Sp3kt3r 13 Posted October 9, 2016 Posted October 9, 2016 Hi, Im having a new issue with some file when emby is transcoding my mkv to my chromecast or even with the web browser interface.There's no audio, the source file has AC3 5.1. I looked through the log and I noticed that the audio data is 0KB but I'm not sure if I read that right I also see ''warning'' message regarding the transcoding stream (has not been used for any stream, the most likely reason.......) I have no idea what that's mean. Codec AVOption b (set bitrate (in bits/s)) specified for output file #0 (C:\Users\Flexraid\AppData\Roaming\MediaBrowser-Server\transcoding-temp\2e7e521ca79ea6a1fe0e548465b27c88.mkv) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some encoder which was not actually used for any stream. Output #0, matroska, to 'C:\Users\Flexraid\AppData\Roaming\MediaBrowser-Server\transcoding-temp\2e7e521ca79ea6a1fe0e548465b27c88.mkv': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (H264 / 0x34363248), yuv420p, 1280x718 [sAR 1:1 DAR 640:359], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc (default) Stream mapping: Stream #0:1 -> #0:0 (copy) Press [q] to stop, [?] for help frame= 2684 fps=0.0 q=-1.0 size= 63276kB time=00:02:08.58 bitrate=4031.1kbits/s speed= 257x frame= 4215 fps=4210 q=-1.0 size= 95010kB time=00:03:12.44 bitrate=4044.4kbits/s speed= 192x frame= 5584 fps=3720 q=-1.0 size= 125878kB time=00:04:09.54 bitrate=4132.3kbits/s speed= 166x frame= 8024 fps=4009 q=-1.0 size= 173071kB time=00:05:51.31 bitrate=4035.7kbits/s speed= 176x frame= 9118 fps=3641 q=-1.0 size= 199724kB time=00:06:36.94 bitrate=4121.9kbits/s speed= 159x frame=10433 fps=3473 q=-1.0 size= 240288kB time=00:07:31.78 bitrate=4357.0kbits/s speed= 150x frame=12638 fps=3605 q=-1.0 size= 289634kB time=00:09:03.75 bitrate=4363.5kbits/s speed= 155x frame=13616 fps=3399 q=-1.0 size= 313374kB time=00:09:44.54 bitrate=4391.7kbits/s speed= 146x frame=16189 fps=3593 q=-1.0 size= 362435kB time=00:11:31.86 bitrate=4291.4kbits/s speed= 154x frame=18089 fps=3611 q=-1.0 size= 403669kB time=00:12:51.10 bitrate=4288.5kbits/s speed= 154x frame=18819 fps=3416 q=-1.0 size= 417831kB time=00:13:21.55 bitrate=4270.3kbits/s speed= 145x frame=21290 fps=3571 q=-1.0 Lsize= 465860kB time=00:15:04.61 bitrate=4218.7kbits/s speed= 152x video:465686kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.037568% my emby version is beta 3.1.6034.22791. I had the problem with the previous beta version.I don't understand why it doesn't do it on all the mkv file with the same audio spec. any clue where I should look ? I attached the log, there's 2 remux log because while I tested the file, I changed the bitrate playback from the web browser to see if audio was going to kickin but it didn't. Thank you. remux-79a8da12-257c-402c-a7c5-ccb5f6d5ebbe.txt remux-84497278-f98c-4522-9a24-65896c9f0141.txt transcode-9c82370f-8ab7-46fe-accd-de1bd4c3c120.txt
Luke 42186 Posted October 9, 2016 Posted October 9, 2016 You're on an old Dev version so first I would try updating to the latest version
Sp3kt3r 13 Posted October 9, 2016 Author Posted October 9, 2016 That's wierd luke because my emby is set to BETA (not dev) and I just did a update check and I don't have anything.. perhaps I can try to uninstall and reinstall. What is the latest beta version ?
FrostByte 5433 Posted October 9, 2016 Posted October 9, 2016 3.1.183 https://github.com/MediaBrowser/Emby/releases
Sp3kt3r 13 Posted October 10, 2016 Author Posted October 10, 2016 ok I uninstall the version I had and reinstalled the beta 3.1.183. The problem is still occuring, if I play episode 3 it's find and if I play episode 4 it doesn't work.. I have a few file from different shows that does the same thing. my next step is to try a different ffmpeg version.
Solution Luke 42186 Posted October 10, 2016 Solution Posted October 10, 2016 try refreshing those titles from the detail screen. 1
Sp3kt3r 13 Posted October 10, 2016 Author Posted October 10, 2016 (edited) !!! Thank you Luke ! that was the problem.. before reading your reply I did a fresh install on a different computer and it works so I figured it was something inside emby. Would you mind tell me why a simple refresh fix the issue ? the file doesn't change !? what could have cause that ? would it be because I get sometime the same episode with better quality and just overwrite the file ?. I thought emby rescan automatically if the file is different. Thx again ! Question not related this: my emby folder under c:\users\..... Appdata is still named MediaBrowser.. it doesn't really matter but how can I make it Emby. even uninstalling emby and reinstalling doesn't change that. I know if I delete the whole configuration that might work but I don't want to loose all my settings and profile. Edited October 10, 2016 by Sp3kt3r
