mohams 0 Posted October 13, 2016 Posted October 13, 2016 I recently purchased a HDhomerun Dual so I can watch Livetv using my OTA antenna and Emby. I was able to setup the device on my network (hard wired) and got it to work using the Silicon Dust "HDHomerun" App for Windows 10. The tuner detected several channels for my location here in Toronto, Canada. I then configured Livetv in Emby for the Tuner and selected Schedules Direct as my guide provider. I provided the userid, password, country, postal code and antenna for the Schedule Direct information. I have refreshed the data guide several times and tested again the next day but I get no channel information. I am a newbie at this and tried looking for information on how to setup the HDhomerun tuner for OTA antenna but could not find anything. At this time, all I want to do is watch live TV and don't need the DVR functionality. I have included the log file. Any help would be much appreciated. server-63611909495.txt
Guest asrequested Posted October 13, 2016 Posted October 13, 2016 Try updating your firmware. Install the latest beta. https://www.silicondust.com/forum/viewtopic.php?f=119&t=20613
mohams 0 Posted October 13, 2016 Author Posted October 13, 2016 Thanks for the quick response Doofus. I did have a problem before getting it to work with Silicon Dust "HDhomerun" app and they gave me the link for their latest firmware & software, which I have installed and it's working now although quite a few channels are choppy. I am hoping that its because of weak OTA signals. The problem seems that it might be EMBY's LiveTv not getting the required information from my scheduledirect account.
CBers 7541 Posted October 13, 2016 Posted October 13, 2016 @@mohams You can report a channel issue at SchedulesDirect. https://schedulesdirect.org/lineupsupport They'll investigate and get back to you.
mohams 0 Posted October 13, 2016 Author Posted October 13, 2016 Below, is some of what I see from the log file that I have attached in my post. Not sure how to interpret, but it appears that EMBY is getting some info from ScheduleDirect but I don't see it when I select LiveTv. ------------------------------------------------------------------------------------------------------------------------------------------- 2016-10-12 22:54:25.0568 Info App: Found 70 channels on the lineup on ScheduleDirect2016-10-12 22:54:25.0568 Info App: Mapping Stations to Channel2016-10-12 22:54:25.0568 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 699ms. http://localhost:8096/emby/LiveTv/ChannelMappingOptions?providerId=423f325bd44244ea91646da57e45ec36
Guest asrequested Posted October 13, 2016 Posted October 13, 2016 Are you seeing channels and no show metadata or are the channels missing in the guide?
mohams 0 Posted October 13, 2016 Author Posted October 13, 2016 When I select the guide tab, I only see the time bars at the top. When I select the channels tab, the page is totally blank.
Solution Luke 42186 Posted October 13, 2016 Solution Posted October 13, 2016 Sorry I dont think your HDHR Dual has the Dlna feature that we are depending on. 1
mohams 0 Posted October 14, 2016 Author Posted October 14, 2016 That would explain everything. Thanks, Luke. Now I can move on..........
