Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 Guess what I found it. For all you GB users. The master missed a file. 3
CBers 7576 Posted October 13, 2016 Posted October 13, 2016 Guess what I found it. For all you GB users. The master missed a file. Great find !! 2
Happy2Play 9814 Posted October 14, 2016 Posted October 14, 2016 (edited) @@Luke - looks like this translation change was made for some reason here (21 days ago). Edited October 14, 2016 by Happy2Play 1
Luke 42289 Posted October 14, 2016 Posted October 14, 2016 That's not in the master translation that I upload to onesky. must have been a defect of theirs that we hit when I exported to en-gb. well i guess we'll see if the next update i pull is affected. thanks. 1
CBers 7576 Posted October 15, 2016 Posted October 15, 2016 Got it in version 3.0.8100.0 Got it in what way ?? Still not correct in dev version. 1
David Martin 24 Posted October 15, 2016 Author Posted October 15, 2016 My bad, Got as in still showing in the latest update - stable. 1
Happy2Play 9814 Posted October 18, 2016 Posted October 18, 2016 Yep, file in strings folder need updated. en-GB.json 1030 "OptionDisplayFolderView": "Display a folder view to show plain media folders", 1031 "OptionDisplayFolderViewHelp": "If you have a dynamic DNS enter it here. Emby apps will use it when connecting remotely. This field is required when used with a custom SSL certificate.",
Luke 42289 Posted October 18, 2016 Posted October 18, 2016 It was either a mistake by a translator or there's a problem with onesky. i haven't checked into it yet, but updating the translation file in emby won't help much because they'll be lost on the next onesky sync.
