Tikuf 663 Posted January 19, 2014 Posted January 19, 2014 (edited) Ok I am going to assume a bit here so this covers the basics only. I am going to assume you have tortoise git and have forked the resources project. I am using tortoise git for this as I find it easy to use. First after you have forked create the repo on your hd by pulling your own fork down (I am not going to go into much detail for this bit as it is is all on the git site) Ok so skipping a few steps how do you add the studio/genre images you have created (I will work with a studio) Copy the thumb.jpg into its own folder (studio name). Then copy that folder into the appropriate folder inside the repo on you hd. It will look something like (below) EDIT: I have included a small exe to update the studio thumbs text file (its very basic and just lists the folders into the txt file.) Right click on the added folder(s) and select Tortoise Git / Add A pop up will pop Select the files to add to the project as I have done above. Next pop up will pop Click on the commit button and another popup will pop Fill in the message brief description of what you have done then click ok. Click on push Make sure you select the right repo to push to in this case it is origin. Then click ok. Fill in you user name / password when prompted You can hit create pull request here and follow through, but I find it easier to hit close at this time and do the pull request from the git site as i can check and make sure it is all correct. Cheers Hope that makes it easier for someone (this is just how I do it not necessarily how it should be done ) Edited February 10, 2014 by Tikuf 4
gcw07 347 Posted January 19, 2014 Posted January 19, 2014 There is also the option of just using: Github for Windows http://windows.github.com/ Github for Mac http://mac.github.com/ Both simplify things a bit. 1
Luke 42237 Posted January 19, 2014 Posted January 19, 2014 If you're going to do this, can you make it complete from start to finish, like I did in the other thread. Sign up for github, how to create the fork, install software, pull down the source, submit the pull request, etc. Then how to resync your fork when there are new changes on the server. 1
Tikuf 663 Posted January 19, 2014 Author Posted January 19, 2014 If you're going to do this, can you make it complete from start to finish, like I did in the other thread. Sign up for github, how to create the fork, install software, pull down the source, submit the pull request, etc. Then how to resync your fork when there are new changes on the server. Yup will do just didn't have the time to do the full version I will edit over the next couple of days as time permits. 1
Luke 42237 Posted January 19, 2014 Posted January 19, 2014 Maybe @@Brendon can do it, or @@bloodtaker 1
Brendon 124 Posted January 20, 2014 Posted January 20, 2014 can do if tikuf doesnt have the time, just need a day or 2 as well to catch up on the last 2 weeks
Luke 42237 Posted January 20, 2014 Posted January 20, 2014 Brendon that is fine. Tikuf is our main man when it comes to streaming and encoding, so anything like this that we can offload to someone else will be a big help.
Tikuf 663 Posted January 20, 2014 Author Posted January 20, 2014 Brendon that would be awesome mate. TY
Cheesegeezer 3106 Posted January 25, 2014 Posted January 25, 2014 There's a couple of pull requests waiting to be forked on Git.
AlwinHummels 134 Posted January 25, 2014 Posted January 25, 2014 Did a pull request a couple days ago but nothing happens what did I do wrong??
AlwinHummels 134 Posted January 26, 2014 Posted January 26, 2014 Why doesn't anybody response on my git commits and questions? I think I go further for my-self and don't share anymore if not appreciate !!
gcw07 347 Posted January 26, 2014 Posted January 26, 2014 More then likely just nobody has seen them. I'm sure Luke will see it and merge the pull request. He just sometimes gets busy and misses things.
AlwinHummels 134 Posted January 26, 2014 Posted January 26, 2014 (edited) It's rejected but I don't know what's wrong and how to fix it please more help is welcome. I did step by step what was written above. Edited January 26, 2014 by AlwinHummels
Luke 42237 Posted January 26, 2014 Posted January 26, 2014 The pull request has lines added to studiothumbs.txt but I don't see any images for those lines that have been added.
AlwinHummels 134 Posted January 26, 2014 Posted January 26, 2014 (edited) The pull request has lines added to studiothumbs.txt but I don't see any images for those lines that have been added. Okay but I didn't add a picture but replace it so I think that's why it went wrong. But I appreciate any help to do it the right way. Edited January 26, 2014 by AlwinHummels
Luke 42237 Posted January 26, 2014 Posted January 26, 2014 Just remove all of your changes from studiothumbs.txt and it should be fine. Or just post a zip file with your new images. There's plenty of others here who can submit the pull request.
AlwinHummels 134 Posted January 26, 2014 Posted January 26, 2014 Ok thanks i will do it tomorrow ;-) 1
