stettler 31 Posted October 14, 2016 Posted October 14, 2016 Hello, Under Windows 10, ET interface is using a lot of GPU resources (when not playing a video). With an Intel N3700, the GPU load is 100%. The load actualy drop when playing a video. Someone else reported the same problem with a mid-range Nvidia GPU (not 100% load but still more than 40%). On another computer, with a weak Intel HD Graphics GPU, running Windows 7, the GPU load is only 1-3% when ET is running. I couldn't make more test to check if the difference is caused by Windows 7 and Windows 10. I will try to find a few more computers with the various OS.
