theniteow1 25 Posted October 13, 2016 Posted October 13, 2016 I'm running the latest beta 1.2.58a, and I have noticed for a while now that if you are watching a show for say 30 minutes, and then go to the mini-guide (where it still shows the channel you are watching) you will just get the spinning circle, with the guide overlayed with the darkened screen. It doesn't go away unless you change the page, or completely back out, and go back to the full guide. I've noticed also the times will be incorrect. Have you seen this behavior before?
ebr 16337 Posted October 13, 2016 Posted October 13, 2016 I think I've seen that happen before. I believe it is just a display problem. You should be able to still move around and interact with the guide...
theniteow1 25 Posted October 13, 2016 Author Posted October 13, 2016 I think I've seen that happen before. I believe it is just a display problem. You should be able to still move around and interact with the guide... It's a minor annoyance, but annoying. Yes, you still can interact with the guide. It didn't used to do that, so not sure what has changed.
ebr 16337 Posted October 13, 2016 Posted October 13, 2016 Yeah, clearly it is a problem. Hopefully I'll be able to track it down in the next release (the one after the one that's just about to go out). 1
