A time=00:02:43.16 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4086 fps= 26 q=22.0 size=N/A time=00:02:43.44 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4095 fps= 26 q=22.0 size=N/A time=00:02:43.80 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4107 fps= 26 q=23.0 size=N/A time=00:02:44.28 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4119 fps= 26 q=23.0 size=N/A time=00:02:44.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4136 fps= 26 q=22.0 size=N/A time=00:02:45.44 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4153 fps= 26 q=22.0 size=N/A time=00:02:46.12 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4168 fps= 26 q=24.0 size=N/A time=00:02:46.72 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4182 fps= 26 q=24.0 size=N/A time=00:02:47.28 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4192 fps= 26 q=24.0 size=N/A time=00:02:47.68 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4202 fps= 26 q=25.0 size=N/A time=00:02:48.08 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4226 fps= 26 q=22.0 size=N/A time=00:02:49.04 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4237 fps= 26 q=22.0 size=N/A time=00:02:49.48 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4247 fps= 26 q=22.0 size=N/A time=00:02:49.88 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4254 fps= 26 q=23.0 size=N/A time=00:02:50.16 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4264 fps= 26 q=25.0 size=N/A time=00:02:50.56 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4278 fps= 26 q=21.0 size=N/A time=00:02:51.12 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4295 fps= 26 q=17.0 size=N/A time=00:02:51.80 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4307 fps= 26 q=18.0 size=N/A time=00:02:52.28 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4323 fps= 26 q=17.0 size=N/A time=00:02:52.92 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4342 fps= 26 q=21.0 size=N/A time=00:02:53.68 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4354 fps= 26 q=21.0 size=N/A time=00:02:54.16 bitrate=N/A dup=42 drop=0 speed=1.04x frame= 4367 fps= 26 q=21.0 size=N/A time=00:02:54.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4380 fps= 26 q=22.0 size=N/A time=00:02:55.20 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4392 fps= 26 q=22.0 size=N/A time=00:02:55.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4403 fps= 26 q=22.0 size=N/A time=00:02:56.12 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4418 fps= 26 q=22.0 size=N/A time=00:02:56.72 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4435 fps= 26 q=18.0 size=N/A time=00:02:57.40 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4449 fps= 26 q=17.0 size=N/A time=00:02:57.96 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4459 fps= 26 q=22.0 size=N/A time=00:02:58.36 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4466 fps= 26 q=23.0 size=N/A time=00:02:58.64 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4484 fps= 26 q=17.0 size=N/A time=00:02:59.36 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4498 fps= 26 q=17.0 size=N/A time=00:02:59.92 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4511 fps= 26 q=21.0 size=N/A time=00:03:00.44 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4521 fps= 26 q=22.0 size=N/A time=00:03:00.84 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4530 fps= 26 q=23.0 size=N/A time=00:03:01.20 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4544 fps= 26 q=23.0 size=N/A time=00:03:01.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4559 fps= 26 q=22.0 size=N/A time=00:03:02.36 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4577 fps= 26 q=25.0 size=N/A time=00:03:03.08 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4587 fps= 26 q=25.0 size=N/A time=00:03:03.48 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4600 fps= 26 q=26.0 size=N/A time=00:03:04.00 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4617 fps= 26 q=23.0 size=N/A time=00:03:04.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4633 fps= 26 q=21.0 size=N/A time=00:03:05.32 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4646 fps= 26 q=20.0 size=N/A time=00:03:05.84 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4653 fps= 26 q=22.0 size=N/A time=00:03:06.12 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4665 fps= 26 q=23.0 size=N/A time=00:03:06.60 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4676 fps= 26 q=23.0 size=N/A time=00:03:07.04 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4685 fps= 26 q=23.0 size=N/A time=00:03:07.40 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4701 fps= 26 q=24.0 size=N/A time=00:03:08.04 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4712 fps= 26 q=23.0 size=N/A time=00:03:08.48 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4732 fps= 26 q=22.0 size=N/A time=00:03:09.28 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4746 fps= 26 q=26.0 size=N/A time=00:03:09.84 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4762 fps= 26 q=21.0 size=N/A time=00:03:10.48 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4770 fps= 26 q=21.0 size=N/A time=00:03:10.80 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4783 fps= 26 q=21.0 size=N/A time=00:03:11.32 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4791 fps= 26 q=22.0 size=N/A time=00:03:11.64 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4803 fps= 26 q=22.0 size=N/A time=00:03:12.12 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4822 fps= 26 q=21.0 size=N/A time=00:03:12.88 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4839 fps= 26 q=21.0 size=N/A time=00:03:13.56 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4846 fps= 26 q=25.0 size=N/A time=00:03:13.84 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4864 fps= 26 q=22.0 size=N/A time=00:03:14.56 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4883 fps= 26 q=22.0 size=N/A time=00:03:15.32 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4890 fps= 26 q=22.0 size=N/A time=00:03:15.60 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4906 fps= 26 q=22.0 size=N/A time=00:03:16.24 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4922 fps= 26 q=21.0 size=N/A time=00:03:16.88 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4928 fps= 26 q=22.0 size=N/A time=00:03:17.12 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4947 fps= 26 q=21.0 size=N/A time=00:03:17.88 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4954 fps= 26 q=23.0 size=N/A time=00:03:18.16 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4972 fps= 26 q=22.0 size=N/A time=00:03:18.88 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4986 fps= 26 q=21.0 size=N/A time=00:03:19.44 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 4996 fps= 26 q=22.0 size=N/A time=00:03:19.84 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5013 fps= 26 q=21.0 size=N/A time=00:03:20.52 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5019 fps= 26 q=21.0 size=N/A time=00:03:20.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5030 fps= 26 q=23.0 size=N/A time=00:03:21.20 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5044 fps= 26 q=21.0 size=N/A time=00:03:21.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5064 fps= 26 q=21.0 size=N/A time=00:03:22.56 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5077 fps= 26 q=21.0 size=N/A time=00:03:23.08 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5094 fps= 26 q=22.0 size=N/A time=00:03:23.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5102 fps= 26 q=25.0 size=N/A time=00:03:24.08 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5117 fps= 26 q=22.0 size=N/A time=00:03:24.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5130 fps= 26 q=24.0 size=N/A time=00:03:25.20 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5144 fps= 26 q=21.0 size=N/A time=00:03:25.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5154 fps= 26 q=22.0 size=N/A time=00:03:26.16 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5169 fps= 26 q=23.0 size=N/A time=00:03:26.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5186 fps= 26 q=21.0 size=N/A time=00:03:27.44 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5204 fps= 26 q=21.0 size=N/A time=00:03:28.16 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5216 fps= 26 q=21.0 size=N/A time=00:03:28.64 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5224 fps= 26 q=21.0 size=N/A time=00:03:28.96 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5236 fps= 26 q=20.0 size=N/A time=00:03:29.44 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5251 fps= 26 q=18.0 size=N/A time=00:03:30.04 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5258 fps= 26 q=20.0 size=N/A time=00:03:30.32 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5275 fps= 26 q=22.0 size=N/A time=00:03:31.00 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5292 fps= 26 q=22.0 size=N/A time=00:03:31.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5305 fps= 26 q=22.0 size=N/A time=00:03:32.20 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5315 fps= 26 q=26.0 size=N/A time=00:03:32.60 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5326 fps= 26 q=19.0 size=N/A time=00:03:33.04 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5336 fps= 26 q=21.0 size=N/A time=00:03:33.44 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5344 fps= 26 q=22.0 size=N/A time=00:03:33.76 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5355 fps= 26 q=22.0 size=N/A time=00:03:34.20 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5382 fps= 26 q=22.0 size=N/A time=00:03:35.28 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5392 fps= 26 q=23.0 size=N/A time=00:03:35.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5403 fps= 26 q=25.0 size=N/A time=00:03:36.12 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5413 fps= 26 q=22.0 size=N/A time=00:03:36.52 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5429 fps= 26 q=22.0 size=N/A time=00:03:37.16 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5443 fps= 26 q=21.0 size=N/A time=00:03:37.72 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5458 fps= 26 q=21.0 size=N/A time=00:03:38.32 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5472 fps= 26 q=21.0 size=N/A time=00:03:38.88 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5483 fps= 26 q=21.0 size=N/A time=00:03:39.32 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5495 fps= 26 q=21.0 size=N/A time=00:03:39.80 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5512 fps= 26 q=20.0 size=N/A time=00:03:40.48 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5523 fps= 26 q=20.0 size=N/A time=00:03:40.92 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5536 fps= 26 q=21.0 size=N/A time=00:03:41.44 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5547 fps= 26 q=21.0 size=N/A time=00:03:41.88 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5559 fps= 26 q=22.0 size=N/A time=00:03:42.36 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5572 fps= 26 q=21.0 size=N/A time=00:03:42.88 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5591 fps= 26 q=23.0 size=N/A time=00:03:43.64 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5600 fps= 26 q=23.0 size=N/A time=00:03:44.00 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5617 fps= 26 q=23.0 size=N/A time=00:03:44.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5629 fps= 26 q=23.0 size=N/A time=00:03:45.16 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5639 fps= 26 q=23.0 size=N/A time=00:03:45.56 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5652 fps= 26 q=23.0 size=N/A time=00:03:46.08 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5662 fps= 26 q=23.0 size=N/A time=00:03:46.48 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5676 fps= 26 q=22.0 size=N/A time=00:03:47.04 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5687 fps= 26 q=21.0 size=N/A time=00:03:47.48 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5697 fps= 26 q=21.0 size=N/A time=00:03:47.88 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5716 fps= 26 q=19.0 size=N/A time=00:03:48.64 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5726 fps= 26 q=20.0 size=N/A time=00:03:49.04 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5742 fps= 26 q=20.0 size=N/A time=00:03:49.68 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5760 fps= 26 q=20.0 size=N/A time=00:03:50.40 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5777 fps= 26 q=23.0 size=N/A time=00:03:51.08 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5788 fps= 26 q=22.0 size=N/A time=00:03:51.52 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5800 fps= 26 q=22.0 size=N/A time=00:03:52.00 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5810 fps= 26 q=22.0 size=N/A time=00:03:52.40 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5824 fps= 26 q=22.0 size=N/A time=00:03:52.96 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5841 fps= 26 q=22.0 size=N/A time=00:03:53.64 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5854 fps= 26 q=22.0 size=N/A time=00:03:54.16 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5865 fps= 26 q=22.0 size=N/A time=00:03:54.60 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5872 fps= 26 q=22.0 size=N/A time=00:03:54.88 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5882 fps= 26 q=24.0 size=N/A time=00:03:55.28 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5891 fps= 26 q=23.0 size=N/A time=00:03:55.64 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5905 fps= 26 q=23.0 size=N/A time=00:03:56.20 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5924 fps= 26 q=23.0 size=N/A time=00:03:56.96 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5939 fps= 26 q=23.0 size=N/A time=00:03:57.56 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5955 fps= 26 q=20.0 size=N/A time=00:03:58.20 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 5965 fps= 26 q=24.0 size=N/A time=00:03:58.60 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5971 fps= 26 q=24.0 size=N/A time=00:03:58.84 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5980 fps= 26 q=24.0 size=N/A time=00:03:59.20 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 5995 fps= 26 q=22.0 size=N/A time=00:03:59.80 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6012 fps= 26 q=24.0 size=N/A time=00:04:00.48 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6030 fps= 26 q=22.0 size=N/A time=00:04:01.20 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6043 fps= 26 q=22.0 size=N/A time=00:04:01.72 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6058 fps= 26 q=22.0 size=N/A time=00:04:02.32 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6070 fps= 26 q=21.0 size=N/A time=00:04:02.80 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6084 fps= 26 q=22.0 size=N/A time=00:04:03.36 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6098 fps= 26 q=22.0 size=N/A time=00:04:03.92 bitrate=N/A dup=42 drop=0 speed=1.03x frame= 6109 fps= 26 q=22.0 size=N/A time=00:04:04.36 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6123 fps= 26 q=22.0 size=N/A time=00:04:04.92 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6134 fps= 26 q=22.0 size=N/A time=00:04:05.36 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6150 fps= 26 q=22.0 size=N/A time=00:04:06.00 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6160 fps= 26 q=23.0 size=N/A time=00:04:06.40 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6172 fps= 26 q=22.0 size=N/A time=00:04:06.88 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6183 fps= 26 q=23.0 size=N/A time=00:04:07.32 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6194 fps= 26 q=24.0 size=N/A time=00:04:07.76 bitrate=N/A dup=42 drop=0 speed=1.02x frame= 6203 fps= 26 q=23.0 Lsize=N/A time=00:04:08.12 bitrate=N/A dup=42 drop=0 speed=1.02x video:215710kB audio:5808kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0x579e340] frame I:83 Avg QP:17.59 size:159563 [libx264 @ 0x579e340] frame P:6120 Avg QP:20.90 size: 33929 [libx264 @ 0x579e340] mb I I16..4: 15.2% 34.6% 50.1% [libx264 @ 0x579e340] mb P I16..4: 5.6% 5.3% 1.8% P16..4: 57.6% 0.0% 0.0% 0.0% 0.0% skip:29.6% [libx264 @ 0x579e340] 8x8 transform intra:40.9% inter:65.7% [libx264 @ 0x579e340] coded y,uvDC,uvAC intra: 48.9% 61.5% 26.5% inter: 21.7% 26.1% 1.1% [libx264 @ 0x579e340] i16 v,h,dc,p: 43% 37% 14% 6% [libx264 @ 0x579e340] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 25% 22% 5% 5% 5% 6% 5% 8% [libx264 @ 0x579e340] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 51% 10% 4% 3% 3% 4% 3% 6% [libx264 @ 0x579e340] i8c dc,h,v,p: 40% 30% 20% 10% [libx264 @ 0x579e340] Weighted P-Frames: Y:5.4% UV:3.5% [libx264 @ 0x579e340] kb/s:7121.93 Edited October 15, 2016 by KRA
Luke 42242 Posted October 15, 2016 Posted October 15, 2016 In the first example it's definitely mp3. what live tv plugin is this?
