speedingcheetah 39 Posted October 14, 2016 Posted October 14, 2016 First, the channels are showing out of number order. Some 800 channels and 1 random 900 chanel shows up at the top of the guide...then goes on in normal numerical order. When i use Channel view the channels also are out of order. Channel view....it is off by one day ahead in its date headings. THe listings themselves of each program are right, but the day its under is wrong. Fridays listings labeled under Saturdays etc. The listings also are missing the "New" or "Repeat" icons they used to have in channel list. Version 3.1.188.0 beta I have refreshed guide data, restarted server and computer, system clock is right. No other issues to report at the moment.
PenkethBoy 2068 Posted October 14, 2016 Posted October 14, 2016 the channels out of order at the top - i had that with favourites set although i have no favourites - even setting and unsetting favourites - does not reset it - i reported it a few days ago if you turn off favourites you get the correct order - works with channels as well I think my problem is i did have favourites a while ago when testing and have a different list of channels now - but somewhere its remembering it speculation - as for the listings being a day out have you got your country correct in metadata>settings and the timezone correct for the pc/server in the os? New or Repeat come from the epg provider you are using - some dont have it - i was using the over the air epg via NextPVR and everything was new!!! Added Schedule direct to the setup and its mostly correct now YMMV
ebr 16307 Posted October 14, 2016 Posted October 14, 2016 In the settings in the guide, what is your channel order set to?
PenkethBoy 2068 Posted October 14, 2016 Posted October 14, 2016 (edited) gets you this change to this gets you this and Zero favourites set if i do set a favourite it jumps to first place - un favourtie goes back to pic 4 with fav option still checked This has been like this (for me) for a week or so on Dev Edited October 14, 2016 by PenkethBoy 1
speedingcheetah 39 Posted October 15, 2016 Author Posted October 15, 2016 (edited) I don't use Favorites channels in Emby. I have the tuner settings settings (HD HomeRun Prime) to only include "Favorite" channel. I painstakingly went through the may of duplicate channels Comcrap has in my area to file out SD channels and only leave the HD...then the duplicate HD channels (400's then line up starts up again in the 800s) That Is done though the tuners OEM menu. I use Schedule Direct. I did not know the little box button next to the date was there...I was lookigin in Dashboard for settings. Guide fixed now. Thanks. Still have the CHannel view heading off by one day(exactly 24rs). All time date and time setting I can find are correct. Edited October 15, 2016 by speedingcheetah
CBers 7541 Posted October 15, 2016 Posted October 15, 2016 Favouriting channels doesn't seem to work fully, unless it is putting the last favourited channel at the top all of the time. I favourited the UK HD channels so that they were at the top of the guide, but I have ITV1 HD (channel 103) above BBC1 SD (channel 1) in the guide. Some others aren't in the logical order I'd expect. I'll take a screenshot and post what I mean.
PenkethBoy 2068 Posted October 15, 2016 Posted October 15, 2016 @@CBers theres a setting somewhere (cant find it now) about most watched channels first or something like that which might be messing up you favourites order of HD channels
CBers 7541 Posted October 15, 2016 Posted October 15, 2016 It's OK, I've sorted it now. I've unfavourited and re-favourited the channels and they now appear at the top, with that option on.
kanipek 230 Posted October 16, 2016 Posted October 16, 2016 Capture.PNG gets you this Capture2.PNG change to this Capture4.PNG gets you this Capture3.PNG and Capture5.PNG Zero favourites set if i do set a favourite it jumps to first place - un favourtie goes back to pic 4 with fav option still checked This has been like this (for me) for a week or so on Dev Can you tell me where I can find these guide setting screens? I have looked and looked but I find no way to access them. Thanks for reading and any help you can provide!
blade005 185 Posted October 16, 2016 Posted October 16, 2016 Settings are on the guide page. Just to the right of the day selection. System must be at a high enough display resolution for it to show. The selection shows on my system that is set for 1920 x 1080. It does not show on my system set at 1280 x 800. 1
kanipek 230 Posted October 16, 2016 Posted October 16, 2016 Thank you so much! Your info on resolution made the menu button show up! I still have 1 channel out of order, but it is much better. Greatly appreciate it!!
speedingcheetah 39 Posted October 27, 2016 Author Posted October 27, 2016 (edited) The Channel View is still one day off. The Guide View with all the channels, is not affected. Screen shot taken just now Thursday October 27 at 6:30pm. Central Edited October 27, 2016 by speedingcheetah 1
kanipek 230 Posted December 8, 2016 Posted December 8, 2016 The Channel View is still one day off. The Guide View with all the channels, is not affected. Screen shot taken just now Thursday October 27 at 6:30pm. Central Is there any update on a fix for this? I am still seeing the channel view guide data off by one day.
Luke 42186 Posted December 8, 2016 Posted December 8, 2016 It is resolved for the next release of Emby Server. Thanks. 1
