navidonskis 0 Posted October 10, 2016 Posted October 10, 2016 Hello, i tried to upload .m3u file with custom list of different channels (IPTV), the list looks like: #EXTINF:-1,Viasat History udp://@233.136.41.34:1234 #EXTINF:-1,A Music udp://@233.136.41.35:1234 #EXTINF:-1,Viasat Sport Baltic udp://@233.136.41.36:1234 as you see, the prefix of the URL are udp, so it's streaming via udp protocol. On the computer via VLC it's streaming perfectly, but when i try to stream via emby server, i getting an error: There was an error playing the video. Please ensure there is an open tuner availalble. So the question: is it possible to stream those channels via Emby Live TV or IPTV plugin (maybe)?p.s. on the IPTV there is no selection to choose streams via udp protocol, only http, file, rtmp and rtsp.
Luke 42242 Posted October 10, 2016 Posted October 10, 2016 Hi, we can look at supporting udp urls in a future release, thanks.
user29 2 Posted October 15, 2016 Posted October 15, 2016 + 1 have a custom m3u file - would be great to get this working (has lots of channels in it)
user29 2 Posted October 15, 2016 Posted October 15, 2016 iptv - doesnt seem to allow m3u files (lots of channels) only allows one
Luke 42242 Posted October 15, 2016 Posted October 15, 2016 iptv - doesnt seem to allow m3u files (lots of channels) only allows one You can do this with the m3u tuner import under live tv.
Luke 42242 Posted October 16, 2016 Posted October 16, 2016 yes you can check out our live tv wiki here: https://github.com/MediaBrowser/Wiki/wiki/Live%20TV
user29 2 Posted October 16, 2016 Posted October 16, 2016 Actually - easy to do - thanks! works well, only things is the TV Listings Name are abbreviated *lets say i have Sky Sports 1/2/34/5 i only see Sky* - can we make the guide wider?
Luke 42242 Posted October 16, 2016 Posted October 16, 2016 Thanks. There is currently no way to configure the guide column sizes, but you can always click the channel and view the single channel listing. FYI I am adding udp support within the m3u.
navidonskis 0 Posted October 16, 2016 Author Posted October 16, 2016 (edited) i update the server version, so i tested today by adding m3u file with udp stream links. Now when i'm trying to play the channel, the spinner always spinning, never ending. looks like he can't get a response. Status : Pending Edited October 16, 2016 by navidonskis
navidonskis 0 Posted October 16, 2016 Author Posted October 16, 2016 (edited) and here is the console log if that helps: Edited October 16, 2016 by navidonskis
Luke 42242 Posted October 16, 2016 Posted October 16, 2016 check the ffmpeg log. please note, i cannot test udp so I'm going to be relying on you here. if we can't figure out it i'll just have to remove it.
navidonskis 0 Posted October 16, 2016 Author Posted October 16, 2016 how do i check the ffmpeg logs? i didn't find at /var/log , there is some command on ubuntu for realtime logging for ffmpeg? Thanks
navidonskis 0 Posted October 16, 2016 Author Posted October 16, 2016 does it can be a problem, if i'm using a docker machine for emby server? ffmpeg version 2.8.8 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) i tried to add a stream link which is starting with http protocol and it's working, nor udp.
Luke 42242 Posted October 16, 2016 Posted October 16, 2016 The best thing to do is provide the information requested in how to report a problem. thanks !
navidonskis 0 Posted October 18, 2016 Author Posted October 18, 2016 it's working. I try to install emby server on mac os x, so it's working. But at ubuntu, maybe the firewall is blocking or something.
navidonskis 0 Posted October 18, 2016 Author Posted October 18, 2016 i was using a docker machine, so the problem was: docker is not supporting igmp multicast yet, so i install udpxy on the server, and change the all udp links with prefix of the server host, and replace the m3u file at emby server, so now it's streaming perfectly.
