Happy2Play 9802 Posted October 13, 2016 Posted October 13, 2016 Figured I would open a separate topic on this issue. If a Unset library only contains one media type Content type is unavailable. Here is a library set Unset with mixed content - Appear correct with content type options for TV and Movies A Unset library with only TV - no content type options A Unset library with only movies - no content type options And a library content type TV - no content type options for complex folder structure Hope this demonstrated the issue better. All testing was done in Version 3.1.6130.18236 dev 1
Happy2Play 9802 Posted November 26, 2016 Author Posted November 26, 2016 @@Luke Is this going to be added back or will this have to be done manually as I posted in other topics?
Luke 42205 Posted November 26, 2016 Posted November 26, 2016 I haven't had a chance to look at it yet, but yes it will be added back.
Happy2Play 9802 Posted February 7, 2017 Author Posted February 7, 2017 (edited) This is still an issue example from TV library, only workaround in manually adding to system.xml. 3.2.0.100 Edited February 7, 2017 by Happy2Play
Neonteepee 0 Posted March 21, 2017 Posted March 21, 2017 Appreciate there are probably a million things going on at once but is there any ETA on when this might get fixed/put back, I am obviously not the only one hanging on it. Please.... Pretty please.
Happy2Play 9802 Posted March 21, 2017 Author Posted March 21, 2017 Appreciate there are probably a million things going on at once but is there any ETA on when this might get fixed/put back, I am obviously not the only one hanging on it. Please.... Pretty please. There are manual ways to do this if you need assistance.
Neonteepee 0 Posted March 21, 2017 Posted March 21, 2017 (edited) I saw you can edit the system.xml? Any chance you can post a real quick explainer before I break my system? Also any chance someone could update the wiki? It currently says this option is available, I spent quite a bit of time searching in here and trying to work out what I was doing wrong. Thanks for your fast response BTW. I'm on current stable.3.2.7.0 Edited March 21, 2017 by Neonteepee
Happy2Play 9802 Posted March 21, 2017 Author Posted March 21, 2017 (edited) I saw you can edit the system.xml? Any chance you can post a real quick explainer before I break my system? Also any chance someone could update the wiki? It currently says this option is available, I spent quite a bit of time searching in here and trying to work out what I was doing wrong. Thanks for your fast response BTW. I'm on current stable.3.2.7.0 @@Luke is still determining the best way to handle this. This post should help. A library scan is required after making these changes. Edited March 21, 2017 by Happy2Play
austie 4 Posted November 18, 2017 Posted November 18, 2017 Hi Guys, has this progressed any further yet? I have just tried to create a couple of different sub folders under TV\N-Z\Star Trek Discovery to be \TV\N-Z\Star Trek\Star Trek Discovery The metadata shows it as Star Trek Discovery as the folder when viewing via Folder type, however it's picking up all the Star Trek the original series details for episodes. I know I can manually identify the folders via the Identify option, but kinda defeats the purpose of grouping show groups together. Especially when the Marvel Universe is getting so large now, it be handy to store under 1 folder/ Regards Shane
austie 4 Posted February 11, 2018 Posted February 11, 2018 Hey everyone, Has there been any progress on this issue yet or do we need to edit the .xml manually still? It's a pain when you have heaps of series that you want to group in the content type (ie. the Marvel stuff) but can't because it picks it up as another series instead Regards Shane
Happy2Play 9802 Posted February 11, 2018 Author Posted February 11, 2018 (edited) Currently the only option is the manual edit of <ContentType> in system.xml. Edited February 11, 2018 by Happy2Play
