David Martin 24 Posted October 13, 2016 Posted October 13, 2016 Not sure if its intentional or not but the description for "Display a folder view to show plain media folders" seems out of place, Highlighted in the screenshot. Great work on the update. 1
Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 (edited) Hmm, I just installed 3.0.8000 over my dev build and don't see this. Didn't see it on beta or dev either. Edited October 13, 2016 by Happy2Play 1
David Martin 24 Posted October 13, 2016 Author Posted October 13, 2016 Im on stable. Could be some of the css will remove it and get back to yah.
Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 Im on stable. Could be some of the css will remove it and get back to yah. Shouldn't be unless you are rewriting descriptions is css. Does it appear that way in a different browser? 1
David Martin 24 Posted October 13, 2016 Author Posted October 13, 2016 Still seeing it without css on and just checked on android i can see it in app too.
CBers 7576 Posted October 13, 2016 Posted October 13, 2016 Confirmed here in the dashboard in DEV, BETA and STABLE versions as well as the Android app. 1
Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 Hmm, why are we seeing mixed results? Is this a Windows install? 1
David Martin 24 Posted October 13, 2016 Author Posted October 13, 2016 Yeah in other browsers too. Yeah its on Windows 7.
Angelblue05 4132 Posted October 13, 2016 Posted October 13, 2016 I don't see this on 3.1.187.0 beta 1
Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 I just did a clean install of .8000 1
CBers 7576 Posted October 13, 2016 Posted October 13, 2016 I wonder if the information is being cached. 1
David Martin 24 Posted October 13, 2016 Author Posted October 13, 2016 Its possible, Ill do a clean install later on and see if that fixes it.
Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 That is what I was thinking but you are saying multiple devices see it this way. In IE, Edge, Chrome and FF I see that right info.
Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 Could you try clearing your browser cache. 1
David Martin 24 Posted October 13, 2016 Author Posted October 13, 2016 Yeah so far I get it in Chrome, Firefox, Internet Explorer and Android app and browser.
David Martin 24 Posted October 13, 2016 Author Posted October 13, 2016 Cleared cache still got it showing.
CBers 7576 Posted October 13, 2016 Posted October 13, 2016 Just cleared by browser cache in CHROME and opened an INCOGNITO Chrome window, but I am seeing still in DEV, BETA and STABLE. Totally confusing, as it's not normally a page I would open. 1
Happy2Play 9814 Posted October 13, 2016 Posted October 13, 2016 Yes, there is something weird going on with this release then at all levels. 1
CBers 7576 Posted October 13, 2016 Posted October 13, 2016 (edited) Just checked my friend's and family's servers, who all run BETA, and it is the same there as well. One of my friends is still on .186 and it's there as well. Edited October 13, 2016 by CBers 1
David Martin 24 Posted October 13, 2016 Author Posted October 13, 2016 Ok no worries, Its not really that much of an issue just might be a bit confusing to first time users i guess. 2
