pulse00 3 Posted October 9, 2016 Posted October 9, 2016 Is it possible to build MediaBrowser.Server.Mac (dev branch) on Xamarin for Mac? When opening the solution, updating nuget packages and cleaning all, i'm getting "The type of namespace 'Nat' does not exist in the namespace 'Mono'". It looks like 'Mono.Nat' is a nother solution in the dev branch which somehow Xamarin fails to resolve. Has anybody a hint how to resolve this?
Luke 42237 Posted October 9, 2016 Posted October 9, 2016 Try the matter branch. Dev has changes and I haven't updated the Mac solution yet.
pulse00 3 Posted October 9, 2016 Author Posted October 9, 2016 Are there major changes between master and dev/beta? If i try to work on something in master, will it likely create conflicts when dev will be merged back into master in the future?
Luke 42237 Posted October 9, 2016 Posted October 9, 2016 There are decent changes yes. What are you planning to look at?
pulse00 3 Posted October 9, 2016 Author Posted October 9, 2016 I'd like to try out adding a random view feature for the dashboard (just like the next up / resume views but with random items from the library).
