ZiggiNuber 0 Posted October 15, 2016 Posted October 15, 2016 (edited) Hello everyone First of all: thanks for such an amazing media player like emby theater. On my system it runs much better and more stable than plex for playback my movies. But i noticed one big problem: Yesterday i started the new star wars movie and everything just worked fine. I added german subtitles and this also worked without any problem. After that i closed the movie and reopened it. Now emby theater couldnt run the movie smooth. It really lags all the time. When i switch off the subtitles and reactivate them everything works just fine again. The movie just won't start properly with activated subtitles. Anyone else also had this issue? Btw: When i choose the audio language within the movie, it just shows me multiple "Surround 5.1" tracks but no language is shown? This is really annoying when you have more languages. Thanks for the help Edited October 15, 2016 by ZiggiNuber
ZiggiNuber 0 Posted October 15, 2016 Author Posted October 15, 2016 (edited) Its a bluray rip made with MakeMKV. The subtitles are included in the .mkv file Codec is PGSSUB if it helps. The issue occurs with different movies, i must start them without any subs as otherwise it can happen that it lags or the video/audio playback isn't synchronic when changing subs while the movie is running. Edited October 15, 2016 by ZiggiNuber
Luke 42242 Posted October 17, 2016 Posted October 17, 2016 Do you know what kind of GPU you have? Are video settings in the app on default?
Guest asrequested Posted October 19, 2016 Posted October 19, 2016 I wonder if this is the same problem that occurred here. https://emby.media/community/index.php?/topic/38973-some-files-crashing-emby-theater/&do=findComment&comment=373983
